Old 02-09-2009, 01:25 AM   #1
kingsoup85
Member#: 122215
1998 RS/ 1979 BRAT
rally blue pearl
Default need help identifying an ej20g engine
need help identifying this. got the code from the top rear of the block. its got cross-hatching all over it. the code is 520832519753
is it an sti ra?
kingsoup85 is offline   Reply With Quote
Old 02-09-2009, 01:37 AM   #2
elislider
Member#: 133923
03 Legacy GT wagon
I love goooollllllllddddd
pics would probably be more helpful
elislider is offline   Reply With Quote
Old 02-09-2009, 01:56 AM   #3
kingsoup85
Member#: 122215
1998 RS/ 1979 BRAT
rally blue pearl
Old 02-09-2009, 02:36 AM   #4
RallyColtTurbo
Member#: 16819
That is closed deck, but it's not a WRX/STI RA.
It's from an early Legacy. Still an EJ20G, but an earlier head design. The interesting thing about that particualr one is that it doesn't have the Legacy cam and crank sensors. They have been changed to WRX ones.
RallyColtTurbo is offline   Reply With Quote
Old 02-09-2009, 04:00 AM   #5
kingsoup85
Member#: 122215
1998 RS/ 1979 BRAT
rally blue pearl
so the different sensors are that more notably different?
what's the difference between the early legacy ej20g and the wrx ej20g?
Old 02-09-2009, 10:46 AM   #6
RallyColtTurbo
Member#: 16819
The Legacy sensors have long leads that go to the bellhousing area. The WRX sensors, as show in the pic, plug in to the engine harness at the sensor.
The engines have about the same capabilities. The Legacy uses a stub rocker valve arraingement that is prone to ticking. The WRX uses a cam-over-bucket design. The Legacy has larger head chambers (and smaller piston chambers) than the WRX. The Legacy has no direct USDM eqivalent, while you can use '96 Outback/GT parts for the WRX head.
Old 02-09-2009, 01:46 PM   #7
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
so where did you get this engine .. it my old engine
the the yellow/green stuff on the bell housing is sidewalk paint (like sidewalk chalk but paint)
as above its a 92-93? legacy-gt auto came with a vf-10 had even compression ~165 on all cyls when i took it out in 2006
and yes the hla will get noisy if it sits .. but will quiet down after ~15 min
and those are ej18 cam and crank sensors
Old 02-09-2009, 02:45 PM   #8
kingsoup85
Member#: 122215
1998 RS/ 1979 BRAT
rally blue pearl
i got it from a guy in portland forgot his name... i think it was matt.
its good to have information on the block now.
Old 02-09-2009, 03:54 PM   #9
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Passed around like an ex-girlfriend...
Help Identifying an Engine bebesito21 Subaru Conversions 4 09-15-2008 04:16 PM
Need help identifying an old sci-fi artwork book Bottom Feeder Off-Topic 11 05-23-2006 10:00 PM
need help identifying an actress stuttgart Off-Topic 18 11-25-2005 06:31 AM
Need help with an blown engine!!! josh04 Normally Aspirated Powertrain 7 10-30-2005 03:24 PM
Need help identifying my motor ej20g jparent33 Subaru Conversions 4 02-22-2005 05:12 PM
