Old 02-09-2009, 02:22 PM   #1
jungleman
Member#: 147022
Default Replacing Spark Plugs - What else Compliments Spark Plug replacements? FIlters?
Im having my mechanic do some work on the 02 wrx and while im at it, at 102k miles, thinking abotu replacing spark plugs, even though they were replaced at 68k. Is it worth bothering to do so? So i wont have to go back to it in the future since my guy is gonna be in the hood deep anyways.
Im planning to run down my wrx til it completely dies on me,hopefully to at least 150k. haha. Are there any other parts to replace that'll compliment the spark plug replacement? I was told filters.. but what kinda filters? air? fuel filter?
jungleman is offline   Reply With Quote
Old 02-09-2009, 02:27 PM   #2
Feign
Member#: 68604
06 STi
Have you done the timing belt and associated bad pullies/idlers, and the tensioner? Thermostat too.
Feign is offline   Reply With Quote
Old 02-09-2009, 04:45 PM   #3
leecea
Member#: 37359
2003 WRX
The only thing scheduled at 105K are the belts and an oil change.
However, at 120K you are expected to do: plugs, fuel filter, air filter, coolant, and brake fluid.
Not sure that they'll cut you a break on any of those if you do them at the same time as belts, so may not be worth it. I guess you could get a quote on cost now versus cost 15K miles later.
leecea is offline   Reply With Quote
Replacing Head Gasket- What Else? Ekeenan86 Newbies & FAQs 6 07-30-2009 12:32 PM
replacing headgaskets: guess what else i found (need help) topguneagle1 Pre-2002 Factory Turbo Powertrain 12 07-28-2009 09:13 PM
what else to look at replacing when doing clutch ? flywheel? yeos Transmission (AT/MT) & Driveline 4 09-24-2008 03:06 PM
After Radiator Replace Car Overheating what else possible??? Please Help wrxspdr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 24 10-23-2005 09:42 PM
Replacing glow plugs same was as Spark plugs? shogunate83 Bay Area Impreza Club Forum -- BAIC 1 11-13-2002 04:56 AM
