#1 |
Member#: 103136
I no longer have the time (or enthusiasm) to keep up with updating this list. I've included the data below. If you want to take over the list, go ahead and copy and paste the data into any spreadsheet program and format it in any way you like . Then start a new thread and I'll link to it in this thread.
The data below is arranged, in order, as follows: screen name - nasioc screen name posts - number of posts before the member posted their first failure post joined - date they joined nasioc date reported - date they reported the failure on nasioc vin - last 6-digits of VIN (production number) as reported by member build date - as reported by member miles - at failure as reported by member If something is blank, it means the info was not given. An asterisk next to the build date means the date was not given but was estimated based on other reported failures near the same VIN. The data below was last updated on 8/29/09, meaning it should cover all failure reports before 8/29/09. SEDANS Code:
gcs5656 5 04/06/06 04/27/09 500060 07/08 4540 cnation 0 06/29/09 06/29/09 50015X 19500 AshJWilliams 100+ 09/20/08 12/12/08 500277 07/08 3850 gimmersong 0 04/28/09 04/28/09 5002XX 07/08* 5970 wy09wrx 0 03/22/09 03/22/09 500406 07/08* 7534 irish44j 1000+ 10/08/08 04/02/09 5008XX 07/08 9300 rschottr 9 12/17/08 01/06/09 500XXX 07/08 610 volcomgnu 1 05/21/09 06/10/09 500XXX 07/08 8100 powells85 4 01/24/09 05/08/09 5012XX 07/08* 2847 swervyswervy 18 10/08/03 01/26/09 501493 07/08 5200 StopSweatinMe 100+ 12/30/04 05/13/09 5018XX 07/08 1517 Rexy09 0 09/09/08 08/04/09 501XXX 07/08 12000 travisma 0 03/29/09 03/29/09 501XXX 07/08 6400 ephilli2 0 08/25/09 08/26/09 502124 08/08 5303 Python96 9 11/27/08 04/28/09 502484 08/08 13198 cecilia 0 08/12/09 08/12/09 5024XX 08/08 16565 dreddin 0 01/16/09 01/17/09 5025XX 08/08 2400 blackjak 1 03/10/09 08/11/09 502XXX 08/08 6975 Phathead6669 5 01/23/09 02/21/09 502XXX 08/08 918 wrxmike09 0 04/03/09 06/14/09 502XXX 08/08 3797 portlandsubie 0 08/13/09 08/13/09 503440 08/08 9888 marleyzion2000 1 02/13/09 06/17/09 503513 08/08* 1017 patdpro 0 08/25/09 08/25/09 503536 08/08 13181 wrx rod 0 05/13/09 05/13/09 5036XX 08/08* 11900 AngelgirlWRX 0 07/17/09 07/17/09 503834 08/08 8800 davidylyl 0 01/06/09 03/25/09 503XXX 08/08 7350 farnumrl 0 04/07/09 04/07/09 503XXX 08/08 150 jcw09wrx 0 02/22/09 02/22/09 504067 08/08 1044 Aero- 50+ 12/08/08 01/19/09 504XXX 08/08 2400 popnfrresh 0 02/01/09 02/01/09 504XXX 08/08 1300 nismozx 5 08/21/05 04/02/09 504XXX 09/08 3100 michaelpharvey 1 02/16/09 02/22/09 5043XX 09/08 400 Code:
Cargowerk1 0 07/05/09 07/05/09 800093 07/08 7000 veedub0 8 10/12/08 03/05/09 800108 07/08* 6502 Mader 0 03/10/09 03/10/09 800149 07/08* 1213 BigSteiner5 40+ 12/25/08 03/15/09 800240 07/08 3200 lorencherylp 0 07/09/09 07/09/09 800415 08/08 156 CANNIBALOFDOOM 18 01/01/09 03/20/09 800419 07/08* 2245 MackeyMack 1 12/18/08 04/29/09 800469 07/08 4975 tuxcat09wrx 0 04/22/09 04/22/09 800617 07/08 5700 bagels 0 05/28/09 05/28/09 800661 07/08 4800 TuningIsLife 100+ 10/09/08 11/29/08 800693 07/08 3300 Replacement motor failed at 5941 miles Warner265 0 02/11/09 02/11/09 800791 07/08 3666 Digitalfiend 500+ 02/11/04 04/25/09 800886 07/08 8264 LeFuret 0 03/23/09 04/13/09 800XXX 07/08 3500 newrx09 0 PM 03/31/09 05/11/09 800XXX 07/08* 2113 GravityDaemon 0 04/20/09 04/20/09 801544 08/08 6194 Runnin4Him 0 09/06/08 02/16/09 801XXX 07/08 1953 TunaRider 3 01/20/09 04/30/09 8020XX 07/08 3978 canyon carver 9 11/23/08 02/01/09 802498 08/08 1500 gezemice 0 07/08/09 07/08/09 802520 08/08 1514 White_Pearl_82 0 08/13/09 08/13/09 802786 08/08 7500 andyinwi 5 04/24/08 03/27/09 802919 08/08 1861 BBMN 0 08/18/09 08/18/09 80294X 08/08 7000 bungtriple 1 02/08/09 07/22/09 802XXX 08/08 7414 fellstar 38 03/10/09 06/27/09 802XXX 08/08 4700 GunslingerRC 0 02/19/09 02/19/09 802XXX 08/08 5000 Meatfoam 16 09/05/08 01/15/09 802XXX 08/08* 2780 mono666 5 03/14/08 12/10/08 803088 08/08 877 09duffman89 0 05/15/09 06/12/09 803135 2600 SubRunner 0 02/03/09 02/03/09 803222 08/08 1900 cse 0 05/12/09 05/12/09 8032XX 08/08 9800 BIGSKYWRX 14000+ 07/01/01 05/11/09 8035XX 08/08 6550 fog hat (dad) NA NA 02/23/09 803626 08/08 8200 fog hat 1 12/02/08 01/25/09 803726 08/08 4200 EVL1 2 06/02/09 08/03/09 803970 08/08 7911 leviathan3k 0 03/24/09 04/04/09 803XXX 08/08 3629 stck4evr 0 02/02/09 02/02/09 803XXX 08/08 5800 nizzki 1 03/03/09 04/10/09 804054 08/08 3300 lightgod86 0 12/12/08 12/12/08 804170 08/08 1500 ericlfg265 0 02/12/09 02/12/09 804214 08/08 3480 RadioFlyer09 7 02/28/09 04/20/09 804411 08/08 4800 snoxracer183 3 03/25/09 04/06/09 804425 08/08* 1150 ILikeToGoFast 0 04/20/09 04/20/09 804451 08/08 1900 Penti 20 05/07/07 06/10/09 804698 08/08 2350 peglegsteve 222 04/28/09 07/22/09 8047XX 08/08 9500 bavaria1105 11 02/04/09 03/07/09 804805 08/08* 2107 nkodemus82 200+ 03/23/01 02/28/09 8048XX 08/08 7200 LEXtoWRX 25+ 08/16/08 02/09/09 804939 08/08 1400 Celly 3376 11/17/03 07/25/09 8049XX 08/08 2100 elwray 330 11/20/08 06/24/09 804XXX 08/08 7988 VVG 500+ 11/20/05 12/19/08 804XXX 08/08 150 09RexKCMO 0 08/20/09 08/20/09 805156 09/08 8400 Flipz 0 PM 05/21/09 05/21/09 8051XX 08/08 3709 NismoSkylineGTR 1000+ 08/27/05 04/28/09 8051XX 08/08 5210 Code:
@NT 100+ 04/01/09 08/26/09 08/08 09paparex 5 10/05/08 03/13/09 5300 bailey1224 0 02/23/09 02/24/09 2700 Dillon09WRX 0 12/22/08 12/23/08 2700 humby45 0 08/06/09 08/06/09 6000 RATROKT 7 09/25/08 12/16/08 2800 sforzley 0 01/09/09 01/09/09 1264 skiboysteve 2 01/05/07 12/21/08 1300 sopott 3 10/26/08 12/30/08 SR-71WRX 1000+ 12/31/02 03/14/09 5000 sub4lifee 0 08/25/09 08/02/09
#2 |
Member#: 103136
updated - added new failure (jaysuss) and added build date for Meatfoam.
#3 |
Member#: 103136
updated - added another new failure (Warner265).
#4 |
Member#: 103136
updated - added another new failure (ericlfg265).
#5 |
Member#: 151870
This list is not showing up. Can you please repost it? Thanks.
#6 |
Member#: 103136
#7 |
Member#: 193241
Vehicle:2008 WRX black as satan's a$$ |
I had my engine replaced at 8600, but I own 08 wrx. Build date is 01/08. Does it aply to your list?
#8 |
Member#: 103136
No, sorry, we've only been tracking the 09 WRX.
#9 |
Member#: 151870
Did the '08 WRX have as many engine failures as the '09 WRX or even a close number? If 28 or so '09 WRX engines have failed so far, how many '08 WRX engines would you guess have failed?
#10 |
Member#: 103136
No one has been tracking the 08 WRX, but it doesn't appear there's anywhere near as many failures (reported anyway) as the 09 WRX.
#11 |
Member#: 103136
updated - added another new failure (Runnin4Him) and also updated some verified build dates.
#12 |
Member#: 198694
Vehicle:09 WRX Satin White |
look like more hatch got engine failure more than sedan
#13 |
Member#: 103136
#14 |
Member#: 7958
Vehicle:09 GH B+ |
I'll see if I can get this guy to post his info
#15 |
Member#: 7958
Vehicle:09 GH B+ |
#16 |
Member#: 103136
updated - added another failure (joshua27) and also updated another verified build date.
#17 |
Member#: 203453
#18 |
Member#: 103136
updated - added another new failure (GunslingerRC).
#19 |
Member#: 103136
updated - added another new failure (Phathead6669).
#20 |
Member#: 192177
NESIC
Vehicle:2009 Impreza WRX black |
Kinda interesting is the fact that the majority of failures (11 out of 31, or 35.5% of the total) happened between 1001 and 2000 miles...which is when owners can finally go beyond 4000 rpms...
After that it seems to progressively fade (5 failures from 2001 to 3000 miles, 4 from 3001-4000, 3 from 4001-5000, 3 from 5001-6000, 1 from 7000-8000)... So, generally speaking, if someone passes 6000 miles without a problem, chances are they are safe. Still a long way for my 2009 Wrx sedan...Very scary... |
#21 |
Member#: 103136
updated - added another new failure (jcw09wrx).
#22 |
Member#: 203124
deleted
#23 |
Member#: 203124
Knock knock, rattle rattle....~400 miles. Build Date 9/08. VIN 5043XX. It's Sunday, so I guess I'll have to go visit the dealership tomorrow.
Add me to the list! ![]() Am I the first with a 9/08 build date? |
#24 |
Member#: 36240
Vehicle:09 WRX, 78 Malibu, 82 Chevy Beast |
#25 |
Member#: 103136
updated - add new failure (michaelpharvey).
Also removed the 6 reported failures where the owners have failed to respond to continued requests for VIN and/or build date. |
