Old 02-09-2009, 06:15 PM   #1
mtcs
Member#: 180640
2000 Drag RSTi
8.96 @ 163
Default Head gasket selection (EJ257 + Ej251 heads)
Alright....
well, the motor is coming together nicely.
I have my CP pistons, eagle rods, and ACL bearings all installed.
Here is where I cannot get a straight answer from anyone.
What Headgasket should I be running?
I have a EJ257 bottom end and Ej251 heads. A MUT i know..
The heads are built with TWE Dual springs, retainers, Delta cams and SS valves.
What are my different options?
Specs:
http://www.cardomain.com/ride/3056614
mtcs is offline   Reply With Quote
Old 02-10-2009, 12:31 AM   #2
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
OEM STi EJ257 HG's for 2.5L bores
OEM '97-'98 EJ22E HG's for 2.2L bores
OEM WRX EJ205 HG's for 2.0L bores
...but that's just me. All these are 3-layer HG's.
FuJi K is offline   Reply With Quote
Old 02-10-2009, 02:41 PM   #3
Fongers
Member#: 118239
2002 Built Wagon
Wife- 2004 Outback SE
I'd look at the thicker cometics (.051 or .060) if you are going to run 20+ psi.
Fongers is offline   Reply With Quote
FS : STi intake manifold and throttle body jcovey2.5 Engine/Power/Exhaust 173 12-05-2011 09:38 PM
FS: EJ257, Wiseco Forged Pistons, Cometic head gaskets RollingOnAll4 Engine/Power/Exhaust 9 10-12-2007 09:25 PM
Which Head Gaskets ej257 to 2001 sohc Joncas Normally Aspirated with bolt-on Forced Induction Powertrain 4 02-25-2005 01:28 AM
ej257 piston Q. and Head gasket Q. snowman4us Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 02-04-2005 02:25 PM
Which head gasket for EJ257 swap SPESHAL Subaru Conversions 6 06-02-2004 12:34 PM
