Old 02-09-2009, 08:53 PM   #1
Un0RiGiNaL
Member#: 189748
Default Another DIY Painting wheels / check out my painted tarmacs
Ive had trouble searching for DIY painting wheels in the past so im gonna make one for other people.
Tools you need :
- Sanding paper (preferably 600grit, lower grit for rough spots/rash) or a scuff pad
- 2 Cans of wheel paint (I used Duplicolor Graphite wheel coating)
- 2-3 cans of clearcoat (I used Duplicolor clearcoat)
OPTIONAL - 2 Cans of primer
- Acetone or Dishwashing liquid
- lots of time and patience
- Respirator
Estimated time: <9 hours
NOTE: It says on the cans of paint to use it in decent weather (55 degrees and up, and not too hot)
Once you have all that you can get started
STEP 1
Clean the wheels THOROUGHLY. Use acetone or dishwashing soap and clean the **** out of it.
(In the picture i didnt clean the lugnut hole but i did later)
STEP 2
Scuff the wheels up so the paint can adhere
STEP 3
Wash the wheels again (dont need to alcohol it this time)
STEP 4
Spray the wheels with the wheel coating (unless you have primer then do that first)
Do light coats instead of heavy coats.
Take your time! WEAR A RESPIRATOR
STEP 5
Let the wheels dry and then start clearcoating. Same thing as above, use light coats instead of heavy coats
I was stupid and I was in a rush so I kinda screwed up on one part of the wheel and sprayed too much clearcoat as you can see here
STEP 6
Fap uncontrollably.
STEP 7
Enjoy your end product
I was glad with the end product but if i didnt have work and i took more time it woulda came out 10 times better. I should have painted the inside too but oh well.
NOTE:
Oh and let it dry overnight. I handled it right after it was dry to touch and when i was putting it on the car i noticed the next morning scratches inside the lugnut hole
Un0RiGiNaL is offline   Reply With Quote
Old 02-09-2009, 08:56 PM   #2
EsubaruJ
Member#: 200008
03 wrx
TE72 wagon, Legacy wagon
Looks great! Nice write up. Good job.
EsubaruJ is offline   Reply With Quote
Old 02-09-2009, 09:00 PM   #3
yo6bd
Member#: 196887
2010 Corn <3'er
361WHP/444WTQ stock turbo
looks good.
yo6bd is offline   Reply With Quote
Old 02-09-2009, 10:22 PM   #4
vik_wrx
Member#: 194804
2004 VF43 WRX - sold
Nice
question: how long between coats and after the paint was applied how long did you wait before applying the clear coat?
vik_wrx is offline   Reply With Quote
Old 02-09-2009, 10:28 PM   #5
Un0RiGiNaL
Member#: 189748
10 minutes. i rushed some and waited like 5
Old 02-09-2009, 10:31 PM   #6
ARBoost
Member#: 190876
2005 STI CGM
361hp/370tq Done by Jorge
Good grief man they look sweet!
ARBoost is offline   Reply With Quote
Old 02-09-2009, 11:04 PM   #7
Mr_Snips
Member#: 152117
2012 Ford F150 ECO
Dude. you need some sort of primer.
How i did mine was...
  1. Sand the crap out of it with a fairly low count sand paper
  2. sand it again with medium grit sand paper
  3. Apply 3 coats of self etching primer
  4. apply 3-5 coats of filler primer
  5. sand with very high grit sand paper to smooth the primer
  6. spray 3-5 coats of duplicolor wheel paint
  7. spray 3-5 coats of duplicolor wheel clear
They lasted great and the only time they chipped is when they used impact wrenches on the wheels when the tires were changed. lips were perfect after mounting general grabbers and running through super deep mud.
Mr_Snips is offline   Reply With Quote
Old 02-09-2009, 11:15 PM   #8
eurospek
Member#: 96944
2005 SAAB 9-2X AERO
4eat Stage 2 Protuned
They are still gold.
. . . . . on the inside barrels.
eurospek is offline   Reply With Quote
Old 02-09-2009, 11:39 PM   #9
ADAS1223
Member#: 159853
2005 Impreza
wrb
Please elaborate and add pics for step 6.. I don't quite follow
ADAS1223 is offline   Reply With Quote
Old 02-10-2009, 02:54 AM   #10
Suby<3777
Member#: 192178
99' Impreza wagon
All red!
Also another not you might want to add to your how to is to make sure you get your wheels balanced after you paint them for believe it or not the weight of the paint will through off the balance of the wheel. Very important or you will end up with some vibrations
Suby<3777 is offline   Reply With Quote
Old 02-10-2009, 03:56 AM   #11
ohsothrowed
Member#: 162157
2003 WRX
pretty clean man, i been wanting to change my rim color
ohsothrowed is offline   Reply With Quote
Old 02-10-2009, 10:02 AM   #12
Micky
Member#: 89757
2004 Impreza STI
Black & dirty
Look like crap, you didn't finish the job!
Change the title... DIY, how to paint half your wheels...
Micky is offline   Reply With Quote
Old 02-10-2009, 10:13 AM   #13
Evo killerz
Member#: 182874
2007 wrx
WR Blue
i agree with the above comment looks rubish quick way on how to mess your rims up half a job and runs every where in the paint and you didnt even use primer or rub them down properly before paint and insides r still gold???
Evo killerz is offline   Reply With Quote
Old 02-10-2009, 10:40 AM   #14
Un0RiGiNaL
Member#: 189748
i said you can paint the inside of the wheels if you want and primer if you want. and i said when to use primer. so cry more
Old 02-10-2009, 10:46 AM   #15
pDubs
Member#: 149317
'95 BMW M3 (E36)
'05 Kawi ZX6R, '73 CB350F
They look good minus the inside still being gold, and primer is not necessary if you scuff them up good. Unless you take it down to bare metal than obviously primer is needed. They look decent though Iman.
pDubs is offline   Reply With Quote
Old 02-10-2009, 10:57 AM   #16
aveisone
Member#: 171364
2006 STi
if you wetsand the wheels it makes them much easier to clean up before paint.
you went through all the trouble of doing a diy writeup but didnt paint the whole wheel? thats just lazy. poor show.
edit: 9 hours!?!?! to prep and paint 4 wheels?!?
aveisone is offline   Reply With Quote
Old 02-10-2009, 11:02 AM   #17
Evo killerz
Member#: 182874
2007 wrx
WR Blue
Fail!!!!!
Old 02-10-2009, 11:12 AM   #18
Un0RiGiNaL
Member#: 189748
No it took me like 6 hours in a rush. but for people who want to make it nice and primer it and paint the inside etc it can take up to 9 hours
Old 02-10-2009, 11:20 AM   #19
Joshz400_03
Member#: 198844
2004 WRB STi
primer is overrated..I might powdercoat mine
Joshz400_03 is offline   Reply With Quote
Old 02-10-2009, 11:34 AM   #20
scprs
Member#: 172359
2005 STi
is your paint really brittle? mine is on my stock wheels doesnt take much to scratch em
scprs is offline   Reply With Quote
Old 02-10-2009, 11:55 AM   #21
pDubs
Member#: 149317
'95 BMW M3 (E36)
Originally Posted by Evo killerz View Post
Fail!!!!!
Originally Posted by Un0RiGiNaL View Post
if you call that a fail!! then you are an idiot. That looks sick! It obviously was a good temporary fix because the gold wheels were scratched up what not and he didn't want gold. Oh well if the inside is still gold you wouldn't be able to tell unless he showed you the pic where the clearcoat ran. He's getting them redone professionally soon this was a good diy for $30 for now.
Old 02-10-2009, 12:43 PM   #22
Evo killerz
Member#: 182874
2007 wrx
WR Blue
em no when u see car in person ur gona see all bad spots and the gold is goin to stick out like sore thumb shoulda just took them to a pro and got them done properly
Old 02-10-2009, 01:21 PM   #23
ADAS1223
Member#: 159853
2005 Impreza
wrb
shut your face now. no one is going to notice it on his car unless its you hunched over with a flashlight. enough of these whiners on nasioc!
Old 02-10-2009, 01:42 PM   #24
vik_wrx
Member#: 194804
Came out great man , nice job!
Old 02-10-2009, 02:43 PM   #25
pDubs
Member#: 149317
'95 BMW M3 (E36)
Your right because you have seen it in person and I haven't . You can barely tell at all unless you bend down and look to see. I live 4 minutes away from him and saw it today in fact.
Check out my two-toned WRX my friend and I painted this weekend fastlanerex Member's Car Gallery 207 05-03-2008 06:53 PM
Check out my new body kit and paint job! mrmcderm Member's Car Gallery 27 06-07-2005 05:41 PM
Check out my fresh painted suby! TRU_V8_KILLER Bay Area Impreza Club Forum -- BAIC 5 12-28-2004 02:33 PM
Check out my newly painted 93 IMpreza Kranium31 Member's Car Gallery 3 09-30-2002 01:18 AM
Check out my ghetto paint job! I painted the car in my garage yesterday... Sean Interior & Exterior Modification 26 09-07-2002 10:27 PM
