Vancouver Impreza Club
Old 02-10-2009, 01:52 AM   #1
Wrgb
Member#: 169096
2000 Impreza 2.5RS
Blue Ridge Pearl
Default Rims, Sizing, Rubbing, Weight and Whatnot
So basically i have come to the conclusion that buying rims is Really not any Fun... So im ranting.
Even thought i have a totally stock GC and am just looking for 17" rims, im getting mildly fed up.
There are so many constraints and things i dont know about.
-Offset +48,+53 (and whatever other random offsets there are, and what will be good?)
-Width 7", 7.5" ? what will rub, what wont?
-205/215/225 width tires?
-how does this change depending on 50/45/40 high sidewalls?
-Rolling fenders? what is this? how expensive? does it need to be done?
-Not to mention the differences in weight and "strength"
Ive spent many hours on RS25.com, and basically just gotten much more confused!
Can anyone clear this up?
Goal: I want to have a separate set of 17" rims for summer, and i dont want to damage my car or rims/tires.
Wrgb is offline   Reply With Quote
Old 02-10-2009, 01:57 AM   #2
007WRX
Member#: 125884
06 Evo IX MR Black
76 Datsun ZZZZZZZ
Racing use or just daily wheels?
Price range?
007WRX is offline   Reply With Quote
Old 02-10-2009, 02:03 AM   #3
Wrgb
Member#: 169096
2000 Impreza 2.5RS
Blue Ridge Pearl
-Daily wheels only
-Looking to get used
-Hoping for around 450-700$ Including some semi worn tires
Money is really tight, but i have to get something as i only have winters right now,
so instead of paying to mount/remount 16's, i might as well pay the money and buy a 2nd set of rims.
Ultimately would love to be able to powdercoat/paint 17" rims gold, but i dont know where/how much that would cost to get done well.
Old 02-10-2009, 02:03 AM   #4
KiraFayt
Member#: 161457
2004 WRX
Good post, I am going to be purchasing a set of 04 BBS with 215/45 soon.
KiraFayt is offline   Reply With Quote
Old 02-10-2009, 02:09 AM   #5
007WRX
Member#: 125884
06 Evo IX MR Black
76 Datsun ZZZZZZZ
Originally Posted by Wrgb View Post
-Daily wheels only
It's pretty slim pickings with that budget, especially with tires.
You'll want to go max 17x8 with a 225 tire around 48 offset, depending on ride height. Anything bigger than that and you are going to run into trouble. Your best bet is to look in the private classifieds(not VIC), might get lucky, there are good deals on rotas every now and then.
Some prodrives: http://forums.nasioc.com/forums/show....php?t=1691741
Some rotas: http://forums.nasioc.com/forums/show....php?t=1693895
Old 02-10-2009, 02:11 AM   #6
Splinter
Member#: 106510
98 Widebody 2.2
Smooth Safety Blue
Buy my chipped team dynamics 17s :P
Splinter is offline   Reply With Quote
Old 02-10-2009, 03:28 AM   #7
tryallzee
Member#: 179947
'04 WRX Wagon
97' Integra
Ask hypa about rolling fenders his the **** !!
It only needs to be done if you go wider rims which looks sexy !!
About the tires and rims ... I feel your pain on that it is confusing .
Good luck with your search !
tryallzee is offline   Reply With Quote
Old 02-10-2009, 03:42 AM   #8
Loomin
Member#: 118113
98 Brights!
heres a suggestion.... rather than trying to figure out all this for yourself.... just find somone whos got 17's on their car. copy their size and offset as well as tire size and just buy that size in whatever brand/style you like.... take the guess work out of the whole process.
48 offset will make them stick out 5mm more than stock which is fine. i doubt it will rub.
17x7.5 will work. 17x8 might work too depending on your ride height. wider= better IMO but if youre too low it might rub.
if its going on a GC id stick with 215/45R17's or 225/40R17's max
rolling fenders is only necessary if your stepping away from normal sizing and trying to fit something a bit more agressive on your car. for example: you want to fit 17x8.5 +44 with 235's, youll need to roll. or you want to lower it ALOT for some reason, even with a milder size. if you want to tuck, youll need to roll. but why though?
and weight vs. strength is personal choice. you can have both but be prepared to fork out mad coin $$. if you want light + strong you need forged and your looking at volk or advan or something. your also doubling or even tripiling your budget.
if your not racing your car forged isnt necessary. unless you want the baller look of advan or volk etc.
IMO, get a set that fits the budget, fits the car, and looks nice. and dont worry about the weight unless your tracking or seriously auto-x'ing.
How low is your car? and what style are you into? JDM wheels? agressive look? rally style? race wheels? "tuner" style?
Loomin is offline   Reply With Quote
Old 02-10-2009, 12:04 PM   #9
tora
Member#: 5851
09 Forester XT
+ NA Miata
Your best bet for fit is -
17x7 with a 48-53 offset (48 sticking out 5mm more).
215/40 or 45 tires.
tora is offline   Reply With Quote
Old 02-10-2009, 12:22 PM   #10
Drakar
Member#: 68402
2000 Impreza RS
Silverthorn Metallic
offset is usually a concern for the different brakes, you need 53 for brembo's a 52 for regular 4 pots if your stock 55 works as well.
and as many said, look at what others are running and copy it, I would say most common on GC's is 17x7 and 17x7.5 with a 215/45/17 rubber.
something in the 48-53 range like said. this way if you did go to 4pots you don't have to worry about spacers.
Drakar is offline   Reply With Quote
Old 02-10-2009, 12:49 PM   #11
steve
Member#: 4718
~ too
many to list
that's going to work okay for the gc chassis.
I did a roll on a friend's gc, and he was able to fit 225's, although he still rubs a bit.
Those cars have tiny fender wells.
steve is offline   Reply With Quote
Old 02-10-2009, 01:01 PM   #12
Drakar
Member#: 68402
2000 Impreza RS
yup had a GC and the lack of space for big tires frustrated me, so I moved up (among other things for making the change) course now I look at the 08+ and their 285+ under stock fenders and wonder again
Old 02-10-2009, 01:02 PM   #13
steve
Member#: 4718
~ too
many to list
The 08'+ has some serious room for wide, fat tires and wheels.
I'm always impressed when someone fits a 9.5" wide wheel with 265's, and doesn't have to do anything more than a simple roll.
Impressed, and jealous.
Old 02-10-2009, 01:11 PM   #14
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
Even 215/45R17 rubs in the rear the minute the car is lowered - I wasn't sure whether it was rubbing against the fender or the strut. For your reference, I had the original 17x7.5 SSR Comp which are +50 and runs Goodyear F1 GS-D3 215/45R17. Definitely require fender work if you go 225/45R17 don't know about 225/40R17 but it would have been quite a bit shorter than stock 205/55R16.
kgb is offline   Reply With Quote
Old 02-10-2009, 01:32 PM   #15
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
Personally, I think that unless you go crazy with fender work so you can go another size or 2 wider, going 225 is more trouble than is worth for the 10mm gain in width. Now granted the P1 run 225/35R18 on either P1 spring+STi strut or WR setup, you're not looking for 18s and running 35s around town is just plain stiff. See if you can find some used OZ Superleggera (the P1 rims) - those are 17x7 +48. As for caliper fitment, offset only tells part of the story - you really need a rim template to be sure. Don't know what the 17" Legacy/WRX stock rims are like but that's another option (besides some 04 STi BBS). I believe the 4 pots are probably thicker than STi Brembos but I haven't done measurements
Old 02-10-2009, 05:14 PM   #16
dtt1167
Member#: 190676
2008 WRX Hatch
World Rally Blue
I'm going to go through the same questions in a while here, I know that stock the 08 is 17x7 55 offset, but finding something in a size that is close or matching is extremely hard (well too look good)
dtt1167 is offline   Reply With Quote
Old 02-10-2009, 05:29 PM   #17
Wrgb
Member#: 169096
2000 Impreza 2.5RS
Blue Ridge Pearl
yah, there is just so much to consider.
ideally i would spend the extra money and get some 04 Sti BBS rims, but i dont see anyone looking to sell them, and i dont know whats required to make them fit properly.
So yah... just weighing out all my options, i still got some time before i need to take my Winters off.
How hard is it to roll fenders? expensive? How much to powdercoat rims?
Old 02-10-2009, 05:39 PM   #18
007WRX
Member#: 125884
06 Evo IX MR Black
76 Datsun ZZZZZZZ
You still haven't answered what suspension you are on, ride height etc.
Old 02-10-2009, 05:50 PM   #19
007WRX
Member#: 125884
06 Evo IX MR Black
76 Datsun ZZZZZZZ
Trevor, there are a TON of threads on here about fitments and the 08wrx models(non-STI). Even look in the members car gallery, http://forums.nasioc.com/forums/show....php?t=1415491
If you like someones setup, pm them and ask them for details on tire size, rim size, offset and even alignment specs(especially for the wider tire sizes)
Old 02-10-2009, 05:56 PM   #20
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
Sounds like the OP is still on stock suspension and ride height - 215/45R17 no problem on the right wheels (I say find some 17x7.5 wheels ahead of 17x7), 225/45R17 is a tight fit as it stands and it will be worse when lowered. Rolling the fender is different than pulling fender - rolling the fender will only push in that tiny bit of fender lip while pulling fender is usually serious business to be done right
Old 02-10-2009, 06:19 PM   #21
Wrgb
Member#: 169096
2000 Impreza 2.5RS
Blue Ridge Pearl
Wont that make things wider? and therefore more likely to rub?
215/45R17
This seems to be general consensus on the perfect tire size for 17's, so i have figured out tire size
Old 02-10-2009, 06:58 PM   #22
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
17x7.5 makes the tires more square (ie, stretch the sidewalls straight)
Old 02-10-2009, 07:55 PM   #23
Splinter
Member#: 106510
98 Widebody 2.2
Smooth Safety Blue
I've never run anything but 225s on my 98 RS with no problems, no rubbing.
Old 02-10-2009, 10:46 PM   #24
steve
Member#: 4718
~ too
many to list
How about instead of posting those pretty pictures, that maybe you could spit out the offset you're running, along with your camber settings, and the type of tire. Then we'll know the whole story.
Hell, I could fit 295's on my car..... if I ran a lifted suspension.
Old 02-10-2009, 11:18 PM   #25
Spy
Member#: 60062
2000 Impreza 2.5RS
2009 Norco Team DH
depends how low u are..
james and I once put his wheels on my car, and well.. 225/45/17..(i believe a +53) and it was rubbing without anyone in the car.. got worse when i drove it (turning wasnt much of an option either)
i run 215/45/17 with rolled rears with +53mm, and its fine now.. front still rubs every now and again (bumps and stuff)
Spy is offline   Reply With Quote
Sticky for Rim sizes and tire sizes? TomsSound Brakes, Steering & Suspension 8 02-01-2012 09:30 PM
Ej22ss and a tranny and whatnot Doncolberto530 1993 - 2001 Impreza Specific Parts 7 04-05-2010 08:51 PM
weight and size Jkonquer Tire & Wheel 2 03-19-2006 06:09 PM
will sti springs and after market rims cause rubbing? littleblue Brakes, Steering & Suspension 5 07-24-2001 04:15 PM
Community Awareness, Philantropy and whatnot Akirasoft General Forum Archive 2 02-05-2001 09:10 AM
Message Board Statistics All times are GMT -4. The time now is 09:46 AM.
