Old 02-10-2009, 04:58 PM   #1
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
Default only 6psi? i had 12...
well i drove my car... and desided to go WOT.... i was in 2nd... at 3K RPMs... stomped on it... and got up to 5.5k.... and my boost held at 6psi... so i thought maybe i should go higher in Rpms... 2nd again.. starting at 3k... WOT...got up to 6k... and still boost only at 6psi...
it usually pulls Harder and harder... but once it it 6psi... it kinda leveled out... pulled slightly...
and insight?
i was thinking maybe waste gate was opening too early...
BTW its ej20g... 94 wrx. only exhaust...td05.. . and lil intake... it used to pull hard.... but idk.. ill try it again... on the highway..
azn0boi04 is offline   Reply With Quote
Old 02-10-2009, 05:21 PM   #2
subaruwrx
Member#: 1818
03 1996 Impreza Wa
Soon to be a v3 STI
any CEL?
subaruwrx is offline   Reply With Quote
Old 02-10-2009, 05:23 PM   #3
lapointe11
Member#: 175232
2005 WRX
CGM
Do you have the restrictor pill in the right line? I had the same problem and thats what fixed it for me. I dunno if this will help or not. But something to try.
lapointe11 is offline   Reply With Quote
Old 02-10-2009, 10:42 PM   #4
blkgm8
Member#: 184543
JDM RHD STI
GM8 Type-R
You might have a boost leak... You shouldnt be seeing 6psi of boost. Any more info... do you have a front mount? Are you hearing any whistling noise then the turbo spools?
blkgm8 is offline   Reply With Quote
Old 02-10-2009, 11:37 PM   #5
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
well i drove it again and everything is fine... idk why... i did the SAME exact thing... pulled to 6k... and it went to 12psi... i smiled. and did it again to double check... and it worked again... idk what was wrong with it... i got really worried...
but so far everything works now... idk...
Old 02-11-2009, 01:23 AM   #6
blkgm8
Member#: 184543
JDM RHD STI
GM8 Type-R
That is pretty spooky... Good luck with the car.
Old 02-15-2009, 03:54 PM   #7
sniper512
Member#: 189923
1993 JDM WRX
Limp Mode. My car was doing that as well when it wasn't running good. The car won't boost over 5-6psi. Happened also when I unhooked my O2 sensor. After a bit of driving or resetting the ECU the car started hitting full boost again. You may have an issue that caused it or were you possibly working on the car while it was running eg unplugging sensors or anything like that before you drove it?
sniper512 is offline   Reply With Quote
Old 02-17-2009, 01:14 PM   #8
kingsubi
Member#: 19239
As above. I get this sometimes when I get crappy gas and the car detects to much knock or becomes too lean. Turn the car off/on to reset it or after a bit of driving (10-15minutes) it resets.
kingsubi is offline   Reply With Quote
SOLD FS Waltham, MA: Thule Roof Rack + Bike Carriers 08+ Impreza, Pickup Only bcarm NESIC Private Classifieds 12 06-09-2010 04:50 PM
Only if I had 21K wrx_dad Texas Impreza Club Forum -- TXIC 2 09-19-2007 11:50 PM
Arg the past 12 hours have had teh suck. LinuxGuy New England Impreza Club Forum -- NESIC 1 08-12-2003 10:31 AM
Whats the difference between 6psi and 6psi? Midwayman Engine Management & Tuning 2 01-03-2003 10:31 AM
Just had a 12 round fight with an oil filter OwlBoogie Bay Area Impreza Club Forum -- BAIC 21 10-11-2002 06:09 PM
Message Board Statistics All times are GMT -4. The time now is 06:03 AM.
