Old 12-01-2012, 09:28 PM   #4176
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
Originally Posted by Hurley959 View Post
Looks low! I like it. How much bump are you running?
at ride height i have 4-5" of bump travel. also have some 4" air bumps that i need to install but want to put a spacer in it so its more of a 2" or 3" so i am not always hitting it. the CO is also setup for dual rate springs but those are just sitting in the back and not installed.
PARANOID56 is offline   Reply With Quote
Old 12-01-2012, 09:31 PM   #4177
Hurley959
Member#: 140767
TDi Rand Lover
KTM 450SMR
Not particularly difficult, there's just nothing fun about completely disassembling the dash.
If you find an otherwise perfect truck I'd consider it, but it's probably best to buy one that isn't in need of the fix.
Hurley959 is offline   Reply With Quote
Old 12-01-2012, 10:01 PM   #4178
PGT
Member#: 57283
2014 4.7L of TT Fury
w/ 4Matic
what is an air bump used for? more progressive version of a rubber bump stop for big hit suspension?
PGT is offline   Reply With Quote
Old 12-01-2012, 10:24 PM   #4179
Slow5oh
Member#: 70698
wait until I go
up a hill...
http://www.billavista.com/tech/Artic...ech/index.html
Advantages & Disadvantages
There are both advantages and disadvantages to running air bumps, some of which are:
Disadvantages:
  • Cost
  • Packaging - as mentioned, they take quite a bit of room vertically, and are generally more work to install than a simple rubber or poly bump.
  • Requirement for high-pressure nitrogen
  • Maintenance - more moving parts means more seals, O-rings, fluid, and wear bands to occasionally replace.
  • Size of axle contact area - because of their travel, they most often are engaged (are contacted by the axle and start to work) earlier than would be a simple lump of rubber. This means, the range of axle positions when contact initially occurs is quite large and therefore the area of the contact pads on the axle must be fairly large.
Advantages
  • Damping - Their ability to progressively damp the upward motion of the axle before a hard stop is unequaled by other styles of bump stop.
  • Adjustability - Easily adjusted for different lengths of travel, as described above.
  • Tunability - With the ability to tune valving, travel, nitrogen pressure, and to a limited degree even fluid volume and fluid viscosity, their function and manners can be tuned in a way that a lump of rubber or polyurethane cannot. If you use a rubber or poly bump, its rate or stiffness is what it is and if it's too harsh or too soft - there's not much you can do about it.
  • Ruggedness - Because they damp the axle by heating the fluid (kinetic energy transformed to heat energy), they can do so reliably and consistently for many thousands of cycles and with little wear and tear. Conversely, a traditional rubber or poly bump stop relies on plastic deformation to damp the axle, as it works its structure is continuously deformed and this results in wear and tear - eventually they chunk or tear and fall apart.
  • Bling - If it's your thing, there's no denying the curb appeal of high-tech machined aluminum air bumps compared to a chunk of rubber.
If you're racing (many hundreds or thousands of bumps in a single event), and / or needing to progressively damp and cushion the up-travel of long-travel suspension to a full stop then air bumps are almost a must. If, on the other hand, you spend all day slowly crawling around trails and rocks, then they probably won't do that much for you and simple rubber bump stop may suffice. If your use falls somewhere in between (eg. you like to occasionally rip around over the rough stuff) then you will have to make your own decision based on needs and budget.
Slow5oh is offline   Reply With Quote
Old 12-01-2012, 10:57 PM   #4180
PGT
Member#: 57283
w/ 4Matic
thanks
Old 12-01-2012, 11:34 PM   #4181
PARANOID56
Member#: 22035
2003 Brocoma DCab
yea more for when i am being dumb and end up in the air. got them for cheap so figured why not.
Old 12-03-2012, 09:12 PM   #4182
Sideshowbob
Member#: 50304
97 TJ Wheeler
12' TSX Wagon
Originally Posted by Whitford View Post
Do these help? Bump stops are metal and about 2-2.5".
1.
2.
3.
And in case you missed it, here is the kit I was planning on installing:
http://dpgoffroad.com/products/old-m...-wrangler-kit/
It would be that, with 35's and the Highline Kit (and new wheels, even though I hate to not be able to use my white steelies). If I get cold feet financially I can do the suspension, 33's and retain my wheels.
What do you think?
Thanks, man.
You need to figure out what trackbar that is. It looks like it may clear. That steering is stock, and if you ever plan on going offroad needs to be replaced. with 35's that steering is really being pushed. Good news is that setup is working now, so it should work with lower lifts regardless of tire size.
There is an issue in TJ's wherein you run into contact and spacial issues especially when flexed and turning. You basically want this if you are lower than 3.5" of suspension lift, want to wheel, and not on tons/histeer aka hardcore setup-
Factory profile diff cover with lower protection (narrow)
JKS later gen or Currie trackbar that has bends to avoid issue
Adjustable front control arms upper and lower
Steering- savvy/currie setup
There is a really long thread here-
http://www.jeepforum.com/forum/f9/tj...it-fit-738948/
My goal is OME springs, 1" BS only and eventually longer shocks.
Sideshowbob is offline   Reply With Quote
Old 12-03-2012, 09:15 PM   #4183
dvrmstrng
Member#: 274717
2011 WRX TP Stg2+
Are non-offroad Jeeps appreciated and welcomed in this thread?
dvrmstrng is offline   Reply With Quote
Old 12-03-2012, 09:17 PM   #4184
express_wagon
Member#: 68346
2001 M5
2013 Abarth Cabrio
Pix or ban
express_wagon is offline   Reply With Quote
Old 12-03-2012, 09:18 PM   #4185
dvrmstrng
Member#: 274717
2011 WRX TP Stg2+
426 Stroker, Vortech V2 blower, Kooks headers, Borla catback, 100lb injectors, yadda yadda.
Old 12-03-2012, 09:25 PM   #4186
PGT
Member#: 57283
w/ 4Matic
that must be slow
Old 12-03-2012, 09:27 PM   #4187
dvrmstrng
Member#: 274717
2011 WRX TP Stg2+
Where in MAIC are you ^^^ ?
Yeah it's a real slouch.
Old 12-03-2012, 09:27 PM   #4188
skywaffles
Member#: 82470
I am more humble
than you can understand.
100lb injectors? Why would you add an extra 800 pounds to an already heavy vehicle?
skywaffles is offline   Reply With Quote
Old 12-03-2012, 09:28 PM   #4189
PGT
Member#: 57283
w/ 4Matic
NoVA
Old 12-03-2012, 09:29 PM   #4190
dvrmstrng
Member#: 274717
2011 WRX TP Stg2+
I know right? Not to mention I'm a bit overweight myself.
Old 12-03-2012, 09:57 PM   #4191
GDB FAN
Member#: 105814
Needs more stance, bro.
GDB FAN is offline   Reply With Quote
Old 12-04-2012, 11:38 AM   #4192
The Phenx
Member#: 95823
2003 Imprezza Wrx
WRC BLUE
Nah needs a little wheel gap. Whats it get for gas milage.. 2?
The Phenx is offline   Reply With Quote
Old 12-04-2012, 11:42 AM   #4193
dvrmstrng
Member#: 274717
2011 WRX TP Stg2+
Your close.
Old 12-04-2012, 11:45 AM   #4194
The Phenx
Member#: 95823
2003 Imprezza Wrx
WRC BLUE
Your close.
I figured. You have to be in the 700HP range with that setup.
Old 12-04-2012, 12:16 PM   #4195
dvrmstrng
Member#: 274717
2011 WRX TP Stg2+
Yup..haven't dyno'd yet but from what other people are running probably low 700's at the wheels.
Old 12-04-2012, 12:28 PM   #4196
K Dub
Member#: 210438
2012 Jeepfiniti
G37X Rubicon
What trans you running?
K Dub is offline   Reply With Quote
Old 12-04-2012, 01:28 PM   #4197
dvrmstrng
Member#: 274717
2011 WRX TP Stg2+
stock...
Old 12-04-2012, 01:45 PM   #4198
ventral
Member#: 53238
stock...
you mean,
Jealousy aside, I wish the wife would have let me pick up the SRT8 that was available when we got our V6.
ventral is offline   Reply With Quote
Old 12-05-2012, 11:20 AM   #4199
The Phenx
Member#: 95823
2003 Imprezza Wrx
WRC BLUE
LOL you use the same dyno I do...
I got tired of people asking so I finally ran my wrx and then everyone told me it was impossible so I gave up. 260whp on a TD04... HAX I CRIES HAX!!!
Now I just say its fast.
LOL
Old 12-05-2012, 12:04 PM   #4200
dvrmstrng
Member#: 274717
2011 WRX TP Stg2+
Originally Posted by ventral View Post
you mean,
They are pretty stout transmissions and I don't beat on it....when it goes, it goes.
LOL
Exactly...Usually telling them it's "scary" fast sets the record straight. And in a car that weighs over 4000lbs it is scary.
with all the gay and straight threads [27] Off-Topic 27 05-08-2013 06:31 PM
the Official Rally/Off-Road thread? Longitude Member's Car Gallery 178 09-05-2006 05:39 PM
Why all the bestiality and dehydration threads today??? Grap Off-Topic 15 01-11-2006 03:55 PM
this site is dwindling (aka: The piss and moan thread v.2) stevedood Bay Area Impreza Club Forum -- BAIC 59 04-01-2004 12:38 AM
A lazy monday thread...A continuation of the saturday and sunday thread DoctorNick Mid West Subaru Owners Club Forum -- MWSOC 9 09-10-2002 08:17 AM
