Welcome to the North American Subaru Impreza Owners Club Monday August 3, 2015
Old 12-05-2012, 12:17 PM   #4201
K Dub
Member#: 210438
2012 Jeepfiniti
G37X Rubicon
Originally Posted by ventral View Post
Jealousy aside, I wish the wife would have let me pick up the SRT8 that was available when we got our V6.
Would be a very fun toy. I will say this though.
My dad had one. I was doing axle swaps on my XJ so my daily driver it was out of commission for a week or two as I got that done. I borrowed the SRT WK during that time. After driving it every day for a week+, I just wanted my XJ back. And not because of gas mileage, either.
K Dub is offline   Reply With Quote
Old 12-05-2012, 05:01 PM   #4202
TurismoLou
Member#: 9480
2011 Wrangler Unlim.
Anti-hybrid
Ordered my Ace stubby front bumper.
TurismoLou is offline   Reply With Quote
Old 12-05-2012, 06:17 PM   #4203
soslow
Member#: 95027
'13 BRZed
pretend racecar
Well I may have found a 2000 Jeep Grand Cherokee Laredo 4.0 4wd for ~$1k with under 100K miles!
Coworkers boyfriend had the emergency brake stick, didn't feel like dealing with it (2nd vehicle) and parked it. I'm going to check it out tomorrow.
soslow is offline   Reply With Quote
Old 12-06-2012, 10:32 AM   #4204
soslow
Member#: 95027
'13 BRZed
pretend racecar
So what's the off road thread think.
It appearently does run and they're just tired of "dealing" (i.e. it's been parked for months now and they don't want to take the time to do anything) with it. If i can get the parking brake unstuck and test drive it and it seems otherwise fine I'm buying I think. How bad are the transmissions? Getting it for ~$1,000
Old 12-06-2012, 10:33 AM   #4205
MidnightSti05
Member#: 74064
ooo the trusty 4.0L
MidnightSti05 is offline   Reply With Quote
Old 12-06-2012, 10:37 AM   #4206
Joe Boxer
Member#: 63119
** Memoirs of a
Serial Bachelor**
For daily driving, the tranny should be fine (presuming it has been taken care of). You may want to do some general maintenance on it though (flush, filter, etc.).
Joe Boxer is offline   Reply With Quote
Old 12-06-2012, 10:38 AM   #4207
MidnightSti05
Member#: 74064
Is that a travel case of coolant in the back seat???
Old 12-06-2012, 10:40 AM   #4208
sureshot007
Member#: 142405
#716 G2 OBS
Anyone have any cheap suggestions on lowering my XJ?
sureshot007 is offline   Reply With Quote
Old 12-06-2012, 10:49 AM   #4209
Scooby207
Member#: 255687
11 WRX DGM
Anyone run Michelin LTX A/T 2 ?
Scooby207 is offline   Reply With Quote
Old 12-06-2012, 11:00 AM   #4210
soslow
Member#: 95027
'13 BRZed
pretend racecar
Yeah it needs some attention paid the parking brake, new tires and I figure a general tune up. It's going to be used as a second/third vehicle for going up the mountains snow days, hauling the kid etc.
I figure pick it up for 1,000, spend about 1,000-1500 on maintenance
and I'm still coming under my 3,000 mark and it'll be worth ~4k. I think it has less than 100,000 miles on it.
It is, which concerns me. But the coolant overflow was full so it doesn't leak just sitting there...
Old 12-06-2012, 11:02 AM   #4211
K Dub
Member#: 210438
2012 Jeepfiniti
G37X Rubicon
The WJ engine/transmissions are just fine. They could even be called stout and reliable.
It's everything else you have to worry about (heads cracking in that year, axles howling, blend doors if auto climate control, etc.)
Edit: I see it has the 242 T case. VERY nice.
Old 12-06-2012, 11:08 AM   #4212
soslow
Member#: 95027
'13 BRZed
pretend racecar
Howling axles and head cracking? I know the 4.0 like to blow manifold gaskets/ crack the headers but cracking the head?
Old 12-06-2012, 11:25 AM   #4213
K Dub
Member#: 210438
2012 Jeepfiniti
G37X Rubicon
Yes. Bad head casting for a few years.
If I recall correctly, 2000 is one of the affected years.
Be careful about potential overheating problems, especially if that is a jug of coolant in the back seat
Just one of a million threads on this can be found here:
http://www.jeepsunlimited.com/forums...d.php?t=391831
And about the axles: if you have the Dana 35 rear (I think all the 4.0's did), then you'll be fine. But the aluminum housing D44 found under the V8's is a disaster.
Old 12-06-2012, 11:30 AM   #4214
Hypernoodle
Member#: 12391
I did her 5 times
then 7 times, then 5 more
The head cracking is seen on 0331 head castings, between cylinders 3 and 4. The 7120 doesn't have this issue, and can accept the newer valvetrain nicely. This is why when I built my motor, I used a 7120 head on a 2000 Grand Cherokee block with 2001 valvetrain.
The axles howling... yeah. More of a Grand Cherokee problem. They liked to chew-through differentials.
Hypernoodle is offline   Reply With Quote
Old 12-06-2012, 11:31 AM   #4215
Hypernoodle
Member#: 12391
I did her 5 times
Pop the valve cover off and you'll see the casting number on the top of the head.
Old 12-06-2012, 11:33 AM   #4216
PGT
Member#: 57283
2014 4.7L of TT Fury
w/ 4Matic
2000-2001 were the bad head years IIRC. THere's also a heat soak issue on them.....the injectors need to have heat collars installed. I had an '01 XJ and had this issue.....maddening until I sorted it out (it wouldn't fire during the heat of summer if the engine was warm....cold start was fine).
PGT is offline   Reply With Quote
Old 12-06-2012, 11:57 AM   #4217
MidnightSti05
Member#: 74064
I had some heat issues with my cherokee, but that came towards 90,000 miles...then we got rid of it.
Old 12-06-2012, 12:20 PM   #4218
soslow
Member#: 95027
'13 BRZed
pretend racecar
How much does it cost to fix the if the head cracks? (in parts).
The most important thing is that it will stay running while i gather resources to fix it should it need to, I.E. non catastrophic failures. The head issue seem's like it could go both ways.
Old 12-06-2012, 12:33 PM   #4219
Hypernoodle
Member#: 12391
I did her 5 times
I picked-up mine for $40 from the local junkyard. I had to bathe it and swap the valvetrain over, but nothing too tough.
The only pain is swapping it in. It would only take me an evening, but that's because I've done this crap at least a dozen times.
Old 12-06-2012, 12:39 PM   #4220
soslow
Member#: 95027
'13 BRZed
pretend racecar
That doesn't sound terrible.
So a head that will crack and headers when the exhaust manifold cracks plus a set of injectors.. I can deal with that. (it doesn't matter if it sits broken for a few days, unless it's snowing)
Old 12-06-2012, 01:23 PM   #4221
Hypernoodle
Member#: 12391
I did her 5 times
The exhaust headers like to crack, too. I went at mine with a welder and beefed-up the welds to keep that from happening.
I'd reenforce the new exhaust header, and drop it in when doing the head. Better to do it all at once before inevitable failure.
Old 12-06-2012, 10:53 PM   #4222
atasnailspace
Member#: 176626
Thinking about a 2006 jeep liberty diesel. 60,000 miles. What says ot about these kj's?
atasnailspace is offline   Reply With Quote
Old 12-06-2012, 11:06 PM   #4223
Hypernoodle
Member#: 12391
I did her 5 times
Is it the 2.5 or 2.8? The bigger one has almost as much torque as an STi.
It's basically a fancy Cherokee without the 4.0
Old 12-07-2012, 12:58 AM   #4224
thechickencow
Member#: 16840
98 M3, '14 outback
03 ktm 640a
I've got them on my armada. I like them a lot for all around use. Quiet on the highway. Not super meaty but a bit more agressive than a standard tire. I got stuck once in 20" of heavy snow but I was one of 2 people to even make it out of my neighborhood in the morning that day (got stuck in the afternoon when it was warmer/heavier snow turning into my driveway up my hill).
I live on a dirt road and go exploring in the national forest near me on two-tracks and have no issues with them.
thechickencow is offline   Reply With Quote
Old 12-07-2012, 10:23 AM   #4225
The Phenx
Member#: 95823
2003 Imprezza Wrx
WRC BLUE
If you want an all season with light offroad capability the Goodyear Duratracs seem the be the one to beat at the moment.
The Phenx is offline   Reply With Quote
with all the gay and straight threads [27] Off-Topic 27 05-08-2013 06:31 PM
the Official Rally/Off-Road thread? Longitude Member's Car Gallery 178 09-05-2006 05:39 PM
Why all the bestiality and dehydration threads today??? Grap Off-Topic 15 01-11-2006 03:55 PM
this site is dwindling (aka: The piss and moan thread v.2) stevedood Bay Area Impreza Club Forum -- BAIC 59 04-01-2004 12:38 AM
A lazy monday thread...A continuation of the saturday and sunday thread DoctorNick Mid West Subaru Owners Club Forum -- MWSOC 9 09-10-2002 08:17 AM
