Old 10-10-2011, 09:51 AM   #1326
Sideshowbob
Member#: 50304
97 TJ Wheeler
12' TSX Wagon
Oh that's cool it's your friends business, I like their TJ DIY flatties.
Sideshowbob is offline   Reply With Quote
Old 10-10-2011, 11:04 AM   #1327
zombiekiller
Member#: 167010
Yup! When I lived in jersey I met him. He even let me borrow his truck to tow my heap home. At the time I had an xj with an lt1 in it on 37s.
zombiekiller is offline   Reply With Quote
Old 10-10-2011, 11:25 AM   #1328
Sideshowbob
Member#: 50304
97 TJ Wheeler
12' TSX Wagon
Nice can you get a nasioc discount?
Old 10-10-2011, 11:28 AM   #1329
zombiekiller
Member#: 167010
If you pm me what you're interested in ill call him for you.
Old 10-10-2011, 07:57 PM   #1330
TurismoLou
Member#: 9480
2011 Wrangler Unlim.
Anti-hybrid
So who here owns an AEV Procal?
TurismoLou is offline   Reply With Quote
Old 10-11-2011, 11:07 AM   #1331
The Phenx
Member#: 95823
2003 Imprezza Wrx
WRC BLUE
Originally Posted by zombiekiller View Post
You could also spend 700 on a welder and materials to do the same thing, then have the welder left over to make bumpers and sliders.
+1 my welder was literally the best tool I have ever bought.
But if your getting one.. make sure its a 220v unit... you wanna be able to do 1/4" single pass or its not worth it.
The Phenx is offline   Reply With Quote
Old 10-11-2011, 01:25 PM   #1332
zombiekiller
Member#: 167010
My miller 140 does 1/4 with ease.
Old 10-11-2011, 04:56 PM   #1333
HeyZeus
Member#: 199998
1983 Crapi
White with a brown fender
+1
I am interested in buying a number of parts in the next month or two from a-z for the bumper/tire carrier/etc. I am planning on building for my 1st gen 4runner.
Let me know if he is interested is swinging a deal for us, I can put together a parts list. They seem to have a good rep and the stuff I am looking for.
I am with zombiekiller, I use my cheapo Lincoln 120v MIG for most of my stuff. When I was shopping for MIG’s the 120v offerings did better with jobs that are a bit more delicate (i.e. thin metal you are trying to put as little heat into as possible). Doing a V-groove or multi pass doesn’t bother me generally, if I really need to step up I fire up the TIG or stick welder.
HeyZeus is offline   Reply With Quote
Old 10-11-2011, 05:34 PM   #1334
zombiekiller
Member#: 167010
Originally Posted by HeyZeus View Post
+1
if you guys are serious i'll get ahold of zach. His products are really great and he is a super nice guy.
I'll just let him know that some otters will be barking at him.
If I was building a frame or roll cages that needed certified, sure a 180 or 210 is where i'm at, but for axle brackets, bumpers, motor mounts - your joints are not huge. You're also not on the clock, you can take your time and go with one pass. worry more about potentially having to weld cast to mild with a mig. Use the spare change for a torch rig so you can preheat.
hell, whenever i was building jeep parts, everything got the sledge hammer test. it didnt even need to be pretty.
On the other hand, sheetmetal work - the 140 is stellar finish work, awesome. The duty cycle on miller welders is so cautiously advertised its ridiculous.
Old 10-11-2011, 05:42 PM   #1335
The Phenx
Member#: 95823
2003 Imprezza Wrx
WRC BLUE
From Millers website.
http://www.millerwelds.com/products/...p?model=M00234
Rated to Max 3/16" mild steel.
If your welding 1/4 with this unit you would need to be pre-heating, and v notching, and even then I wouldn't use it for doing suspension work. The penetration isn't sufficient or consistent enough.
Old 10-11-2011, 05:45 PM   #1336
The Phenx
Member#: 95823
2003 Imprezza Wrx
WRC BLUE
I am with zombiekiller, I use my cheapo Lincoln 120v MIG for most of my stuff. When I was shopping for MIGís the 120v offerings did better with jobs that are a bit more delicate (i.e. thin metal you are trying to put as little heat into as possible). Doing a V-groove or multi pass doesnít bother me generally, if I really need to step up I fire up the TIG or stick welder.
The 120/140 is perfect for exhaust and sheetmetal. I have one I use all the time for it.
The 180 or 210 for suspension and thick metal work, on roll cages, rock sliders, etc.
If its for welding on cast (which I try to avoid) Stick welder with nickle rod, and following some stringent procedures so you dont crack it.
Honestly a 110v welder is just sketchy sometimes, I have seen more than one weld which looked solid rip out on the trail and show almost 0 penetration.
Bumpers and rock rails sure... but suspension and cages? Your trusting your life to these components, don't skimp out.
Old 10-11-2011, 08:46 PM   #1337
zombiekiller
Member#: 167010
As I said for before, miller under rates a ton. Ill tell you what. Ill weld 2 1/4 inch pieces of steel together, if you can break my weld with a 50 lb sledge, you win.
You can even scope it or cut it in half to check penetration.
I've been welding first hobby, then pro, now hobby again for 18 years. That little millermatic is more than its advertised.
I've even done tractor repairs with one.
All it takes is a bit of patience and some skill. The duty cycle on them is far beyond what's advertised.
Old 10-12-2011, 10:06 AM   #1338
The Phenx
Member#: 95823
2003 Imprezza Wrx
WRC BLUE
LOL I believe you. I can V-notch preheat and do a nice controlled pass and get great penetration with a 110v.
But remember we are talking to folks who don't know what they are doing.
I am basing my opinions for those guys, and in IMHO for a beginning welder who wants to do some heavy duty equipment the millermatic 180 is a MUCH better choice, plus it gives you headroom for welding on 1" thick d ring blocks, making custom bumpers, etc.
Old 10-12-2011, 11:22 AM   #1339
HeyZeus
Member#: 199998
1983 Crapi
I will PM a list of things to you shortly.
Just to be clear I am not advocating doing anything stupid, but if you need to weld thicker than what your machine can do in a single or double pass proper V-grooving works great in many applications. I have a TIG/stick set up that I can punch though way thicker stuff than I do on a regular basis.
Every time I have dug into those sorts of failures there is very good reason for it. MIG welding at the amperage levels used by the 120V units has been proven in mass manufacturing. It is the individual operator/assembler/decision maker that is suspect.
Note: I would put bumpers on the safety critical list as well.
I always recommend people that donít know what they are doing to take welding classes from the local tech school.
Old 10-12-2011, 03:39 PM   #1340
The Phenx
Member#: 95823
2003 Imprezza Wrx
WRC BLUE
+1
Besides its really kinda cool, and you can pick instructors heads for dissimilar metal welding, vertical, upside down, multiple thickness... etc.
Old 10-13-2011, 12:12 PM   #1341
Sideshowbob
Member#: 50304
97 TJ Wheeler
12' TSX Wagon
I am gonna look for some today. It's been too long without knowing how to weld.
Did you ever talk to him? I would like to give him a call.
Old 10-13-2011, 01:51 PM   #1342
The Phenx
Member#: 95823
2003 Imprezza Wrx
WRC BLUE
Ya I have a guy who might want corners rockers and tube fenders for him
Old 10-13-2011, 03:53 PM   #1343
Slow5oh
Member#: 70698
wait until I go
up a hill...
Me and Damon went and did some trail riding today along a drainage ditch, it wasn't anything tough by any means but it was still fun to get outside and get dirty. Only 2 spots we went through were rough enough to warrant low range. Could have managed in high but I don't like using the skinny peddle more then I have to. I was pleasantly surprised that I didn't rub at all especially after seeing others with this big a tire needing some work. There was one spot where I thought I did but after investigating it I didn't see anywhere with fresh rub marks.
33" BF Goodrich Mud-Terrain KM2 tires and my 4Runner is an excellent combination.
Slow5oh is offline   Reply With Quote
Old 10-15-2011, 10:16 AM   #1344
Sideshowbob
Member#: 50304
97 TJ Wheeler
12' TSX Wagon
Nice 4 Runner. I miss mine to this day, still have the tags.
Old 10-15-2011, 01:18 PM   #1345
Sideshowbob
Member#: 50304
97 TJ Wheeler
12' TSX Wagon
Some final assembly and dry pics of the Medium Quartz Grey Monstaliner-
Old 10-15-2011, 01:54 PM   #1346
mannac
Member#: 161038
2005 LGT
'72 Datsun 240Z
Looks great!
mannac is offline   Reply With Quote
Old 10-17-2011, 08:51 AM   #1347
Sideshowbob
Member#: 50304
97 TJ Wheeler
12' TSX Wagon
JeepForum is doing a Superwinch giveaway....
http://www.jeepforum.com/forum/f261/...eaway-1276534/
Old 10-17-2011, 10:31 AM   #1348
The Phenx
Member#: 95823
2003 Imprezza Wrx
WRC BLUE
Coating Came out very nice!
Old 10-17-2011, 10:33 AM   #1349
Sideshowbob
Member#: 50304
97 TJ Wheeler
12' TSX Wagon
I really do love it, even after all the effort lol.
Old 10-17-2011, 10:45 AM   #1350
Sideshowbob
Member#: 50304
97 TJ Wheeler
12' TSX Wagon
Video highlights the need for tummy tuck and lockers
with all the gay and straight threads [27] Off-Topic 27 05-08-2013 06:31 PM
the Official Rally/Off-Road thread? Longitude Member's Car Gallery 178 09-05-2006 05:39 PM
Why all the bestiality and dehydration threads today??? Grap Off-Topic 15 01-11-2006 03:55 PM
this site is dwindling (aka: The piss and moan thread v.2) stevedood Bay Area Impreza Club Forum -- BAIC 59 04-01-2004 12:38 AM
A lazy monday thread...A continuation of the saturday and sunday thread DoctorNick Mid West Subaru Owners Club Forum -- MWSOC 9 09-10-2002 08:17 AM
