Old 10-26-2011, 04:17 PM   #1451
Sideshowbob
Member#: 50304
97 TJ Wheeler
12' TSX Wagon
Yeah, I mean D35 isn't the total end of the world as you could do an Ford 8.8 (from exploder) swap which is stronger than a D44. But it's certainly worth some haggling.
My D35 has taken way more abuse than the ninnies on the internet would have you believe it can.
Sideshowbob is offline   Reply With Quote
Old 10-26-2011, 04:27 PM   #1452
Whitford
Has never had a cavity
Member#: 97875
Originally Posted by zombiekiller View Post
Looks like a d35 from that angle. To be sure id need to see the cover on the pumpkin from the rear or see the vin tag.
Also ask him what the gear ratio is.
Good to know, thanks guys.
Whitford is offline   Reply With Quote
Old 10-26-2011, 04:32 PM   #1453
zombiekiller
Member#: 167010
no worries. if it is indeed a d35, do the same with the rear wheels as the front. If the tire will wiggle, there may be an issue with the axle shafts/c-clips. if thats the case its not a huge deal , but its an issue and you dont want the wheel to fall off your new jeep.
zombiekiller is offline   Reply With Quote
Old 10-26-2011, 04:40 PM   #1454
Whitford
Member#: 97875
Noted, thanks.
Old 10-27-2011, 10:57 AM   #1455
The Phenx
Member#: 95823
2003 Imprezza Wrx
WRC BLUE
In out movement is symptomatic of a c-clip issue.
Updown/frontback is wheel bearings.
If its just wiggle... check yer lug nuts lol.
Me I find a great diagnostic tool is my finger. Dip it in the gear oil... look for metal sheen, rub for grit, thats bad. Grab yoke and turn, anything more than a couple degrees of slop is unacceptable, and ANY updown front back movement is a reason to avoid the axle.
The Phenx is offline   Reply With Quote
Old 10-27-2011, 11:42 AM   #1456
eg33GC
Member#: 206851
56 Belair
Pro Street
so if i want to put some cragar soft 8s on an xj, and some tires to boot, with no or a minimal lift, what sizes should I get?
15x8?
15x10?
16x8?
what tire will fit?
/noob
eg33GC is offline   Reply With Quote
Old 10-27-2011, 11:47 AM   #1457
zombiekiller
Member#: 167010
15x8?
15x10?
16x8?
what tire will fit?
/noob
8 inch wide. 4 inches of backspacing. If the xj has its og suspension, it probably sagged. On full height stock suspension, 30s will be in with a wee bit of rubbing. 3 in lift will allow you to run 31x 1050s, but you'll need spacers with stock wheels to not rub.
Old 10-27-2011, 11:47 AM   #1458
express_wagon
Member#: 68346
2001 M5
2013 Abarth Cabrio
15x8?
15x10?
16x8?
what tire will fit?
/noob
You can fit up to a 30 with no lift without much rubbing. I don't see why you would need anything more than a 8" wide wheel really. Stay with 15s for better pricing. It also helps to say which year XJ you have.
express_wagon is offline   Reply With Quote
Old 10-27-2011, 11:49 AM   #1459
eg33GC
Member#: 206851
56 Belair
Pro Street
1999 sport2 door. the rear just started to sag, within like a matter of 2 weeks.. odd.
15x8, 4",30s. got it
Old 10-27-2011, 01:13 PM   #1460
Spootypuff
NASIOC SUPER Supporter
n00b jesus
Member#: 200000
2012 Wrangler
Shouldn't this be more than 23k? (2010 Rubicon with 15k miles)
http://www.duvalacura.com/2010-Jeep-...-FL/vd/7376034
Spootypuff is offline   Reply With Quote
Old 10-27-2011, 01:21 PM   #1461
Sideshowbob
Member#: 50304
97 TJ Wheeler
12' TSX Wagon
My friend got one for less than that with less miles.
That snorkel is a crime though. It also could mean it was "wheeled" aka mudded down there.
Also you need to make sure everything is still there. Axles, Transfer case, etc. can be swapped out for lesser parts.
Old 10-27-2011, 02:06 PM   #1462
The Phenx
Member#: 95823
2003 Imprezza Wrx
WRC BLUE
Leaf springs generally sag for 1 of two reasons...
Either over compression causing the spring to go negative arch, or "S" ing due to axle wrap... but once they start failing its a quick process.
Old 10-29-2011, 04:12 PM   #1463
PGT
Member#: 57283
2014 4.7L of TT Fury
w/ 4Matic
want
PGT is offline   Reply With Quote
Old 10-29-2011, 05:21 PM   #1464
Joe Boxer
Member#: 63119
** Memoirs of a
Serial Bachelor**
grade 8 hardware just means that you did it right.
if you're that worried about color coordination, its most likely a mall crawler and beadlocks are not necessary.
A week later...
I'm a perfectionist. I know the functionality is there, but if I can retain it and improve the aesthetics... I am going to do it. I have no qualms with the silver hardware, but if I am not satisfied with the look when all is said and done... I'm going to change it.
Having caught up on the thread... did Whitford buy the LJ? I ****ing loooooove LJ's. :drool:
Joe Boxer is offline   Reply With Quote
Old 10-29-2011, 05:23 PM   #1465
Joe Boxer
Member#: 63119
** Memoirs of a
Serial Bachelor**
Effectively $10k less than a new one. I am inclined to think it would fetch $3-4k more.
Old 10-29-2011, 05:35 PM   #1466
PGT
Member#: 57283
w/ 4Matic
dealers were dumping '11s for $7k off because of the new motor. Wonder if that has affected resale so soon. I wouldn't think so
Old 10-29-2011, 08:23 PM   #1467
techwrtr2
Member#: 105613
2007 WRX Limited
Garnet Red
Originally Posted by PGT View Post
want
I like. Somewhere I saw a concept like that but on a 3/4 ton RAM chassis. I like that too.
techwrtr2 is offline   Reply With Quote
Old 10-31-2011, 03:11 PM   #1468
brianglawson
Member#: 229468
2004 Impreza WRX STI
AEV Brute's are such a well thought out kit..... super nice conversions
brianglawson is offline   Reply With Quote
Old 10-31-2011, 03:14 PM   #1469
PGT
Member#: 57283
w/ 4Matic
as much as I love it, a lightly used 5.7L Commander is probably a better buy. Not as cool though.
Old 10-31-2011, 03:15 PM   #1470
Whitford
Member#: 97875
want
Yes indeed.
Originally Posted by Joe Boxer View Post
A week later...
Not yet, I'm going to have to wait a week or so. I hope it's still available then.
Old 10-31-2011, 03:16 PM   #1471
express_wagon
Member#: 68346
2001 M5
2013 Abarth Cabrio
Not sure if serious.
I guess they are a good buy if it's like $7k for a 3 year old one.
Old 10-31-2011, 03:22 PM   #1472
PGT
Member#: 57283
w/ 4Matic
100% serious. You can get a Limited 5.7L Hemi 4WD with less than 100k miles for <$15K. Do a 2" lift, AEV wheels and 32's and for not much spent:
Here's an AEV built Commander on 40's:
Old 10-31-2011, 03:22 PM   #1473
Whitford
Member#: 97875
What's the consensus on the Commander?
Old 10-31-2011, 03:24 PM   #1474
zombiekiller
Member#: 167010
enormous POS.
Old 10-31-2011, 03:25 PM   #1475
PGT
Member#: 57283
w/ 4Matic
keep in mind, I nearly bought this SJ for $15k earlier this month:
with all the gay and straight threads [27] Off-Topic 27 05-08-2013 06:31 PM
the Official Rally/Off-Road thread? Longitude Member's Car Gallery 178 09-05-2006 05:39 PM
Why all the bestiality and dehydration threads today??? Grap Off-Topic 15 01-11-2006 03:55 PM
this site is dwindling (aka: The piss and moan thread v.2) stevedood Bay Area Impreza Club Forum -- BAIC 59 04-01-2004 12:38 AM
A lazy monday thread...A continuation of the saturday and sunday thread DoctorNick Mid West Subaru Owners Club Forum -- MWSOC 9 09-10-2002 08:17 AM
