Old 02-11-2009, 12:11 AM   #1
chop204
Member#: 171741
2009 Civic SI
Crystal Black Pearl
Default Borla UEL Headers ?
Where is the best price online I can get a new set for my 05 RS ? I see some site's say that only fit up to 04 or 01 is that true ?
chop204 is offline   Reply With Quote
Old 02-11-2009, 12:20 AM   #2
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
They all fit. eBay is always cheapest. You need to learn to search.
Mods, can I get a locked thread in here?
Old 02-11-2009, 12:50 AM   #3
chop204
Member#: 171741
2009 Civic SI
Crystal Black Pearl
I decided to go for ebay reps since they are about 100 dollars cheaper and from what ive read the same in performance. What seller is everyone buying there replica's from ? I found about 3-4 in similar price range and wanted to know who ppl are buying from. If someone could post an ebay link that would be great thanks
Old 02-11-2009, 10:24 AM   #4
07ImprezaMB
Member#: 153861
2008 WRX hatch
WR Blue
I just purchased the newer style borla headers from boxer4racing. I was doing some research and the older borla's had a problem with cracking after a while. But the new ones they have now i have heard nothing bad about, all good things. So i went with them........ look it up and see how many people have had to replace their replicas. Just some info i gathered. But i have had my full exhaust (borla header, stromung high flow cat w/ pipe, and apex'i n1 catback) for a couple months and i am very pleased.
07ImprezaMB is offline   Reply With Quote
Old 02-11-2009, 10:36 AM   #5
chop204
Member#: 171741
2009 Civic SI
Crystal Black Pearl
yea I have the money to get the real borla's so Im gonna go for it prob order from boxer4racing too. With the warrannty too it gives me a peace of mind if they do crack they can be replaced. Thanks your your help
Old 02-11-2009, 10:41 AM   #6
07ImprezaMB
Member#: 153861
2008 WRX hatch
WR Blue
Lightbulb
If your trying to do full exhaust, its a bit pricing, but do the same set up as me. You can feel the power gain the first time you drive it. Not sure what the numbers are as far as hp and torque but i know its pulling a heck of alot harder. Plus the sound is just sexy. You get that wrx deep boosted prrrrrrr. check this video out...... youll see what i mean.
http://www.youtube.com/watch?v=_WY1_...e=channel_page
also for full step by step instructions on how to instal check this link:
http://forums.nasioc.com/forums/show...ght=uel+header
Old 02-11-2009, 11:10 AM   #7
06demon
Member#: 151398
^^^wow your car sounds really good
06demon is offline   Reply With Quote
Old 02-11-2009, 01:19 PM   #8
ttatsumi
Member#: 85763
One more thing...
don't make the mistake i made when i installed mine...Make sure you buy exhaust wrap 50'x2" (I bought DEI) and wrap the header then spray it with high temp silicone paint before installing. Unlike the OEM header, it does not trap exhaust heat which are done by heatshield on OEM ones. If you install it bare, you will get a CEL (gas cools down too quick to fire up the catalytic converter) and eventually you'd have to take it off and wrap it then reinstall, unless you want to eliminate CEL permanently or drive around with CEL. I live in NY and it won't pass state inspection unless you fix this problem. I should've done it right the first time. But I'm happy with the result. It gives deeper sound and let's the exhaust flow better.
The only con I've read was that it makes the increases rust/corrosion of the header when it traps salt in winter time. But it will save you time and stress of fixing it eventually.
Hope this helps.
ttatsumi is offline   Reply With Quote
Old 02-12-2009, 02:04 AM   #9
God
Member#: 148482
2085 CRYSMORE
LE BARON
umm... buy an ebay one if you want to deal with cracked header on a monthly basis. otherwise buy a borla one and deal with cracked header on a monthly basis.
in other words, they will crack. a lot. be ready to take your header off all the time.
God is offline   Reply With Quote
WTT Stromung NA Catback/Borla UEL Headers for Stock Catback/Headers Plus Cash chop204 Engine/Power/Exhaust 14 04-05-2010 11:46 AM
Borla UEL headers for cheaper? SUBYAWD85 Normally Aspirated Powertrain 30 03-24-2010 11:35 AM
OEM vs Borla UEL header - acoustics Bluefoton Normally Aspirated Powertrain 60 02-11-2010 06:12 PM
Borla UEL Headers. Unknown Divorced DP. Immaculate! ChronoX720 Engine/Power/Exhaust 46 04-18-2009 11:55 AM
NJ: GC jet-hot coated borla UEL headers and stock headers M E R C U R Y Tri-State Area Private Classifieds 1 05-12-2008 01:58 PM
