Old 02-11-2009, 01:38 AM   #1
fourage20
Member#: 136149
2002 WRX EJ207
Default 08 legacy key fob in a bugeye
ok so i read the all you need to know thread about the key fobs but its not all i need to know.
i wanna know if the 2008 legacy key with the built in remote work on a bugeye. if so how do i program the remote to my car? if it doesnt work what do i need to get to get it to work?
also the bugeyes do not have imobilizers. what do i need to do if i want to put that option in my car?
fourage20 is offline   Reply With Quote
Old 02-11-2009, 10:39 AM   #2
fourage20
Member#: 136149
2002 WRX EJ207
anyone?
Old 02-11-2009, 10:58 AM   #3
JavaBot
Member#: 156723
99rs Silver
rip javabot <3
Subscribed... I want the trunk pop too. GL keep us posted.
JavaBot is offline   Reply With Quote
Old 02-11-2009, 11:30 AM   #4
ozzy370
Member#: 162469
2003 WRX wagon
special sauce
I imagine that this feat will be quite hard to accomplish and quite expensive.
The dealer programs and reprograms any FOBs that have the immobilizer.
ozzy370 is offline   Reply With Quote
Old 02-11-2009, 11:38 AM   #5
fourage20
Member#: 136149
2002 WRX EJ207
well my car doesnt have an imobilizer. its a 02 wrx. id like to have that feature also but im more concerned about programing the remote to my car.
Old 02-11-2009, 11:47 AM   #6
Uncanny
Member#: 133012
2011 WRX
Obsidian Black Pearl
Programming of the remote can be done, i believe they use the same frequency set.
Adding an immobilizer is nearly impossible, your ECU wont support it.
Trunk pop is impossible, the factory keyless module can't support it, PLUS you'd have to add an actuator to put on the trunk release cable
Uncanny is offline   Reply With Quote
Old 02-11-2009, 07:45 PM   #7
fourage20
Member#: 136149
2002 WRX EJ207
it can be done. it will be done. im gonna get a viper alarm that has remote start and alarm with trunk popping option. the alarm will work with the factory remote.
how do i program the new remote? it has to be different than the 02 remote. its not the tear drop remote either its built into the key.
Old 02-11-2009, 09:53 PM   #8
Uncanny
Member#: 133012
2011 WRX
You can't program the factory remote to work with an aftermarket alarm or remote start. Those units use trigger wires to be controlled by things other than the keyfob for the unit.
If there IS NO OUTPUT from the factory keyless module for a trunk release, then there IS NO WAY to use the factory style keyfob for trunk release. and you STILL need an actuator to run inline on the trunk release wire.
If you think I'm wrong, try it, but I'm a professional and I've been doing this for a while. Your theory is great, but it isn't grounded, and you have no way of execution, and you dont have a clear understanding of how a keyless entry system works in a vehicle.
Old 02-11-2009, 10:25 PM   #9
fourage20
Member#: 136149
2002 WRX EJ207
so how do i program a 08 remote to my car?
Old 02-11-2009, 10:30 PM   #10
atomicfire
Member#: 136296
2005 STi
There is an extra set of contacts on the fob to trigger the trunk release. There is also an unmarked output on the alarm module to pop the trunk. You can buy an actuator from DEI or wherever and wire it into the cable. I've seen it done before.
atomicfire is offline   Reply With Quote
Old 02-12-2009, 12:10 AM   #11
fourage20
Member#: 136149
2002 WRX EJ207
Old 02-12-2009, 01:08 AM   #12
hella_sti
Member#: 139289
2003 WRX Wagon
What if I just want the switchblade key and the lock and unlock function to work, are the key profiles the same on the new leggy keys? Where do I buy the new key/fob that will work in the flip keys?
hella_sti is offline   Reply With Quote
Old 02-12-2009, 02:39 AM   #13
fourage20
Member#: 136149
2002 WRX EJ207
thats another thing im working on. the legacy key is the same key for my wrx. so all i have to do is have it cut. but before i do that i want to program the remote. as soon as i know i can do that ill venture off into making that switchblade key (which i already have).
sooooooooo does anyone know how to program this thing?
Old 02-16-2009, 02:50 PM   #14
fourage20
Member#: 136149
2002 WRX EJ207
Bump.
Old 02-16-2009, 03:30 PM   #15
Uncanny
Member#: 133012
2011 WRX
this isn't the for sale forum, you don't need to bump things. If someone has an answer, then they will find the thread and answer.
Consult your owner's manual or a subaru technician if nobody here has a clear answer for you.
Old 02-16-2009, 11:44 PM   #16
fourage20
Member#: 136149
2002 WRX EJ207
Bump..
Old 03-01-2010, 11:41 AM   #17
Felginator
Member#: 210088
97 Outback Sport
I'm using the 09 legacy key fob in my bugeye. Just follow the regular programming instructions and it works fine. All buttons work for me except the trunk but I have a wagon anyway.
Use these instructions to program it:
Unlock all doors, foot on brake, all doors closed. Cycle key quickly but carefully on-off appr 10 times until the car honks one time.
Do not turn the key far enough to start the car, just to the 'on' position so the dashboard lights up.
When the horn honks, open and close the driver's door, press any remote button and that's it.
Program another remote? Quickly open and close the driver's door again and push a button on the 2nd remote. That's it.
When you're done, remove the key and the horn should honk 3 times. You're all set.
Sometime it takes more than 10 on-offs to set program mode. Open/close the door, lock/unlock etc, wait 10 minutes, then try again.
Felginator is offline   Reply With Quote
Bugeye ebay switchblade key fob flacopower Newbies & FAQs 4 03-01-2010 06:15 PM
1998 sub outback legacy key fob prob kekoa503 Car Audio, Video & Security 1 08-17-2009 10:16 AM
DIY 08 Key fob into switchblade key EdsWRX Interior & Exterior Modification 32 04-08-2009 01:14 AM
security system used in key fobs by Toyota, GM, VW and others hacked kevinh211 Non-Subaru News & Rumors 1 08-29-2007 07:43 PM
What key fob is in the brochure and why don't I have it? GiJoe Newbies & FAQs 12 06-01-2002 01:28 AM
Message Board Statistics All times are GMT -4. The time now is 11:24 AM.
