Old 02-11-2009, 01:49 PM   #1
SenorMcNasty28
Member#: 189104
'98 GC Impreza
Default Fuel Tank Pressure Sensor
Hey guys. A am an active member of RS25.com. I posted this question there a few nights ago but am having trouble getting responses. Since this is not really pertaining to the GC8 I figured this forum might be more suitable. I know this isn't the right section to post this question but I'm not really sure where it belongs. I'm sure a mod will move it to the appropriate location.
Hey there knowledgeable Subaru people. I am working on my swap and am trying to gather the last bits needed. The guy I bought my donor car from said he was running the car with a CEL because he never got the Fuel Pressure Sensor from an 06 WRX. I do not want to roll with a CEL so I am now looking to pick one up.
First of all what are my options? I don't feel like picking through a junkyard. Can I just order one from Subaru? Do I need a part # or will they know what sensor I need? I know the plug # which goes to the sensor but not the part # of the actual sensor.
Also do I need to install the sensor? How involved is this and where is it located? I'm guessing it's not too important if the PO didn't bother picking one up. Will simply connecting the sensor and mounting it somewhere in the car rid me of the CEL? What exactly does this sensor do?
Sorry for all the questions but I know you guys are the best people to ask.
Thanks in advance for any help.
SenorMcNasty28 is offline   Reply With Quote
Old 02-11-2009, 02:33 PM   #2
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
I have never heard of such a sensor unless it was implemented on the later models.
i_c_the_light is offline   Reply With Quote
Old 02-11-2009, 04:38 PM   #3
dryvby
Member#: 49931
0305 wrx/Xt
black/black
post your trouble code or search and then post what the translated code is
dryvby is offline   Reply With Quote
Old 02-11-2009, 07:15 PM   #4
2xhighpsi
Member#: 158089
2004 STi RomRaided
I had this CEL. F O R E V E R.
P1446 - Yours could be P1447 as well i believe.
I have an 04 STi swap with 02 tank and the sensor was not used until the tanks of 04+.
Romraider took care of that though
2xhighpsi is offline   Reply With Quote
Old 02-11-2009, 08:20 PM   #5
SenorMcNasty28
Member#: 189104
'98 GC Impreza
Ya it seems like the best option is to find someone with opensource to just override the CEL. Anyone have any ideas on how to find somebody. I live in Central MA.
Old 02-11-2009, 08:22 PM   #6
MasterKwan
Member#: 98961
2003 WRX
Romraider did? Does it affect how the car runs? I'd THIS close to swapping fuel tanks and harnesses to get that sensor and any other senser the 05 STI uses in the tank. I'm not that keen on doing the tank though (I suppose I should, to do a complete swap job)
Old 02-11-2009, 08:50 PM   #7
69subaru360
Member#: 159682
1995 WRX
2015 F150
It's just an emissions thing, doesn't affect how the car runs. I would turn the codes off. Much easier than swapping tanks.
Old 02-11-2009, 09:43 PM   #8
EvenSteven
Member#: 156542
Even my 01 RS has this sensor on it. The signals sent from it are exactly the same as the 06 STI. I checked it out. There are three wires going to it. Just splice the wires if you need to. You dont have to drop the tank for that you could just re-pin it at the connector under the rear seat. Im not sure how you have it wired or what is wrong.
Most likely it is not even your sensor at all. It could just be that you have a leak somewhere in your evaporative emissions system, or even something simple like a bad gas cap. Check that out first.
EvenSteven is offline   Reply With Quote
Old 02-11-2009, 09:48 PM   #9
SenorMcNasty28
Member#: 189104
'98 GC Impreza
I haven't actually completed the swap yet. This was just based on information given to me by the PO. I will check on Saturday when I get working on this Even.
edit: looking at the wiring diagrams, it seems that my swap car ('98 2.5RS) doesn't have the sensor like your '01.
Old 02-11-2009, 10:22 PM   #10
EvenSteven
Member#: 156542
No, i just checked that out too. The 98 RS also had the same exact signal and is also a three wires. You should be fine unless the sensor is not working. He probably didn't have the evap system connected right. There may be some differences in the evap system from 06 to 98 but i dont think it would be the pressure sensor. I think the pressure sensor was just leaving a code because the system had a leak somewhere. change the gas cap first.
Old 02-11-2009, 11:00 PM   #11
MasterKwan
Member#: 98961
2003 WRX
I'm looking at the wiring diagram for the 02 WRX and 05 STI and there are missing parts. Worse though (at least for me) is that the pinouts for the wide white connector under the rear seat that goes to the fuel tank is different. The wires aren't plumbed to the same pins on the connector.
In my case this is a problem because I'm using the STI harness. This suggests I HAVE to switch the tank harness too or re-pin the connector. If I re-pin, I'll still probably get a CEL because of the missing solenoids so, it looks like the tanks comes out.
If you use the same front harness, it's not an issue.
Old 02-11-2009, 11:36 PM   #12
EvenSteven
Member#: 156542
The WRX will have a fuel controller where as the the RS doesn't. I forgot about that. I don't know enough about it to give you info but i know that you shouldn't have to drop the tank to wire in the controller. I saw a guy on ebay that is selling all the solenoids that you need so you are in luck with that one. Ill pm you.
Old 02-12-2009, 01:08 PM   #13
nick42010
Member#: 114933
alot of
escalades
This probably won't help much but I am in the middle of my 02 WRX swap into my 01 RS and they both have the same sensors on the tank, even all of the plugs are the same.
nick42010 is offline   Reply With Quote
Fuel Tank Pressure Sensor?? pardsbane Normally Aspirated Powertrain 1 03-30-2010 06:20 PM
Fuel Tank Pressure. Kape Commercial ECU Reflashes 0 12-01-2007 08:32 PM
busted stud during fuel pump install, proper fuel tank pressure? overdose Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 09-25-2006 11:20 AM
P1400 Fuel tank pressure control solenoid valve circuit low input after utec install bozz Engine Management & Tuning 7 07-28-2004 11:47 PM
Lack of Fuel Tank Pressure mynew02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-23-2002 11:49 AM
