Old 04-07-2002, 06:04 PM   #1
Santo Domingo 2.5 RS
Member#: 5354
Silverthorn Metallic
Default Problem when filling up gas!!
I dont know whats the problem, but my car whenever i try to fill it up with gas, i can`t do it fast because the trigger on the fuel pump always comes up and stops pumping, so you cant fill it up fast, and i have to fill it up really slowly.
Santo Domingo 2.5 RS is offline   Reply With Quote
Old 04-07-2002, 07:44 PM   #2
Tkacik
Member#: 847
'06 Titan Crew Cab
'08 Forester LL Bean
I have had this happen too. Whenever you fill up your tank try only putting the nozzle part half way in, instead of having it flush against the door opening. I think that the sensor that is on the pumps nozzle gets false readings for some reason when you have it all the way in, perhaps its getting splashed? Anyways try what I said, that should solve the problem.
Tkacik is offline   Reply With Quote
Old 04-07-2002, 08:05 PM   #3
LA
Member#: 7119
2000 impreza rs
blue ridge pearl
ya i have had the same problem
LA is offline   Reply With Quote
Old 04-07-2002, 08:35 PM   #4
AJ711
Member#: 6178
98 GM67 + 03 SG6
2 whls > 4 whls
This happened to me at a random Texaco station. I was getting really ticked. So I just pulled the nozzle out 1/4 to 1/2 inch or so, and tried it again, and it worked fine. Try that and see what happens.
This doesn't happen to me often, so I'm guessing it is just that pump. It didn't happen today when I filled up, and I wasn't pressing the nozzle all the way in. Just an idea.
AJ
AJ711 is offline   Reply With Quote
Old 04-07-2002, 10:00 PM   #5
amorenite95
Member#: 15174
02 Impreza 2.5 RS
white
Yeah like everyone else said do that. That happen to me a few times. Its like it goes to deep sometimes. It works for me to raise it up a bit.
amorenite95 is offline   Reply With Quote
Old 04-07-2002, 11:19 PM   #6
Aprilia Jon
Member#: 13394
2001 GC8 Coupe
Yeah, I get that problem all the time
Aprilia Jon is offline   Reply With Quote
Old 04-08-2002, 10:44 AM   #7
Suba_Roo
Member#: 5691
2001 2.5 RS
Silverthorn
I had this problem with my car from day one. I had it back to the dealer something like 4 times. I was without my car cumulatively for 6 weeks. Before they finally fixed it, they had replaced the entire gas tank, the fuel filler tube, a bunch of smog equipment. It turns out that it had a defective "check valve" which was replaced with another defective "check valve".
Take it to a dealer and tell them to try it. The positive side is that for the dealer to test it they have to fill your car up...
Anyway, the dealership I dealt with, Carlsen in Redwood City CA was very helpful and understanding. Now every time I show up the service writer says "Oh, no, please tell me the gas tank still works."
Suba_Roo is offline   Reply With Quote
Old 04-08-2002, 11:50 AM   #8
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
its a common subaru proublem
2 of my subaurs have done it
if you have soft enought suspension rock the car as you fuel it
the air outlet line is blocked or too small
Old 04-09-2002, 01:12 PM   #9
Subie FI
Member#: 17253
2014 BMW 328i Wagon
Alpine White
Post
Suba_Roo nailed it. I also had this problem the first time I filled up the tank of my '02 OBS. First, I thought it was the gas pump. When it happened again I called my dealer (Ann Arbor Subaru). They said it could be a plug in the pressure bleed line or a faulty valve in the tank. First, they checked the lines and found no problem so they ordered me a new gas tank. Replacing the tank and check valve did the trick. Warranty replacement.
Subie FI is offline   Reply With Quote
Problem when hooking up battery globalrex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 03-05-2008 08:14 PM
Car Idling Problem When i fill up Gas wrxphantom Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 02-03-2007 07:48 PM
Engine mount problem when jacking up engine Eaglesfan2422 Service & Maintenance 3 09-03-2006 06:11 PM
having problems filling up gas tank Benjamin Tang Legacy Forum 12 01-01-2003 11:06 PM
White 00-01 RS, Black painted 6spoke stock rims, Filling up gas on Teaneck Rd Tensen Tri-State Area Forum 0 10-03-2001 12:41 AM
