Old 02-11-2009, 08:55 PM   #1
gopsu
Member#: 96448
02 WRX VF34
Default Replacing wheel bearing on 98 Outback?
I am thinking about picking up used Outback, but the seller says front wheel bearing needs replacement (as well as fuel pump). I've replaced hub assembly on Miata, but not sure what is involved in replacing wheel bearings on Outback. Lastly, can WRX fuel pump be used on 98 outback? I have a spare WRX one which I replaced with Walbro.
Thanks guys!
gopsu is offline   Reply With Quote
Old 02-11-2009, 09:16 PM   #2
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
wheel bearings need to be pressed in and out.
fuel pump, is easy enough, take out the unit, replace the pump, but the unit back in. I wouldnt put a wrx pump in an outback though.
Old 02-11-2009, 09:26 PM   #3
gopsu
Member#: 96448
02 WRX VF34
I have searched, but only found wheel bearing relacement on WRX. I am assuming Legacy and WRX wheel bearing replacement are similar.
I plan to do this myself and just take the hub assembly to the shop with press (NAPA or local shop). Perhaps I can get everything done under $100.
Old 02-11-2009, 09:30 PM   #4
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
pretty much the same as the WRX. Most DIYs take the hubs/knuckles off and them bring them some place to have the bearings pressed in and out.
Only tough part on the older cars is getting the kunckles off, the lateral links bolts tend to seize in the making it pretty much impossible to get them out without breaking or cutting them and sometimes damaging the bushings.
Old 02-11-2009, 11:11 PM   #5
rdodger
Member#: 156447
99 18g'd 2.5RS-T
The wrx pump will work fine, a little more flow but that never hurt anything. I think they even use the same connectors.
rdodger is offline   Reply With Quote
Old 02-11-2009, 11:18 PM   #6
ShookOne
Member#: 168177
2002 Wrx Sport Wagon
i had to replace my wheel bearing once.
it was stuck so the mechanic heated it up a little then it popped out.
incase yours doesn't wanna come out so easy.
good luck with everything.
ShookOne is offline   Reply With Quote
Old 02-11-2009, 11:19 PM   #7
nix-hex
Member#: 67809
1999 2.5 RS coupe
with the wheel jacked up in the air, can you move the wheel by grabbing it from top top bottom? is there play?
nix-hex is offline   Reply With Quote
Old 02-11-2009, 11:52 PM   #8
ZeroPunk
Member#: 169593
1998 Impreza RS
Rally Blue Pearl
That test isn't 100% valid; sometimes the wheel won't move even if the bearing is shot.
Also, I doubt the OP knows if the wheel will wiggle. He's asking about a car he's thinking of purchasing, not one he's inspected. lol
ZeroPunk is online now   Reply With Quote
Old 02-12-2009, 10:27 AM   #9
rdodger
Member#: 156447
99 18g'd 2.5RS-T
Then the bearing isn't shot tho is it? I mean the wheels still turning on an even plane...
Old 02-12-2009, 11:15 AM   #10
bugeye829
Member#: 81995
2008 Impreza
02 WRX 247k RIP
you are dead wrong on this. the bearing can be junk and without causing any play in the wheel. sometimes you can hear the roughness in the bearing while the wheel is turning but there is no side to side play.
bugeye829 is offline   Reply With Quote
Old 02-13-2009, 01:13 AM   #11
4wdrift
Member#: 1403
99 RBP GC8 Impreza
Impreza GC8
Thanks guys!
Here you go...
http://www.ej207.com/files/Subaru%20...vice%20Manual/
4wdrift is offline   Reply With Quote
Old 02-13-2009, 03:38 PM   #12
rdodger
Member#: 156447
99 18g'd 2.5RS-T
I wasn't disagreeing I just want to know how to know if bearings are shot if the "rock it" test comes back good.
Old 02-13-2009, 04:10 PM   #13
69subaru360
Member#: 159682
1995 WRX
2015 F150
Thanks guys!
The bearings are kind of a pain. You have to pull the spindle off and press them in/out in a press. I usually just buy a complete used spindle/hub/bearing and put that in.
The fuel pump in the wrx has a controller to lower the output at idle. In theory you would need that to put it in. With that said, I used my old stock wrx pump in my brother in laws outback sport when his pump went bad. It just fit and I did nothing else but bolt it in. It runs fine and has been in there for at least 6 months and 10,000 miles.
Old 02-13-2009, 05:02 PM   #14
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
wheel bearing thread
http://forums.nasioc.com/forums/showthread.php?t=787070
i'm moving this to the correct forum
Old 03-05-2009, 09:11 PM   #15
trueno16v
Member#: 175170
2005 WRX Wagon
owl + bungee cord= my a$$
Thanx for the info, I'll be doing these too once weather gets warmer.
trueno16v is offline   Reply With Quote
Wheel fitment on 98 Legacy Outback...? wirolla Tire & Wheel 3 03-03-2009 09:25 PM
rear wheel bearings for 98 outback hackertim Transmission (AT/MT) & Driveline 0 12-24-2006 02:27 PM
Replacing rear wheel bearing on my 93 Legacy L FWD djsilvera Legacy Forum 3 10-11-2003 02:37 PM
Front wheel bearing questions, "99 Outback makofoto Legacy Forum 6 11-01-2002 11:51 PM
Replacing wheel bearings HudsoN456 Brakes, Steering & Suspension 2 10-29-2001 07:16 PM
