Old 02-11-2009, 10:19 PM   #1
sum0325
Member#: 192136
AE86 ,10 EVO X MR-T
08 Lancer GTS
Default HVAC problem
The 2nd of the blower speed was not working since I bought the car.
I thought its just the Hvac , so I bought a used one and replace it today.
but It does the same thing, what should I look for the next, what could be the problem?
My car is an 02
sum0325 is offline   Reply With Quote
Old 02-12-2009, 01:48 AM   #2
sorrowfulkiller
Member#: 170439
I <3 Lamp
its a blower motor resistor thats gone bad, its connected to the blower motor housing that the fan (blower motor is attached to.... get your local subie dealer to print you out a copy of the sheet that shows where it is)
It's not at all hard to change but its time consuming
sorrowfulkiller is offline   Reply With Quote
Old 02-12-2009, 02:11 AM   #3
sum0325
Member#: 192136
AE86 ,10 EVO X MR-T
08 Lancer GTS
thanks a lot
that problem bother me a lot, this weedend is time to clear it out
Old 02-14-2009, 04:58 AM   #4
sum0325
Member#: 192136
AE86 ,10 EVO X MR-T
08 Lancer GTS
finally went to buy the part from the dealer for $44
have any write up or idea would be easlier to replace
Old 02-14-2009, 07:12 AM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
It's very simple. Look under the passenger side dash in the footwell, at the bottom of the HVAC/blower housing. There are two electrical connectors down there (you may have to move the mats/carpet to see them)- One is for the blower motor and the other is for the resistor. Unplug the resistor, remove the screws holding it in place and remove it. Install the new one and plug it back in.
If after replacing the resistor the 2nd speed still doesn't work, there may be a problem with the speed switch.
Old 02-14-2009, 11:07 AM   #6
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
That is a interesting design for the resistors. I have not seen that type of design before.
Old 02-14-2009, 12:26 PM   #7
rick-l
Member#: 33868
2003 wrx
srp
A $3.99 Harbor Freight voltmeter could have removed all doubt about what part was bad.
rick-l is offline   Reply With Quote
Old 02-14-2009, 02:20 PM   #8
sum0325
Member#: 192136
AE86 ,10 EVO X MR-T
08 Lancer GTS
great ,sound like so easy.thank you so much for this.
and hope it will help someone too
Old 02-15-2009, 06:33 PM   #9
sum0325
Member#: 192136
AE86 ,10 EVO X MR-T
08 Lancer GTS
ok just replace mine and everthing works prefect right now.even I feel the blower is way stronger now.
Replacement is so easy , all i did was just looked down from the passager side ,above the ecu,and you will see a brown connector.Unplug it and unscrew the resistor ,repleace the new one and put everything back.
Only took me 5 mins to get everything done.
Here is the bad resistor:
HVAC problems Matt Mid Atlantic Impreza Club -- MAIC 0 02-23-2008 09:44 PM
HVAC problems qoncept Service & Maintenance 2 12-19-2005 03:58 PM
HVAC problems! SubaruImpreza_power Service & Maintenance 6 01-29-2004 12:28 AM
HVAC Problem 98LegacyGT Legacy Forum 4 12-10-2003 04:19 PM
HVAC Problem 98LegacyGT Electrical & Lighting 2 12-10-2003 11:17 AM
