Old 02-11-2009, 11:39 PM   #1
rougeben83
Member#: 115154
2005 Outback XT
White on grey
Default Can I use this oil filter? (not really subaru related)
Not 100% subaru related, but I have a couple of purolator L14460 oil filters left over from when I still had an ej253...my gf's got a 2003 hyundai Accent, completely stock, uses a L14459 filter.
Basically theyre the same but the 14459 has a relief valve set at 12-15psi vs. 20-25psi in the 14460. Can I use my old filters on her car? I usually change her oil every 3-4 months, she never puts more than 4k miles during that time period...
rougeben83 is offline   Reply With Quote
Old 02-14-2009, 01:32 PM   #2
madmax718
Member#: 172501
that all depends, just remember if the bypass doesnt quite work, you may starve the engine. usually the mfg builds a high margin of psi into the oil pump
madmax718 is offline   Reply With Quote
Can I use EJ25 Oil Filters on a EJ20? jmeltzer4 Service & Maintenance 4 10-05-2009 06:33 PM
Subaru Tech's recommend not using aftermarket Oil Filters? CirrusWRX Service & Maintenance 39 07-18-2003 02:55 AM
Subaru dealer using Valvoline oil filters? mightbewrx Mid West Subaru Owners Club Forum -- MWSOC 3 11-15-2002 12:40 AM
Anyone used this oil filter? gdiamant Service & Maintenance 4 11-02-2001 10:34 AM
Subaru Uses Purolator Oil Filters ! EchoWrx Normally Aspirated Powertrain 25 04-18-2001 04:02 AM
