Old 02-12-2009, 01:04 AM   #1
bnr34rb26dett
Member#: 188424
2012 640WHP STI
Unhappy CEL with cruise control lights goign on and off
i went catless, installed MIL eliminator, and did 05 rs engine swap with a motor that has 22k miles on it.
now the CEL light is going off with cruise control light going on and off. it is consistent so far.
im going to get it diagnosed tomorrow but does anybody have any idea whats going off? p0420 hopefully.
bnr34rb26dett is offline   Reply With Quote
Old 02-12-2009, 01:08 AM   #2
T Wrex--OH
Member#: 179478
2000 Impreza 2.5 RS
Sedona Red Pearl
It either is the rear oxygen voltage high/low, or catalytic converter efficiency below threshold.
The car knows your cat isn't doing it's job (in this case the non-existent ones) and has disabled your cruise control.
T Wrex--OH is offline   Reply With Quote
Old 02-12-2009, 01:10 AM   #3
T Wrex--OH
Member#: 179478
2000 Impreza 2.5 RS
Sedona Red Pearl
oops, or your test mode connectors could be connected, they shouldn't be...
Old 02-12-2009, 07:42 AM   #4
bnr34rb26dett
Member#: 188424
2012 640WHP STI
+1
you mean from like tuning? i have never tuned my car...yet.
Old 02-12-2009, 02:06 PM   #5
elevenpoint7five
Member#: 187798
04 2 liters of
AWESOME!
you need to have the codes read before anyone can help you. head to your local autozone, they will read it for free.
elevenpoint7five is offline   Reply With Quote
Old 02-12-2009, 02:09 PM   #6
Mavrik
Member#: 90347
2013 BRZ & Imp 2.5RS
Yamaha FZ8
Getting tuned should eliminate the codes if they are being set because of whats on the car. the cruise system disables when ever the cel is on. Since your untuned and catless, I'm going to guess your setting a p0420 code for cat efficiency below threshold.
GO GET TUNED!
Mavrik is offline   Reply With Quote
Old 02-12-2009, 02:20 PM   #7
anickode
Member#: 141633
2002 WRX Wagon
Shiny new silver!!!
GO GET TUNED!
I think someone discovered that installing an 18mm spark plug spacer on your 02 sensor to pull it out of the exhaust flow will fix this too. Either way, get a tune. You spent money on an exhaust that you're not getting any power from yet.
anickode is offline   Reply With Quote
Old 02-12-2009, 04:35 PM   #8
CynicX
Member#: 48199
06 WRX
You guys noticed its a 2.5 RS right?
CynicX is offline   Reply With Quote
Old 02-12-2009, 04:46 PM   #9
thejordan
Member#: 185374
^ doesn't mean it can't be tuned.
he can do the resistor mod too.
thejordan is offline   Reply With Quote
Old 02-12-2009, 07:55 PM   #10
bnr34rb26dett
Member#: 188424
2012 640WHP STI
if you mean MIL eliminator, i actually already have that installed. it worked for a little bit and then CEL!
Old 02-12-2009, 08:58 PM   #11
k04sti
Member#: 171773
04 wrx sti
jbp dom 3 xtr w meth!
So, instead of being on here, go to autozone and get it read already. It takes like 5 seconds.
k04sti is offline   Reply With Quote
High coolant temp, cel, oil pressure light goes on and off? wtf cazwrx187 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 03-05-2010 04:25 PM
High coolant temp, cel, oil pressure light goes on and off? wtf cazwrx187 Electrical & Lighting 1 02-14-2010 01:58 AM
Brake light comes on and off but not low on brake fluid? IIdiceII Brakes, Steering & Suspension 5 09-13-2007 11:44 PM
cell and other lights blinking on and off EPskate Electrical & Lighting 5 03-20-2006 12:35 AM
Battery and brake lights flickering on and off together. AcquaCow Electrical & Lighting 2 07-04-2004 03:21 PM
