Old 02-12-2009, 02:54 AM   #1
cubuff
Member#: 38345
2004 WRB WRX
Default New snail.... borg s366
Nothing proven yet but it will change and ill use this thread when I have numbers within the next 2 months.
Here are pictures though of the monster that is about to go on my built 207.
Next to the stock td04 and the biggest monster you can get.
Another next to the stock WRX td04
Another showing exhaust... Its a divided 1.00ar courtesy of Full Race!
Another of the exhaust side, 3" vband welded on
cubuff is offline   Reply With Quote
Old 02-12-2009, 02:56 AM   #2
focusfuri75
Member#: 142011
nice!!!
focusfuri75 is offline   Reply With Quote
Old 02-12-2009, 03:02 AM   #3
SUBYS R US
Member#: 99591
2003 18g w/38EWG
PSM(siver)
yummy
SUBYS R US is offline   Reply With Quote
Old 02-12-2009, 03:35 AM   #4
VladiWrX
Member#: 145658
On my 5th scoob
and lovin it
beautiful
VladiWrX is offline   Reply With Quote
Old 02-12-2009, 04:03 AM   #5
EJMFAB
Member#: 197017
2006 WRX Wagon
91' Civic Hatch GT35R
Nice turbo! The BW's have picked up A LOT in the honda community. I haven't really seen to many over here so it was refreshing to see this. They definitely make incredible power. A lot of people swear by those over the GT series turbos. Good luck, should be verrrry fast.
EJMFAB is offline   Reply With Quote
Old 02-12-2009, 08:42 AM   #6
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
I heard they run better @ high boost levels, ie they shine at a higher psi level then say a garret..if this is true, why?
i dont get why people spend big bucks on garret turbos..you can get used holset diesel truck turbos for cheap and they perform just as good
mxpunk is offline   Reply With Quote
Old 02-12-2009, 10:47 AM   #7
treystoys
Member#: 97436
03 toyota tundra
gray..missing my WRX's :(
Interested in your set up man...have you run the 207 in the car already, or is this turbo going in with the 207 for the first time. I'm a fellow ej207 owner...amazing engines!
I'm running a 3076 .82 a/r on mine which has been a great turbo for mine on 93 octane and 23 psi.
ttyl
Trey
treystoys is offline   Reply With Quote
Old 02-13-2009, 12:28 AM   #8
cubuff
Member#: 38345
2004 WRB WRX
ttyl
Trey
Im coming from the 257! I cant wait for the smoothness that I hear that the 207 has! I have a completely built 207 with ported "big port" version 8 heads and cosworth avcs cams.... I am hoping for 8500+ I think 8500 is realistic and I would really like 9k if oil pressure is good. I wont take it over 9k.
I will probably add a shot of nitrous to spool this thing probably somewhere in the range of a 25 to 50 shot. Looking for mid to low 10's up here at 5800 ft.
Old 02-13-2009, 01:10 AM   #9
SubyWill
Member#: 166830
2003 WRX
so what are the advantages of a 207 to a 257? i'm curious on what to go with in the near future
SubyWill is offline   Reply With Quote
Old 02-13-2009, 01:53 AM   #10
cubuff
Member#: 38345
2004 WRB WRX
That is hotly disputed.... You will have your 207 lovers and then you will get your 257 fan boys.... Then there are always the people who say there is no replacement for displacement.
Reasons why I like the 207 is the short stroke, It seems that subaru motors are happier with shorter strokes. I like that fact the the cylinder walls are thicker on the 207 than the 257. I like the factory cross drilled crank (nitride treated on some, mine is!).... Overall I think the ej207 is probably the best motor subaru has ever built, especially in certain forms, version 8 with large port heads twinscroll turbo etc....
At the end of the day if you like torque, go with the 257. If you like smooth high revving engines go with the 207. Always keep in mind the 207 is stronger in stock form also forged internals from the factory.
Old 02-13-2009, 02:32 AM   #11
SubyWill
Member#: 166830
2003 WRX
At the end of the day if you like torque, go with the 257. If you like smooth with revving engines go with the 207. Always keep in mind the 207 is stronger in stock form also forged internals from the factory.
awesome! thanks for the info! i think i know what i'm going with now
Old 02-13-2009, 03:58 AM   #12
FQ_22b
Member#: 123195
2005 STi
Silver with Goldies
I Want Twin Scroll So Bad! SO JEALOUS!
Of couse I don't have the money laying around to REALLY build my block, so I must settle for my GT30r....
FQ_22b is offline   Reply With Quote
Old 02-13-2009, 06:28 AM   #13
Iflysti06
Member#: 156955
2006 STI
UR GT35R w/ mad bolt ons
Wow cant wait for this to unfold! /Subscribed
Iflysti06 is offline   Reply With Quote
Old 02-13-2009, 07:57 PM   #14
treystoys
Member#: 97436
03 toyota tundra
The strength of the ver 8 sti motor was my main reason for going the jdm route, the big port heads and 8k+ rev limit, make up for the lack of displacement to me atleast. The 30r seems to be well suited to this motor in stock form...I too wanna see some results from this build!
Trey
Old 02-13-2009, 09:02 PM   #15
05gtSTi
Member#: 175649
2005 Legacy GT
Obsidian Black
What garrett would this compare to eg 4088/4094? and how much?
05gtSTi is offline   Reply With Quote
Old 02-13-2009, 10:20 PM   #16
cubuff
Member#: 38345
2004 WRB WRX
It is advertised by full race as being everything the 4094 should have been. You can get the basic turbo without the vband discharge for a little over $1000 to have full race weld on the vband takes it to 1200ish. Mine cost 1275 I think because I opted for the bigger exhaust side.
Old 02-14-2009, 12:28 AM   #17
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
Where'd you get that from, BTW?
HamFist is offline   Reply With Quote
Old 02-14-2009, 12:33 AM   #18
vaj
Member#: 59136
04/5 APRWidebody STi
Parts all over the state!
Sounds like a great project. In for updates on this one.
Good lookin Rott!
vaj is offline   Reply With Quote
Old 02-14-2009, 01:27 AM   #19
ownnij
Member#: 70459
2002 AW Bugeye ej257
6spd, GT3076R, Alky & EWG
thats sick. i want to see more borg warner setups on subarus. i'm planning on doing one my self. a friend of mine is building a fully built ej205 with a ej207 sb witha gt40r. can't wait until those results too.
ownnij is offline   Reply With Quote
Old 02-14-2009, 03:57 AM   #20
cubuff
Member#: 38345
2004 WRB WRX
Full Race...
http://www.full-race.com/
Seriously some of the best customer support I have dealt with lately.... Best prices on borg warner products I could find! I have heard that the compressor housings are on back order right now so no new s366's will be shipping anytime soon!
Old 02-14-2009, 08:55 PM   #21
Jhovany
Member#: 137317
2006 STI
Rally Blue
I am sooo sorry for the question but im just not very "turbo literate".........How does this compare to the S300sx 83/75 in size?
Jhovany is offline   Reply With Quote
Old 02-14-2009, 09:02 PM   #22
Clark_Kent
Member#: 114299
Looks nice!
Clark_Kent is offline   Reply With Quote
Old 02-14-2009, 09:27 PM   #23
SuperSTI
Member#: 67182
2004 Subaru STi
11.0 @ 128mph - 93/Meth
Dont know if this was answered or asked....what does this turbocharger compare to?
SuperSTI is offline   Reply With Quote
Old 02-14-2009, 11:14 PM   #24
cubuff
Member#: 38345
2004 WRB WRX
The 83/75 is like a twinscroll 35r, the s366 or s300sx 91/79 is like a 4094r. So the s300sx 91/79 is rated at 82lb per min and the 83/75 is is rated at 68lb per minute.
Old 02-14-2009, 11:23 PM   #25
hybridpatient95
Scooby Scammer- Do Not Buy From User
Member#: 127606
amen my brother i got a hx55 on ej22e/wrx heads combo
not finished here
hybridpatient95 is offline   Reply With Quote
new monster borg warner turbo 123mara Engine/Power/Exhaust 66 08-07-2010 04:27 AM
Snail-juice-drinking is the new toad-licking Wagon Of Fury Off-Topic 15 03-15-2010 01:55 PM
Snails, Snail, Snails! All kinds of Turbos! Built Industries Engine/Power/Exhaust 2 04-28-2009 05:23 PM
Borg Warner s366 + Daily Driven?? FuZiOn84 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 79 01-23-2009 02:30 PM
Borg Warner s366 + Daily Driven?? FuZiOn84 Mid Atlantic Impreza Club -- MAIC 2 12-18-2008 10:39 AM
