Old 02-12-2009, 05:31 PM   #1
ADAS1223
Member#: 159853
2005 Impreza
wrb
Have a Nice Day? Adas1223's DIY hoodscoop delete
EDIT: you need 12x25" for an 04-05, they only sold 12x24 so it will not be flush with the recess, but still cover the hole. my bad
Materials:
$5.00? 3M double sided tape
$11.00 home depot polycarbonate glass (12x25) your year dimensions. its advertised as unbreakable we'll see.
cutting tool (dremel, saw, power sander, whathave you)
TOTAL: < $16
Time: 30minutes or less
I didnt take any during shots but its very simple.
Step 1: Take off the stock scoop and splitter. bunch o 8mm nuts
Step 2: trace shape of scoop area on glass. this could be done by just laying it over b/c its somewhat seethru even with the protective tape over it.
Step 3: Cut it out! I used a saw for larger pieces, then a power sander to finalize the shape. not a lot to trim if its 12x24".
Step 4: re-use the bolts on the hoodscoop and place 3m double tape on the top rectangle
Step 5: Place the bolts with tape on the mounting holes
Step 6: Remove protective tape from glass and clean off any shaving/dust
Step 7: Carefully drop the glass on the 3m taped bolts (Once they touch the glass, they will never come off!! kinda good/bad in a way)
Step 8: secure the bolts!
Step 9: Clean your engine bay!!
done
PS. You can add washers on the rear bolts to create a vent/ add downforce.
PSS. You can paint the edges or everything if you don't want the lambo style ..I will color match mine
PSSS. Don't do this if you live in a bad hood. they'll jack your bov
-Alex
ADAS1223 is offline   Reply With Quote
Old 02-12-2009, 06:14 PM   #2
PoorMan'sR
Member#: 202438
2005 WRX
CGM
that's pretty cool, and cheap
PoorMan'sR is offline   Reply With Quote
Old 02-12-2009, 06:41 PM   #3
Soobie2.5i
Member#: 137321
2006 Impreza 2.5i
CGM
pretty sweet idea!
Soobie2.5i is offline   Reply With Quote
Old 02-12-2009, 06:45 PM   #4
lastsnare
Member#: 169539
2004 WRX sedan JBP
2013 BRZ GBS, 2000 2.5RS
i like it, wish i had a front mount to do this !
lastsnare is offline   Reply With Quote
Old 02-12-2009, 06:48 PM   #5
P03w
Member#: 29059
1914 Stutz
Bearcat
Looks good, but I'd advise drilling holes and using the bolts to mount. 3M tape is not truly weatherproof, and over time, moisture, UV and dirt will cause the bond to fail. When that happens, your hard work will go airborne, and while it probably won't break your windshield, the lexan/polycarb piece will likely shatter on impact with the ground, or at least bang/scratch it up.
Nice job though... don't mean to detract from your efforts, just have plenty of experience with VHB and other 3M tapes... and no tape bond is permanent.
P03w
P03w is offline   Reply With Quote
Old 02-12-2009, 06:49 PM   #6
sc00ter
Member#: 117767
2015 WRX
CWP
Ingenious. I love it!! And it's so cheap.
sc00ter is offline   Reply With Quote
Old 02-12-2009, 06:58 PM   #7
ADAS1223
Member#: 159853
2005 Impreza
wrb
P03w
definitely man, definitely. I didnt think of that. thanks for the heads up. I just saw the 3m tape on my cusco lip, it was dry and no adherence. too much weather.. your right. this should hold up for a few months is my guess-timate.
What could be a permanent way to mount this without touching the top glass surface?
-Alex
Old 02-12-2009, 07:01 PM   #8
lastsnare
Member#: 169539
2004 WRX sedan JBP
just as an aside for the tmic crowd, i think a transparent molded scoop might be a cool idea for someone to run with, maybe i'll think that one over .... =)
Old 02-12-2009, 07:03 PM   #9
ADAS1223
Member#: 159853
2005 Impreza
wrb
A clear scoop. That's gonna be a sight to see haha
Old 02-12-2009, 07:38 PM   #10
Thug Nasty
Member#: 128492
Chapter/Region: HIIC
2002 WRX - Hybrid
Very cool. I like it.
Thug Nasty is offline   Reply With Quote
Old 02-12-2009, 07:40 PM   #11
SubieWReX
Member#: 151080
07 BME AutoX WRX
Looks really good, IMHO it looks better than most fiberglass ones.
SubieWReX is offline   Reply With Quote
Old 02-12-2009, 07:44 PM   #12
TheSomethingorother
Member#: 186149
2005 STi WFC #144
I failed...
TheSomethingorother is offline   Reply With Quote
Old 02-12-2009, 07:46 PM   #13
TheSomethingorother
Member#: 186149
2005 STi WFC #144
Nice job, looks good!
Although as Platinum03Wagon mentioned I would mount it more securely and add holes.
Maybe stainless steel bolts/screws that can be counter fit into the plexi? Maybe some cool Allen heads or something along those lines?
Old 02-12-2009, 08:13 PM   #14
ADAS1223
Member#: 159853
2005 Impreza
wrb
I might try that one! if i have to end up using outside bolts, might as well make them tricked out.. gotta find me some burnt TI bolts haha (i doubt they make those)
Old 02-12-2009, 08:14 PM   #15
lastsnare
Member#: 169539
2004 WRX sedan JBP
actuators that raise the rear edge when car reaches highway speeds, hehe
Old 02-12-2009, 08:15 PM   #16
Handsdown
Member#: 29355
i like that way more than the mesh ones. ZR1!!!
Handsdown is offline   Reply With Quote
Old 02-12-2009, 08:16 PM   #17
emsmap
Member#: 159334
02 WRX, 99RS, 96L
AP3,PPG, BW S256
wow!!! I seen this done at Ocean City one time
emsmap is offline   Reply With Quote
Old 02-12-2009, 08:27 PM   #18
Wrx KidD
Member#: 123531
.. Kwinskii <3
This is easy top 10 DIY!
Wrx KidD is offline   Reply With Quote
Old 02-12-2009, 08:33 PM   #19
geist
Member#: 111197
1995 Lexus SC300
Has it warped from the engine bay heat yet? Interested in seeing how this holds up to the conditions.
geist is offline   Reply With Quote
Old 02-12-2009, 08:34 PM   #20
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
+1 Excellent Idea. If I had a FMIC I too would go for this.
wrxdrvr is offline   Reply With Quote
Old 02-12-2009, 08:35 PM   #21
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
I would actually set it up the opposite, Up when stopped and down when cruising...
Old 02-12-2009, 08:42 PM   #22
dmitriygolos
Member#: 191111
2005 evo VIII
Silverrrr
maybe i could get a whole hood like this. lol kidding
dmitriygolos is offline   Reply With Quote
Old 02-12-2009, 08:56 PM   #23
nexgen
Member#: 179789
2002 When in Doubt
Flat Out!!
how thick was the glass that you used?
nexgen is offline   Reply With Quote
Old 02-12-2009, 09:26 PM   #24
aug
Member#: 172080
very nice.. i like it
aug is offline   Reply With Quote
Old 02-12-2009, 09:53 PM   #25
ADAS1223
Member#: 159853
2005 Impreza
wrb
I believe 1/8"
FS:KsTech Hoodscoop Delete 04-05 WRX/STi obsti2 Exterior/Styling 0 08-03-2009 09:45 PM
ADAS1223's DIY iphone video mount ADAS1223 Interior & Exterior Modification 4 07-21-2009 05:02 PM
FS: Custom APS FMIC w/ APS bov, intake, KStech Hoodscoop delete lugee SCIC Private Classifieds 29 03-08-2009 10:28 PM
KS-tech 02-03 hoodscoop delete DFL2.5RS Car Part Reviews 3 03-31-2008 02:04 PM
DIY hoodscoop featuring Keith RidinLow Off-Topic 54 12-20-2004 10:22 PM
