Old 02-12-2009, 06:04 PM   #1
2slow
Member#: 158479
2005 Saab 9-2x Aero
Default Differences between Cobb Stage 2 maps for 91, 91 and ACN 93
I have a Saab 9-2x Aero that has a Cobb catted downpipe, catless up pipe from a ’06 STI and a cat back exhaust from the same ’06 STI. The STI exhaust technically does not meet the requirements of a 3” cat back for stage 2, but lots of people claim to run them with Stage 2 and have had no problems. I also saw a post in NASIOC that showed it had pretty low backpressure levels. I just do not want a loud exhaust and I have a buddy with the Borla Hush system and it is louder than I can tolerate.
My reasons for modifying the car were primarily to improve the low RPM performance. I don’t mind the higher RPM bonus, but I tend to short shift and will rarely use it.
I would like to have the best low end performance possible, and am willing to take a little reduction in high RPM performance in exchange for an increase in reliability. (This is especially important to me considering the fact that the STI exhaust is a little outside the parameters endorsed by Cobb for Stage 2.)
I took a look through the three Cobb Stage 2 tunings in access tuner race and found:
Stage 2 91 octane and Stage 2 91 ACN appear to be identical except for the primary fuel tables being about 0.01 richer in the higher load areas.
Stage 2 91 octane and Stage 2 93 octane appear to be identical except for some small differences in the primary spark tables.
OK, here is my idea:
I loaded the Stage 2 91 octane map into access tuner race and bumped the primary ignition timing to the same values as the 93 octane map for RPM below 4,000. I also richend up the primary fuel tables to the same levels as the 91 ACN for RPM over 4,000 RPM. I also reduced the rev limiter back to the stock 7,100 RPM.
I think that if I do that, I would essentially be running the 93 octane map below 4,000 RPM and the 91 ACN map above 4,000 RPM with a stock rev limiter
Does the above sound OK? Are there differences between the maps that I did not find?
Thanks in advance,
-Joe
Stage 2 91 Octane ACN
Stage 2 91 Octane
Stage 2 93 Octane
2slow is offline   Reply With Quote
Cobb Stage 2 AZ/CA/NV 91 Octane vs Perrin Stage 2 91 Octane Jayknux Engine Management & Tuning 8 01-26-2013 06:58 PM
Cobb Stage 2 AZ/CA/NV 91 Octane vs Perrin Stage 2 91 Octane Jayknux AccessPort 0 02-09-2010 06:53 PM
Difference from Cobb stage 2 and Protune stage 2... 2006 WRX nethngbtstk Proven Power Bragging 38 09-16-2008 03:21 PM
Cobb stage 2 maps (HWG VS. 91oct vs. 93 oct.) subywrxdude AccessPort 11 04-21-2006 10:30 AM
Difference Between Cobb Stage 1 & Stage 2 rudy_t2004 Engine Management & Tuning 14 02-17-2005 10:57 PM
