Old 02-12-2009, 08:10 PM   #1
Keith
Member#: 191
2012 J train
Brown
Default Finally got my car home..and I hear this hissing noise (battery?!)
Yeah, so I pull into my house, all happy that I have my car back and I hear this hissing noise. I thought it was my speakers, so I shut the stereo down.
Nope, not the speakers.
I pop the trunk (my battery is in the trunk) and there is the noise...my optima red top is steaming up the back of my car.
WTF! Nothing on the charging system was touched, just my brakes! This makes no sense at all.
I ran into the house to call optima (which is closed..weee), and went back outside. The hissing is much more quiet, but still happening. Any ideas what the hell happened? THis is the 2nd optima battery that I've gone through, so far I don't like them....it has always run like crap, never held a charge and have been a pain in the ass.
Anyone ever deal with something like this?
I'm not sure if I should have the car towed, or just pull the battery out myself. NEVER ENDING CAR DRAMA!!
Keith is offline   Reply With Quote
Old 02-12-2009, 08:12 PM   #2
Smalls
Member#: 137028
What kind of vehicle is it in?
Smalls is offline   Reply With Quote
Old 02-12-2009, 08:12 PM   #3
skywaffles
Member#: 82470
I am more humble
than you can understand.
Boiled the electrolyte? I thought Optimas were supposed to be that fancy impregnated mat style?
skywaffles is online now   Reply With Quote
Old 02-12-2009, 08:14 PM   #4
testify
Member#: 196517
2007 n00b rocket
urban grey metallic
i've heard a lot of horror stories about those optima batteries. Be careful when you get rid of it.
testify is offline   Reply With Quote
Old 02-12-2009, 08:14 PM   #5
Keith
Member#: 191
2012 J train
Brown
98 2.5RS-ti
Old 02-12-2009, 08:15 PM   #6
mannac
Member#: 161038
2005 LGT
'72 Datsun 240Z
If you're going through redtops so fast, you might have some other electrical gremlins to deal with.
Does it still do it if it's disconnected?
mannac is offline   Reply With Quote
Old 02-12-2009, 08:16 PM   #7
ItalianGuy
Member#: 60685
Tire Rack is still
cheaper
<--- has had a yellow top for 3 years w/ no problems.
Good luck Keith.
ItalianGuy is offline   Reply With Quote
Old 02-12-2009, 08:17 PM   #8
Miercoles Cansado
Member#: 166820
my ignore list
Try the on topic section. Good advice there. Someone out there must have some experience with this problem.
Miercoles Cansado is offline   Reply With Quote
Old 02-12-2009, 08:17 PM   #9
nhat
Member#: 140163
03 STi
hellaflunctional
i had an optima red top for 4 yrs without any issues whatsoever. and that's with a bunch of stereo equipment hooked up to it.
it is now in my friend's car and still going strong.
Old 02-12-2009, 08:17 PM   #10
Keith
Member#: 191
2012 J train
Brown
the last one didn't hold a charge, pepboys tested it after I complained and replaced it for me.
My last battery was fine, (normal sears job)
Old 02-12-2009, 08:24 PM   #11
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
They only vent if overcharged (more than 15-16 volts). Put a voltmeter across the battery with the engine running and see what it reads.
Old 02-12-2009, 08:26 PM   #12
Smalls
Member#: 137028
I would check the output of the Alt. My Rs was doing the same thing to a standard wet battery. It was overcharging it. Thankfully I caught it before all hell broke loose. It was outputing over 15V after 15-20 Mins of running.
I checked it after that amount of time to "replace" any static loss that might've occured overnight. It might have been pointless but it seemed logical to me. Anyways I replaced the Alt. and it solved my problem.
Edit: Normal should be in the 13.5-14.3ish range.
Old 02-12-2009, 09:35 PM   #13
Keith
Member#: 191
2012 J train
Brown
word, I'll give that a check when i get the car started again. This sux, I just got it back!
Stupid question, aren't alternators easy to install? I'll be doing it in the street with hand tools in 30 degree weather. I've only done an alternator one time and that was with the engine hanging on a hoist.
haha
Old 02-12-2009, 09:44 PM   #14
Sideshowbob
Member#: 50304
97 TJ Wheeler
12' TSX Wagon
That thing regged now?
Sideshowbob is offline   Reply With Quote
Old 02-12-2009, 10:02 PM   #15
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Yes the alternator is easy to swap. Just disconnect the battery first.
FYI once the Optima has vented it's NG since the electrolyte can't be replaced. Probably won't be warrantied either as it was damaged by overcharging and not defective.
Old 02-13-2009, 09:33 AM   #16
Keith
Member#: 191
2012 J train
Brown
Yeah dude I'll fill you in later, but she is good to go
Mulder, thanks for the advice man.
Old 02-13-2009, 09:34 AM   #17
rogue
Teddard Snark
Super Moderator
Member#: 7977
100% Abuse
Boo!!
rogue is offline   Reply With Quote
Old 02-13-2009, 09:51 AM   #18
Keith
Member#: 191
2012 J train
Brown
me no get it
Old 02-13-2009, 09:56 AM   #19
rogue
Teddard Snark
Super Moderator
Member#: 7977
100% Abuse
boo... hiss...
Old 02-13-2009, 10:06 AM   #20
The Gig
Member#: 89062
2005 Saab 92x Aero
Possible the shop let your battery die, and then over-charged it before giving you back the car???? I've seen batteries over-charged here at work do the same thing.
The Gig is offline   Reply With Quote
Old 02-13-2009, 11:57 AM   #21
4x4GGG
RIP Donny
Member#: 12686
2011 CR-Z EX
I thought I had the only car with a battery in the trunk!
4x4GGG is offline   Reply With Quote
Old 02-13-2009, 11:59 AM   #22
upnygimp
Member#: 47036
10 TBHOG
94 Ferd Fteenthousand
haha
Bolt off, bolt on.
You're just lucky the Subaru alternator is right on top of the engine.
I had to do a starter on a Ford E450 cutaway in a parking lot once. The starter sits between the transmission and the floor.
upnygimp is offline   Reply With Quote
Old 02-13-2009, 12:03 PM   #23
jays05
Member#: 78165
05 STI 35r + e85
If you want to test another cheap battery, there's a $25 lawn tractor battery at Walmart that starts my STI just fine in the winter.
jays05 is offline   Reply With Quote
Old 02-14-2009, 02:28 PM   #24
Keith
Member#: 191
2012 J train
Brown
she is reading 14.3 volts, that sound right? I'm not sure how tight this stuff is.
edit, just read that the voltage is good. I'm going to take her out for abit and let her warm up, then test the voltage again.
Thanks for the ideas guys..I'm not sure what happened with the ultima still.
However, I will say that I got both ultimas from pepboys and had problems with both. My last battery was totally fine.
Now that I have the new battery, the car actually starts well and everything seems well.
finally got my car back... <3 my car! zmw Texas Impreza Club Forum -- TXIC 24 04-18-2009 09:56 PM
WOOOh, FINALLY got my car fixed and back from paint:) skate enjoi Member's Car Gallery 23 04-28-2008 10:25 PM
finally got my car back...before and after IIdiceII Member's Car Gallery 84 08-24-2007 07:58 PM
So I finally got my car back from the body shop, after two weeks and... JGard New England Impreza Club Forum -- NESIC 8 03-23-2002 09:03 AM
Finally got my car back (6 weeks in the shop) BoomerRS New England Impreza Club Forum -- NESIC 6 05-03-2001 08:59 AM
