Welcome to the North American Subaru Impreza Owners Club Thursday August 27, 2015
Old 02-12-2009, 08:41 PM   #1
kc jazz
Member#: 109807
2007 GSX-R + '05 STi
ewg'd, slammed, recaro'd
Default I'm at a dead-end for an oil cooler on my '05 STI, with FMIC
So I had an oil-temp gauge before and after the TXS FMIC I have went on the car.
Last summer, in like 90ish heat with a ton of humidity, I'd normally see in the 95-100 degrees Celcius. Now, during winter time and with the FMIC, I'm seeing about 90 degrees Celcius during highway driving in 40 degree (fahrenheit) less outside temperature.
Basically...my FMIC resulted in a lot of oil temp increase, and I'm worried about what temps I will see once it's hot out again.
So, I want an oil cooler.
The prosport's seem to have been discontinued, and I need one that'll work with an FMIC. Ideas?
And another question..just to make sure, an oil cooler will solve the problem I'm fairly confident of, and I'm not seeing any noticable (I don't have an aftermarket coolant gauge) coolant temp increases, but could getting a Koyo radiator and a flush help out more, or do an equivalent amount of good?
kc jazz is offline   Reply With Quote
Old 02-12-2009, 08:44 PM   #2
nhat
Member#: 140163
03 STi
hellaflunctional
http://forums.nasioc.com/forums/show....php?t=1336091
he took the pics down. hope this helps.
Old 02-12-2009, 08:47 PM   #3
CKxx
Member#: 33458
Your BOV sounds lame
93 RX7+09 Forester
Is it possible it will just always be around that temp since the stock oil "cooler" is also an oil heater? I'd bet it just stays around those temps once it's warm out again.
CKxx is offline   Reply With Quote
Old 02-12-2009, 09:01 PM   #4
MasterKwan
Member#: 98961
2003 WRX
Yeah, I think those temps sound very normal.
Old 02-12-2009, 09:18 PM   #5
kc jazz
Member#: 109807
well it's just the fact that it's running the same temps now in the 30 degree fahrenheit weather that it used to before the fmic in 85 degree f weather.
i dunno, i guess i could just wait it out till summer. but it's definitely getting warmed up quicker than before, and hotter than it normally was in winter before the fmic.
blah cars are stressful. any brand recommendations?
Old 02-12-2009, 10:02 PM   #6
b0nd18t
Member#: 155876
2007 STI
Blouch Dom3
maybe this is a dumb question... but why would a fmic result in higher oil temps?
b0nd18t is offline   Reply With Quote
Old 02-12-2009, 10:08 PM   #7
MasterKwan
Member#: 98961
2003 WRX
If you did the FMIC you probably turned up your boost too didn't you? That'll run up your oil temps too.
Cars are only stressful when you jerk with them. That's why it's not wise to mod the DD. My subaru's been on stands all winter as I swap parts into it but, I'm not stressed at all. If you want to avoid stress, leave it stock.
Old 02-12-2009, 10:12 PM   #8
b0nd18t
Member#: 155876
2007 STI
Blouch Dom3
wouldnt synthetic oil be a better choice then, seeing as how its more resistant to high temps?
Old 02-12-2009, 10:14 PM   #9
CKxx
Member#: 33458
93 RX7+09 Forester
The stock oil cooler/warmer is located where the oil filter attaches. It circulates coolant past the oil. This will, depending on the temperature of the two fluids, either heat the oil to coolant temp, or cool the oil to coolant temp.
FMICs block airflow to the radiator, or at least feed it air that has already been heated by the IC, causing coolant temps, and in turn oil temps, to rise.
...in this particular case, though, I'm willing to bet $1 that it's fine. When it gets hot out again the Tstat will open more and cool the whole system off to the correct operating temp.
Old 02-12-2009, 10:16 PM   #10
CKxx
Member#: 33458
93 RX7+09 Forester
For the record, I am assuming these temps are steady cruising at 60ish on the highway.
Old 02-12-2009, 10:30 PM   #11
kc jazz
Member#: 109807
- protuned at ~19 psi
- always run synthetic
- i guess i'll wait till it gets way warmer and see how the car reacts
Old 02-12-2009, 11:57 PM   #12
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
I noticed my oil temps rise by 5-10* after installing my TXS FMIC. I also noticed my oil temps drop by about 5* after installing my radiator shroud. I'm willing to bet that you'll see the oil temps drop with an aluminum radiator, but whether or not it's necessary is the question.
Old 02-13-2009, 12:11 AM   #13
kc jazz
Member#: 109807
I'm trying to figure out now whether buying an oil cooler and all the hassle that goes with it is going to be worth the difference of how easy it'd be to throw a Koyo radiator on.
Old 02-13-2009, 12:23 AM   #14
mpsti05
Member#: 86741
05 STi.. Built
twinscroll35r Love/Hate
mpsti05 is offline   Reply With Quote
Old 02-13-2009, 12:44 AM   #15
MasterKwan
Member#: 98961
2003 WRX
What are your water temps? For the FMIC to cause the oil temps to raise the water temps would have to be higher too (assuming no boost). Maybe what's actually been revealed is that you need a better radiator.
It's also possible your tune is making the engine run hot. Too much or too little timing or something like that.
Old 02-14-2009, 02:36 AM   #16
kc jazz
Member#: 109807
I've never noticed an increase in my water temps..however I don't have an accurate gauge to monitor them.
Maybe I should just try a cooler t-stat and coolant flush for now..see how that works.
Originally Posted by mpsti05 View Post
Nice! Do you run either of their products? That top mount is siiick.
Old 02-14-2009, 02:35 PM   #17
TRooper
Member#: 62422
2006 Lotus Elise
1.8L of Fury!!
Here is a pic of the SSAC FMIC, and Process West oil cooler kit. It is installed on 05cgm's STi.
TRooper is offline   Reply With Quote
Old 02-14-2009, 02:49 PM   #18
kc jazz
Member#: 109807
Great! Thanks for the pics. Do you have any clue if he's on the stock radiator?
Old 02-14-2009, 02:52 PM   #19
TRooper
Member#: 62422
2006 Lotus Elise
1.8L of Fury!!
He has a Koyo radiator.
Old 02-14-2009, 06:36 PM   #20
mrubino83
Member#: 22987
2010 PB EVO X GSR...
.. It's All Stock Officer
+1 for the B-Line Top Mount Oil Cooler! Saw big reduction in oil temps. Quality and fitment is top notch too. DroppedClutch is running one of these as well.
check it out
B-Line Motorsports Top Mount Oil Cooler
http://forums.nasioc.com/forums/show....php?t=1569855
mrubino83 is offline   Reply With Quote
Old 02-14-2009, 08:30 PM   #21
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
^ pretty nice right there^ Just dont like one extra thing to take off when doing maintence.
scby rex is offline   Reply With Quote
Old 02-14-2009, 11:16 PM   #22
mrubino83
Member#: 22987
yah def. a nice kit! All Earl's Fittings and Kevlar braided lines. Nice big core, too. Removal time for maintenance in minor, probobly takes me about an extra 10 minutes. Well worth it IMO.
Mike
Old 02-16-2009, 10:02 AM   #23
kc jazz
Member#: 109807
Thank you guys a lot. That bline top mount looks siiiiick. I'm probably going to end up ordering one of their products.
Old 02-16-2009, 11:07 AM   #24
crand002
Member#: 129765
2006 EVO
439whp/412wtq (MD)
What about getting a larger oil pan instead?
crand002 is offline   Reply With Quote
Old 02-16-2009, 05:22 PM   #25
b0nd18t
Member#: 155876
2007 STI
Blouch Dom3
things are $500+ . Do you guys think i'd need one for stage 2 mods +fmic ?
K&N Typhoon on my '05 STi UltimateLurker Car Part Reviews 32 09-29-2007 12:58 PM
Going with an FP Green on my 05 STI. Aftermarket fuel rail required? 2005wrbluesti Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 01-17-2007 02:37 PM
Left my windows open on my '05 STi in the rain and......... innova Car Audio, Video & Security 11 06-04-2006 06:27 PM
Mounting an Oil Cooler in my hood scoop keirnna Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 07-29-2005 09:20 AM
I'm looking for an OIL COOLER for an 04 STi rich728 Private 'Wanted' Classifieds 1 04-07-2005 11:52 AM
