Old 02-13-2009, 08:48 AM   #1
wanalaugh74
Member#: 148922
2004 Sti
Default Will this offset clear brembos 04 sti?
Rota SDR 17x7.5 in Steel Gray
+53mm
I saw the sti list saying that the 17" SDR's clear but it had an offset of +48. Will the +53 still clear? Thanks.
wanalaugh74 is offline   Reply With Quote
Old 02-13-2009, 08:54 AM   #2
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
I am pretty sure they will not. The +53 was designed for wagons since they have less clearance, and smaller brakes.
Old 02-13-2009, 08:55 AM   #3
wanalaugh74
Member#: 148922
2004 Sti
dang it!!! youre right they are coming from a guy with a wagon!!! blah!!!
Old 02-13-2009, 09:03 AM   #4
UFOpilot
Member#: 189525
2007 WRX Wagon
Invisible Plain
The +53 offset is stock on the STI, wagons might have been +53 also in '04 but it's not listed in the spec's and I own an '07 (+55) so not much help with the '04 wagon. However if you go to www.cars101.com you can search the archives for all the spec's on Subarus into the way back. The '04 STI is listed as having 17x7.5jj 5x100 +53. Same deal as my wagon but 2mm more outboard.
UFOpilot is offline   Reply With Quote
Old 02-13-2009, 09:06 AM   #5
UFOpilot
Member#: 189525
2007 WRX Wagon
Invisible Plain
You need to be concerned with the wheel diameter and inside of face shape a lot more than the offset for brake clearance.
Old 02-13-2009, 09:26 AM   #6
wanalaugh74
Member#: 148922
2004 Sti
hmmmm i pmed suby dude but havent heard back. i guess a test fit would prob be thebest answer haha
Old 02-14-2009, 12:11 AM   #7
suby_dude
Member#: 17397
many '02 Rex,'13 FRS
WRB, White
The +53 wagon specific SDR's will not clear STi front Brembo calipers. The only SDR that clears STi Brembo's is the 17x7.5 +48 model. If you run a 5mm spacer in front with the +53 offset SDR wheels they will clear.
-Dan
suby_dude is offline   Reply With Quote
Old 02-14-2009, 08:30 AM   #8
UFOpilot
Member#: 189525
2007 WRX Wagon
Invisible Plain
-Dan
Rota SDR , ahh. So it is the actual shape of the wheel in question. I am completly unfamiliar with the wheel in question and probably should have stayed out of it.
will enkei zr1 17x7.5 50 offset clear brembos?? mike739wrx Tire & Wheel 3 09-03-2009 10:59 PM
will enkei zr1 17x7.5 50 offset clear brembos?? mike739wrx Tire & Wheel 1 09-03-2009 08:05 PM
Will 17x7.5, +48 offset clear Brembos? bolderer Tire & Wheel 1 06-05-2008 07:17 AM
WORK Emotion XD9 - 18x9.0 43mm offset - Clear Brembo !! RavSpec Tire & Wheel 14 06-14-2007 12:10 PM
Will this wheel fit my 04 Sti Jeffsti Tire & Wheel 3 09-08-2003 04:41 PM
