Old 02-13-2009, 04:57 PM   #1
gatorREX
Member#: 154733
07 wrx sedan
Default The music when using AUX port only comes out of one side of the car...What gives?
I have an 07 rex with the standard auxiliary port for an ipod/mp3 player etc..
When I plug in my ipod the sound only comes from the driver side of the car. I tried adjusting all the settings on the 6cd changer to no avail. Does anyone know a fix for this? Thanks
gatorREX is offline   Reply With Quote
Old 02-13-2009, 06:36 PM   #2
subydrivor
Member#: 191755
2015 Impreza WRX
Does the cable you are using have a single black stripe? If so thats your problem you have a mono cable, you need one with 2 black stripes on the part that goes into the radio.
subydrivor is offline   Reply With Quote
Old 02-13-2009, 06:37 PM   #3
thedaddyb
Member#: 64374
07 WRX SWP *SOLD
03 2.5ts BRP long gone
even stupider question
is the balance on the ipod equal . . . or is it set all the way to the left?
thedaddyb is offline   Reply With Quote
Old 02-13-2009, 07:17 PM   #4
davetsbass
Member#: 169729
2002 a6 2.7t
If this is a new problem you may have worn away the contact surface on your plug (it is now to skinny to conduct properly) and you need a new plug.
But it sounds like:
davetsbass is offline   Reply With Quote
Old 02-13-2009, 07:29 PM   #5
Un0RiGiNaL
Member#: 189748
I had this problem too, i pulled it out halfway and it start working on both sides, it turned out to be the wire. i went thru all this crap trying to get the faceplate fixed (got a new faceplate) and then it turned out to be the aux wire.
Un0RiGiNaL is offline   Reply With Quote
Old 02-14-2009, 01:20 PM   #6
trueno16v
Member#: 175170
2005 WRX Wagon
owl + bungee cord= my a$$
Yeah, sometimes not all headphone jacks are created equally. There may be just a slight variation between the jack and the plug-- causing it to only play through one side. Try wiggling the plug around or try a different cord/plug.
(I didn't think they still make mono stuff?)
trueno16v is offline   Reply With Quote
Old 02-14-2009, 02:00 PM   #7
dubxero
Member#: 200702
2005 2.5 RS Wagon
The plug should be a trs connection (tip ring sleeve) and either the female end on the car or the male end on the cable could have a problem keeping it from making the connection.
The sleeve, or the bottom most part of the connector, is typically ground. The ring, or the middle part, is typically the right channel and the tip is typically the left.
If there's a connection issue at the plug itself it would be the center of the connector, the ring. As Davetsbass said it could be the ring is worn and "too skinny" to make the connection. Also, it could be the contact within the female end of the connection is bent inward and does not reach the male plug.
dubxero is offline   Reply With Quote
Old 02-15-2009, 02:48 AM   #8
gatorREX
Member#: 154733
07 wrx sedan
All options have been exhausted as for as adjustability on the ipod and on the stereo.
This has been happening since day one when I bought the car a little over a year and a half ago so I do not think it is worn. I usually just listen to CD's or the radio but I am going on a fairly length roadtrip which is why I want to finally fix it.
When I had the wire I do not remember how many black strips were on it. I think I bought the cheapest one when I went to best buy and I ended up returning it. I guess I'll get one with two black strips to start and see if that alleviates the problem.
I appreciate all the support!
Old 02-15-2009, 03:14 AM   #9
wrxkid157
Member#: 201046
2004 WRX
i had the same problem you might have scratched the inside of the walls of where the plug plugs in!!
wrxkid157 is offline   Reply With Quote
Old 04-22-2011, 12:39 PM   #10
Illuschonizt
Member#: 248619
2007 WRX
Obsidian Black Pearl
Since this is a common problem can it be stickied. i have the same porblem.
Illuschonizt is offline   Reply With Quote
Old 04-22-2011, 02:07 PM   #11
first suby 2010
Member#: 238974
2012 impreza premium
and 09 Forester XT
does it look like this.....
or this....
first suby 2010 is offline   Reply With Quote
Old 04-22-2011, 02:34 PM   #12
VLCMwrx
Member#: 259469
2008 WRX
SILVER
It could be the ipod itself. I had this issue and it turned out the jack in my ipod was not working properly. When I tried my headphones I could only hear sound from one ear bud. If I moved the plug around sound would come in and out of the side that wasn't working.
I tried a newer ipod and everything worked just fine for me.
VLCMwrx is offline   Reply With Quote
Old 12-13-2012, 12:11 AM   #13
dbt2021
Member#: 336689
I'm having this same problem with the aux in on a 2010 impreza with a sat/nav hu. I've tried multiple working cables, even took apart the console to look for any obvious wiring problems. Did anyone have any luck finding solutions?
dbt2021 is offline   Reply With Quote
Old 12-17-2012, 12:47 PM   #14
tedbertaux
Member#: 340855
2003 Impreza WRX
Subaru Stars AUX Troubles
It is most likely the actual aux cable. The connections on cheap cables usually only last around a month, then they start going out and doing what you are describing. Just buy an upgraded aux cable and this problem should be erased.
tedbertaux is offline   Reply With Quote
Old 12-17-2012, 01:20 PM   #15
dbt2021
Member#: 336689
Thanks, but I've already tried three perfectly good working cables. I do music production on the side so I have plenty of working 1/8th inch stereo cables around.
Old 05-09-2013, 09:10 PM   #16
cosminfilip
Member#: 260505
2012 WRX
I know this is an old thread but I am having a similar problem. I installed a C-123 in my 07 2.5i with the aux and a pig tail for it. I grounded wire number 4. I tried it out and everything worked great! After I put my dash back together, AUX music only plays on the right side of the car. CD and radio play on all speakers. I have no clue why. The aux cable is brand new just bought today. Right when i realized it, I wiggled the AUX cable a bit and it worked on all speakers and than it stopped and only worked on the right side again. Any help would be greatly appreciated!
cosminfilip is offline   Reply With Quote
Old 05-09-2013, 10:39 PM   #17
09WrxNJ
Member#: 355985
2007 FXT 4EAT
CGM
Sometimes my stock radio does this, sound only from one side. It will happen when it's on aux but persists when I switch to another source (radio or CD). It usually only happens when I start the car up after its been sitting a while. The only thing that fixes it is adjusting the balance, like the balance will say 0 but sound only comes from the passenger side, but when I balance the sound toward the pside it will start coming out of all the speakers again. Just a weird glitch once in a while.
09WrxNJ is offline   Reply With Quote
Old 05-09-2013, 10:41 PM   #18
09WrxNJ
Member#: 355985
2007 FXT 4EAT
CGM
If it works for a moment when you wiggle it, and you know for sure the cable is good, then it sounds like the aux input jack is dirty or defective
Old 05-09-2013, 10:58 PM   #19
cosminfilip
Member#: 260505
2012 WRX
Ok. I'll try to clean it but it looks new. I decided I'm gonna take it apart again tomorrow and look at all the wires to make sure they're all good in the back
Old 05-11-2013, 03:59 PM   #20
dbt2021
Member#: 336689
I took mine into an aftermarket shop recommended by my dealer and they went through two separate aux harnesses and aux jacks, nothing fixed the problem. They talked to subaru tech and they said it had to be an issue with the main wiring harness. I'm beyond pissed as I listen to so much music and am tired of having hundreds of CD's jostling around in my car. Let me know if anyone can offer any insight!
Old 05-11-2013, 04:24 PM   #21
cosminfilip
Member#: 260505
2012 WRX
Are you having the same problem as me? Because my aux cable was detective and I had bought it brand new that day. It fixed my problem
Old 05-11-2013, 07:36 PM   #22
dbt2021
Member#: 336689
Na man, multiple cables/devices/jacks/harnesses, nothing gives. I just don't understand how it can be the main wiring harness if the radio itself plays through both sides and only the aux does not, but perhaps the aux uses a separate pin channel or something? It was a freakin mystery to me, but they had a one/one connection with everything pulled apart, multiple parts combo's, and nothing worked. Very strange.
Old 04-23-2014, 05:28 PM   #23
dbt2021
Member#: 336689
So, still no one else has ever experienced this?
I took it into a shop and they had ordered me a separate port, cable, and everything, even tried with a different head unit of the same model. They concluded something must be wrong with the primary electrical harness system, but that made such little sense to me if the rest of the radio is playing through left and right just fine. I mean, would the aux input portion of the radio somehow use a separate electrical pin channel from the rest of the radio system? Seems bizarre and unlikely.
ecu Explorer reading 1v lower than rest of the car.. what gives? elsanto Commercial ECU Reflashes 0 12-16-2007 08:37 PM
one side of my car is higher than the other. refuse Brakes, Steering & Suspension 1 11-11-2006 06:26 PM
FS:STOCK STI BREMBRO ROTORS FOR SALE. 2 Rears/One Side of Front. Only used for 9k. NotoriousD Tri-State Area Private Classifieds 6 09-30-2006 06:33 PM
One side of my car sits lower than the other? JGard Brakes, Steering & Suspension 7 05-18-2001 07:58 AM
One side of my car is higher than the other! WRXwannbe Brakes, Steering & Suspension 6 11-15-2000 07:40 AM
