Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 02-13-2009, 07:00 PM   #1
AMR
NASIOC Manufacturer
Member#: 171509
Default NEW RELEASE: AMR 2" Race Header - ONE OF A KIND!
We just released out "AMR RACE HEADER" for the Subaru Community. This header is very unique and one of a kind. First we will start off with the specifications of the header.
The header is made out of 304 U.S.A. stainless. Each tube is mandrel bent to ensure smooth flow. It is equipped with our custom CNC 1/2 thick flanges to ensure no warping. Each tube is equally tuned. Just like all AMR Products, they are made in-house!
Pictures:
Dyno Plot:
Customer:
William
2008 Subaru STi
Mods:
- AMR BMI Cold Air System
- AMR Stealth-Back Exhaust (stock muffler)
- AMR Turbo Hard Pipe
- AMR Top Mount Intercooler
- AMR 750cc Injectors
- STOCK TURBO!
Notes:
We had done a conservative tune on the vehicle. AFR's in the low 11's. Boost was around 19psi. Vehicle made 294whp / 340wtq. This was on the stock header.
We then installed the new AMR Race Header along with a re-mapped AVCS map to suite header. First pull we had a gain of 18whp / 20wtq at the same boost level. AFR's richened up to mid 10's. We leaned the vehicle back out to 11.3-11.1 afr taper along with some more AVCS INT & EXH mapping and 2 more psi of boost (21psi) we saw a total gain of 32whp / 40wtq. Timing was left un-touch hitting 15* at full boost and 19* up top. We did notice the knock correction was not as sensitive after continous dyno pulls as normally would be which is a plus along with no loss in spool!! We could have given more timing up stairs to increase/level the HP but after the customer went for a ride and felt the difference, he stated "no need".
-Rob
AMR is online now   Reply With Quote
Old 02-13-2009, 07:03 PM   #2
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
you think the stock muffler is significantly increasing the backpressure over an aftermarket unit?
Old 02-13-2009, 07:07 PM   #3
battousai
Member#: 44977
2015 Mustang GT
oooh.. that's an interesting looking piece. Any pictures or videos of it installed?
battousai is offline   Reply With Quote
Old 02-13-2009, 07:46 PM   #4
Badazzcr
Member#: 67693
4 Making them
faster then anyone else.
someone needs to take a welding class
Badazzcr is offline   Reply With Quote
Old 02-13-2009, 07:47 PM   #5
DuCash
Member#: 198714
04' JDM STi EJ207
437whp/357wtrq Dom3 24psi
Price Please......
DuCash is offline   Reply With Quote
Old 02-13-2009, 08:07 PM   #6
SUBYS R US
Member#: 99591
2003 18g w/38EWG
PSM(siver)
who cares if there pretty or not. as long as they wernt cold are to fast then it should be fine. also no blow through
SUBYS R US is online now   Reply With Quote
Old 02-13-2009, 08:44 PM   #7
modaddict
Member#: 95840
sold to a good bud
awaiting next car
So your AFR's went RICH when you installed a header?
You would think IF you increased VE that they would go lean if the processor was untouched.
modaddict is offline   Reply With Quote
Old 02-13-2009, 08:46 PM   #8
STi-MAN
Member#: 70252
05 STI
blue
looks like the prototype is of better material then the production version.. any shots of the collector in the production model?
STi-MAN is offline   Reply With Quote
Old 02-13-2009, 08:50 PM   #9
Freon
Member#: 88322
2009 BMW 135i
Mass airflow sensor...
OP: AMR vs. FR on header primary diameter. FIGHT!
Freon is offline   Reply With Quote
Old 02-13-2009, 09:02 PM   #10
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
... and people call me blunt!
/OT
I was just going to say that someone needs to learn how to use a camera.
Sorry, I'm more anal about my photography, then I am tuning.
/on topic
Otherwise, props for at least trying something different! Though I'd love to know what type of ramp rate you're using on that DD, to run timing like that! If I tried to do that, on our 93, in 4th, on our dynojet, an '08 would implode!
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 02-13-2009, 09:22 PM   #11
juanmedina
Member#: 133146
07 FPgreen 7.37@95
WRX VF39+E85 12.0, 121mph
haha I know, how much they weight? like 30lbs.
juanmedina is online now   Reply With Quote
Old 02-13-2009, 09:49 PM   #12
SuperSTI
Member#: 67182
2004 Subaru STi
11.0 @ 128mph - 93/Meth
wow looks sick
SuperSTI is offline   Reply With Quote
Old 02-13-2009, 10:04 PM   #13
AMR
NASIOC Manufacturer
Member#: 171509
Its just the lighting in the picture that makes one look different than the other. They are identical in material.
-Rob
/OT
/on topic
Jorge (RiftsWRX)
www.ProjectWRX.com
Ramp Rate on the dyno was 100-110. I never use more than that. 4th gear.
I know I need a better camera, not bad for quick shop pics.
-Rob
Old 02-14-2009, 02:40 AM   #14
socalLGT
Member#: 89752
08 STI
Not sure if I like how the primaries are the same diameter as the secondaries. Must be nice to have 93 octane fuel... I can only dream of running 15* of timing with 21 psi at 11.3:1 AFR
socalLGT is offline   Reply With Quote
Old 02-14-2009, 03:56 AM   #15
Lamb155716
Member#: 155716
2008 Spesh Pitch Pro
2010 Spesh Roubaix Elite
how does that have to do with anything?
Lamb155716 is offline   Reply With Quote
Old 02-14-2009, 03:12 PM   #16
achavez
Member#: 139320
2006 RA 1-4 5mt
wrx obp needs a e85 tune
looks good
achavez is offline   Reply With Quote
Old 02-14-2009, 03:19 PM   #17
BigRigger
Member#: 129969
2005 Sti
Silver/Black
pmd you
BigRigger is offline   Reply With Quote
Old 02-14-2009, 03:20 PM   #18
WrXtaCy2003
Member#: 85036
2013 PBP sti ltd
05 LGT 35r 30psi..busted
this car made more power because it was running more boost. Did the headers help make power? Maybe. If the run with the headers was done at the same psi of boost as the stock unit, you would have a better side by side comparison. If you were to argue that the aftermarket unit "allowed" you to run more boost, to make more power, that is another story.
DK
WrXtaCy2003 is offline   Reply With Quote
Old 02-14-2009, 04:41 PM   #19
midnight2.5rs-t
Member#: 126217
04 Jetta GLI
it also says at the same boost they picked up 18whp and 20wtq
midnight2.5rs-t is offline   Reply With Quote
Old 02-14-2009, 04:50 PM   #20
Mr_Snips
Member#: 152117
2012 Ford F150 ECO
out of curiosity what does it do for the actual flow velocity?
seems like there would be a big loss where the other bank joins the bank closest to the turbo without the tubing enlarging for the extra flow.
Mr_Snips is offline   Reply With Quote
Old 02-14-2009, 05:51 PM   #21
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
If they want to get a REAL comparison of improved flow, toss a boost gauge in and actually measure exhaust pressure and do a simple BP/EP comparison across various levels of tune, then do the same with the factory unit.
For those who KNOW what they're looking for, THAT will sell product.
Some constructive criticism!
Jorge (RiftsWRX)
www.ProjectWRX.com
Old 02-14-2009, 06:29 PM   #22
WrXtaCy2003
Member#: 85036
2013 PBP sti ltd
missed that sry
DK
Old 02-14-2009, 07:40 PM   #23
midnight2.5rs-t
Member#: 126217
04 Jetta GLI
it happens I have done it plenty of times also
Old 02-14-2009, 08:30 PM   #24
madmax718
Member#: 172501
The welding is alright, its not perfect, but as someone said, the proto looks better than the production.
Im not fully convinced that simply increasing the diameter is all that helpful. In fact, I think you might have reduced velocity.
madmax718 is offline   Reply With Quote
Old 02-14-2009, 10:55 PM   #25
BigRigger
Member#: 129969
2005 Sti
Silver/Black
I just finished reading this book
Its a little old but the math and theroy are sound, plus they use the subaru motor examples alot.
There is a math formula for the displacement and induction systems to tell you how wide your pipes should be. They also say the wider the pipe, the more power you "CAN" get but your powerband is not as wide, same goes for the reverse. Skinny pipe means wide powerband but loss of peak hp.
AMR EL race header downest Car Part Reviews 22 03-02-2010 02:42 PM
One-Of-A-Kind Racing Cockpit GT5/5, Forza thebloodRS Non-Subaru Stuff 3 11-27-2008 04:58 PM
A Pair of One-of-a-kinds..... f4phantomii Off-Topic 29 09-23-2008 08:49 AM
WRX w/ one of a kind 18" Speedline GT-1 "Pinoy edition" hehe djerickd Member's Car Gallery 33 10-17-2001 12:48 PM
