Mid Atlantic Impreza Club
Go Back   NASIOC > NASIOC Chapters > Mid Atlantic Impreza Club -- MAIC > MAIC Vendor Classifieds
Closed Thread
Old 02-13-2009, 07:48 PM   #1
IAG Performance
Vendor Sales Rating: (66)
Member#: 158123
Default IAG Performance Service Special Thread - Now with Weekly Service Specials!
About Us:
IAG Performance is a complete performance & service center, able to take on the smallest or largest projects. At IAG, we are very familiar with the entire Subaru line of vehicles and you can feel comfortable knowing your STI, WRX, Forester XT, Legacy GT, or naturally aspirated Subaru is in good hands while work is performed. Our customers' satisfaction and comfort during service is our number one priority! We are not about inflated service tickets or one time visits... At IAG, we hope to build long-term relationships that last a lifetime!
A quick shot of our showroom:
Used Parts Section:
Be sure to check out our used-parts section! We have a good number of quality used parts in stock. We buy/sell used parts here regularly -- Shoot us a PM for more info!
http://iagperformance.com/shopping_c...es.php?cat=891
IAG Performance Subaru Scheduled Maintenance Services
30,000 & 90,000 Mile Service - $399
-Oil change using your choice of Motul, Eneos or Valvoline Synthetics
-K&N or Purolator Pure One Oil Filter & new drain plug washer
-Replace Transmission Fluid w/ Motul 75w90 (Motul Gear300, Extra-S, and other fluids available upon request)
-Replace Differential Fluid w/ Motul 75w90 (WRX) or Motul PA 90 (STi)
-Coolant flush and inspect cooling system, hoses and connections. Global coolant w/ 1 bottle of Motul MoCool
-Air Filter Service (replace factory filter w/ K&N Drop-In, or clean & lubricate existing filter)
-Flush & replace brake fluid w/ your choice of Ate SuperBlue or Motul DOT 5.1
-Inspect brake pads and rotors
-Inspect brake lines and check operation of parking brake
-Inspect Front & Rear axle boots and axle shaft joint portions
-Inspect clutch operation
-Inspect Steering & Suspension
-Inspect tires & rotate
-PCV Valve
-Top-off all fluids
-Replace fuel filter (vehicles vary) and inspect fuel system
60,000 Mile Service - $499
-All services performed in 30K Service
-Change spark plugs
105,000 Mile Service - $899
-Replace Timing belt
-Replace water pump & water pump gasket
-Replace thermostat & thermostat gasket
-Flush coolant & inspect cooling system. Global coolant w/ 1 bottle of Red Line Water Wetter or Motul MoCool
-Crank Seal
-A/C & P/S Belts
-Cam Seals
-Timing belt tensioner
Timing Belt/Water Pump Service Only - $499
Brake Packages
Stage 1
Hawk HPS Front/Rear Pads
Techna-Fit SS brake lines
Motul DOT 5.1 or Ate SuperBlue
WRX - $499 Installed
STi - $549 Installed
Prices vary - Also available for other Subaru models - Call/PM for details and pricing!
Stage 2
Techna-Fit SS Brake Lines
DBA 4000 Series Slotted Rotors
WRX - $1049 Installed
STi - $1199 Installed
Prices Vary - Also available for other Subaru models - Call/PM for details and pricing!
Suspension Services
Alignment/Corner Balancing
Performance Alignment - $99
Performance Alignment & Corner Balancing - $199
Install Springs/Coilovers (purchased @ IAG) w/ Performance Alignment - $299
Install Customer supplied springs & alignment - $349
Install Customer supplied coilovers & alignment - $399
*Coilover installation includes initial ride-height set-up. Additional changes to ride height are extra. Alignments are subject to additional charges for extra time (seized bolts/hardware, extreme fitment/aggressive set-ups, etc.)
Fender Rolling Services
CALL FOR DETAILS!
Guideline for our basic pricing can be found here:
http://www.iagperformance.com/fender...g_service.html
Fender rolling service pricing may vary depending on vehicle/extent of service - Call/PM for details and scheduling info!
Transmission Services
Exedy Stage 1 clutch package w/ resurfaced flywheel & Motul or Eneos 75w90 fluid
WRX - $899 Installed
STi - $999 Installed
Exedy Twin-Plate clutch package w/ performance flywheel & Motul or Eneos 75w90 fluid
WRX - $1999 Installed
STi - $2099 Installed
Other clutch purchased @ IAG installation prices (includes resurfacing flywheel and choice of synthetic transmission fluid)
WRX - $399
STi - $499
Install customer supplied clutch (includes resurfacing flywheel and choice of synthetic transmission fluid)
WRX - $499
STi - $549
New ACT Heavy Duty Street Specials (others available - PM/Call for details!)
06+ WRX Special - ACT Heavy-Duty Modified Street Clutch, resurface factory flywheel - $1149 Installed with your choice of fluids!!!
05-09 Legacy GT Special - ACT Heavy-Duty Modified Street Clutch with your choice of ACT Streetlite or Subaru OE 06-07 WRX Flywheel - $1399 Installed with your choice of fluids!!!
04+ STI Special - ACT Heavy-Duty Modified Street Clutch with resurfaced flywheel for 04-09 STI 6-Speed - $1249 Installed with your choice of fluids!!!
Protuning by Jorge (riftswrx)
$500 for 2 hour tuning session
$99 for IAG Pre-Dyno Inspection - Includes compression test and check for boost leaks - Complimentary full-support on the dyno if this service is performed prior to tuning!
See our other thread for details on our Tuning Sessions with Jorge!!! Click Here
Appearance Services & Window Tint
Window Tinting @ IAG Performance
Our window tinter has been in the business for over 15 years, and does an absolutely incredible job. We offer Johnson high quality window films, available in shades from MD legal all the way to limo dark.
Our tinting services come with a lifetime warranty against bubbling, peeling, fading, purpling, hazing, & more.
If you're looking for high-quality tint for your Subaru, shoot us a PM or call at the shop any time!
Other Appearance Services
Recondition headlights - $75
Koji-Mod & Paint headlights (your choice of color, typically black)
WRX & STI - Call for Pricing!
Headlight and Taillight Protection Films - Price varies - PM for details!
IAG Performance
1203 Baltimore Blvd.
Westminster, MD 21157
410-840-3555
sales@iagperformance.com
__________________
See our 100% positive vendor review thread
/ 410-840-3555 /
IAG Performance is offline
Old 02-17-2009, 05:34 PM   #2
IAG Performance
Member#: 158123
IAG is proud to announce that we now offer a full range of mobile electronics services. We are offering some specials to kick off our expansion into the field so don’t miss out on these opportunities.
We stand behind what we install and everything is backed by a lifetime workmanship guarantee!
This Month's Specials
Products are offered for install only, and all prices include install.
Viper 5901 - $550* installed
Remote Start, Keyless Entry, Security.
Responder LC3 – the 3rd generation of Responder, complete with SST One Mile Range, the new Priority icons and text seen on a 20% larger liquid-crystal display, an onboard lithium-ion rechargeable battery with mini-USB recharging – all in the slimmest display remote on the market.
--Compatible with the new Viper Smart Start System. Control your alarm system with a compatible Iphone or Blackberry.
Avital 5303 - $400* installed
Avital's top-of-the-line security and remote start system will start your car with the push of a button from up to 1,500 feet away – and confirm it has started on the large LCD screen of the 2-way remote. Security works the same way: when you arm or disarm your system, you will receive confirmation on the 2-way remote, and if your siren sounds the remote will beep or vibrate to let you know, from up to 1,500 feet away. System comes with one 2-way and one 4-button 1-way remote.
Viper 4103xv - $275* Installed
Viper’s basic remote start and keyless entry solution. Includes two four button ergonomic transmitters with a range up to 1,500 feet.
Avital 3100 - $225 Installed
Alarm and Keyless Entry
When it’s peace of mind you’re looking for, Avital delivers in the affordable 3100. Control your system with two 3-button Avital remotes with range up to 1,500 feet.
2008+ model years add $50 for the data integration module.
2005+ model years add $50 for the transponder bypass unit (excludes 2005 WRX only)
****NOTE**** With all 2005+ model years you will also lose a key!
We now carry the full line of Viper, Avital, and Directed accessories.
You can even customize your setup with additional features. Including remote trunk release, remote window control, and additional sensors and/or sirens. Contact us for details.
GPS
We now also carry Guidepoint GPS tracking systems. Similar to LoJack, these units offer stolen vehicle recovery but also go above and beyond with additional features and services.
Guidepoint uses a state-of-the-art computer module that's equipped with a global positioning satellite (GPS) receiver, wireless data modem and vehicle interface component that allows us to "talk and listen to the car." Each unit's unique electronic serial number-similar to a cell phone number-allows information to be sent back and forth between the vehicle and Guidepoint's Response Center over a nationwide wireless network.
Available features and options:
-GPS Vehicle Locator: Log onto and track the whereabouts of your vehicle at any time of the day over the internet.
-Stolen Vehicle Recovery: Real-time Internet Tracking of your stolen vehicle 24/7 by trained ResponseCenter personal for faster recovery.
-E-Call & Roadside Assistance: In the event of an emergency situation of any kind, this feature provides appropriate emergency assistance or towing to the vehicles exact location with a single phone call.
-Geographic Boundary Alerts: Set geographic limitations in which your vehicle can travel. If your vehicle travels outside of your predetermined boundaries, youll receive an automated alert via email or text message.
-Selectable Excessive Speed Notification: This feature allows you to track the speed your vehicle is traveling and provides you with electronic alerts any time your vehicle exceeds a pre-selected speed for a given amount of time.
-Trace Maps: With this online feature, you can review a history or trace map of where your vehicle has been.
-Arrival and Departure Alerts: Receive email or text notifications when your vehicle arrives or departs from a designated waypoint or landmark.
-Selectable Features: Add security and convenience with selectable features including Remote Door Unlock, Remote Carfind and Remote Car Start. (may require additional parts and labor).
-Visual Theft Deterrent: The Guidepoint access panel mounted on your dash is a visual indicator that your system is on and your vehicle is protected. This panel also allows for access to optional services.
-Transferable: If you ever sell or trade your vehicle, your Guidepoint GPS System can be transferred to your next vehicle.
-On-Call: 24/7/365 ResponseCenter access at the touch of a button.
-Electronic Security Fence: The Guidepoint Unit automatically sets an Electronic Security Zone around your vehicle each time you leave it.
-Automatic Theft Notification: If your vehicle is moved outside the electronic security fence a theft notification is sent to the ResponseCenter. As soon as the ResponseCenter receives the alert, one of our trained professionals will contact you at your designated contact number.
--Contact us for pricing and options.
Also be sure to check out our used part for sale section of our website:
__________________
/ 410-840-3555 /
Old 02-17-2009, 08:50 PM   #3
bisonjr
Member Sales Rating: (69)
Member#: 102714
What are the future dates for tuning sessions?
bisonjr is offline
Old 02-17-2009, 10:22 PM   #4
IAG Performance
Member#: 158123
The next date is next weekend, Saturday Feb 28 and March 1. There is one remaining spot, so if you're interested, shoot us a PM as soon as possible!
Beyond that, we have not selected dates yet for our March session. I will post up when we have some dates!
Regards,
Rick
__________________
/ 410-840-3555 /
Old 02-19-2009, 03:41 PM   #5
Slayer_X
Member Sales Rating: (2)
Member#: 170045
2004 WRX
Will Jorge Protune V1 accessports too?
Slayer_X is offline
Old 02-19-2009, 03:53 PM   #6
DiscoGsus
Member Sales Rating: (21)
Member#: 47646
0511 RallyBaja
DGM Sedan
Yes he will!
And you guys need a shop webcam...
DiscoGsus is offline
Old 02-19-2009, 10:27 PM   #7
IAG Performance
Member#: 158123
Yes he will (thanks John!).. We actually have one spot left available for this month.. Let us know if you're interested (there is another thread about it here in the MAIC Vendor Classifieds!)
Rick
__________________
/ 410-840-3555 /
Old 02-20-2009, 12:23 AM   #8
vinnyd
Member Sales Rating: (22)
Member#: 148219
2013 Mazdaspeed 3
Liquid Silver
can i do a group buy on service packages...the silver xt needs a 90 and the red xt is gonna need a 60 soon???
vinnyd is offline
Old 02-20-2009, 01:46 PM   #9
AginorGotD
Member#: 143119
2007 STi Limited 352
UGM
Thanks again for taking care of me yesterday. There's a reason I drive 48 miles for you guys for an oil change.
AginorGotD is offline
Old 02-20-2009, 02:34 PM   #10
design1stcode2nd
Member#: 112178
Didn't realize you guys were doing Dyno's on the 28th, I sent you an email about getting some generic stuff done (oil change, steering rack bushings and tail tint). Should I try to schedule for a different day?
design1stcode2nd is offline
Old 02-20-2009, 05:59 PM   #11
IAG Performance
Member#: 158123
I'm sure we can work out a package deal. I'd definitely like to help you get the silver car sold so you can get your head focused on more important things (like 10 second Foresters...)
No problem! We certainly appreciate your business!
You've got email, sir!
Reminder for the day: One last tuning spot available for February 28/March 1!!! PM for details!
Rick
__________________
/ 410-840-3555 /
Old 02-28-2009, 05:38 PM   #12
Str8Gone
Member Sales Rating: (36)
Member#: 147972
2004 wrx hybrid 18g
11.9@117 dd
I know you guys stock seibon right? I was looking for this lip for my car that I havent seen much http://www.seiboncarbon.com/pdut_det...asp?ItemID=515
If you guys could get this that would be awesome
Str8Gone is offline
Old 02-28-2009, 09:54 PM   #13
jsr426
Member Sales Rating: (16)
Member#: 170369
STI- EVO X- GT-R
WRB,WW,RED
RIIIIIIIICCCCCCKKKKKKKK!!!!! pickticket
jsr426 is offline
Old 03-06-2009, 07:34 PM   #14
IAG Performance
Member#: 158123
Sent you a PM... I'm sorry, I saw your post last weekend when we were down at the tuning session and completely forgot to PM you when we got back!
Rick
__________________
/ 410-840-3555 /
Old 03-07-2009, 09:04 AM   #15
96accord
Member Sales Rating: (28)
Member#: 145105
2015 WRB WRX Limited
2007 WRX Limited (sold)
Bump for me sending you a PM
96accord is offline
Old 03-07-2009, 01:57 PM   #16
IAG Performance
Member#: 158123
Right back at ya!
__________________
/ 410-840-3555 /
Old 03-18-2009, 06:15 PM   #17
chazly413
Member Sales Rating: (6)
Member#: 151079
2005 2.5RS RBP
too many friction losses
Bump! I sent you a PM.
chazly413 is offline
Old 03-20-2009, 02:34 PM   #18
IAG Performance
Member#: 158123
Thanks for the bump. Looking forward to your appointment!
Rick
__________________
/ 410-840-3555 /
Old 03-25-2009, 12:25 AM   #19
stratguitarist
Member Sales Rating: (11)
Member#: 174960
2006 Lexus IS350
391whp STi sold :(
So I have been slacker recently and I should have posted this earlier, but a huge thanks guys. The guys at IAG did a great job on corner balancing my 04 STi. Thanks again for the spanner wrench as well! You can expect a call from me tomorrow!
stratguitarist is offline
Old 03-30-2009, 03:52 PM   #20
IAG Performance
Member#: 158123
Josh,
I don't think we ever heard from you! I'll shoot you a PM to see what's up! Thanks for the kind words!
Rick
__________________
/ 410-840-3555 /
Old 03-30-2009, 07:21 PM   #21
bisonjr
Member#: 102714
PM'd.....
bisonjr is offline
Old 03-30-2009, 07:47 PM   #22
IAG Performance
Member#: 158123
PM'd.....
PM'd back!
__________________
/ 410-840-3555 /
Old 03-31-2009, 02:12 AM   #23
Heider
Member#: 172173
2005 Impreza WRX
was wandering around westminster today and happened to see the shop (stopped in a little after 7pm and chatted).
marking this for later as my 105k service will be coming up soon.
Heider is offline
Old 04-01-2009, 12:50 PM   #24
DiscoGsus
Member#: 47646
0511 RallyBaja
DGM Sedan
Thanks again for the work guys.
http://forums.nasioc.com/forums/show...1#post26177453
(yes its a cross post, and no I don't care!)
Old 04-01-2009, 03:33 PM   #25
IAG Performance
Member#: 158123
It was very nice meeting you the other night and chatting! Stop by sometime during the day when you get a chance, and I'll finish showing you around the shop!
John,
Thanks again for the review. We greatly appreciate your business, and look forward to working with you in the future!!!
Rick
__________________
/ 410-840-3555 /
Closed Thread
IAG Performance/RiftsWRX (Jorge) Tuning Session - June 26-27 - Spots available!!! IAG Performance MAIC Vendor Classifieds 16 06-22-2010 12:32 PM
3 T-mobile phones for sale. cheap. Drewbiehd NWIC Private Classifieds 5 06-21-2010 12:48 AM
30K service notasensei Texas Impreza Club Forum -- TXIC 2 06-16-2010 01:10 PM
Pot appreciation thread SQ3.0dotJP Off-Topic 4 06-16-2010 10:50 AM
