Go Back   NASIOC > NASIOC Regional Areas > International Forum
Old 02-13-2009, 06:49 PM   #1
AMS
Member#: 27854
STI, WRX, GTR, EVO,
BMW, Porsche, + More!
Default AMS/Wilwood WRX STi Front Lightweight Brake Kit Release!
AMS/Wilwood WRX STi Front Lightweight Brake Kit!
The AMS/Wilwood Subaru WRX STi Lightweight Brake Kit was designed for the Drag racer or Autocrosser looking for that extra edge. AMS has teamed up with Wilwood to provide this lightweight yet streetable kit that shaves 32 lbs from your STi, 22 of which is reduced from the rotating mass! Less weight (sprung & rotational) means quicker acceleration, less parts breakage, and quicker suspension response.
THIS IS THE SAME KIT THAT STOPS OUR DRAG CAR FROM 171+ MPH!!!
Using a robust Wilwood forged 4 piston caliper, this kit retains great stopping power making it very streetable. The vented vane rotor is 11.75” in diameter (stock is 12.75”) and features a lightweight aluminum hat. We supply the rotor and hat pre-assembled with safety wire and include Goodridge braided stainless steel brake lines. Grade 8 hardware and aluminum caliper brackets complete the package. This kit is designed to fit over 15” rims with the appropriate wheel spacers.
Features
• 32lbs. of weight savings, 22lbs. of which is reduced from rotating mass!
• Aluminum hat rotors come assembled, pre-torqued and safety wired
• Heavy-duty Grade 8 hardware
• Comes with everything needed for install
• Direct bolt-on, no modifications needed
Kit Includes
• Wilwood forged 4-piston caliper
• Wilwood brake pads – BP-10 medium friction “Smart Pad”
• Aluminum caliper adapter brackets
• Grade 8 hardware
• Street/Track 11.75” vented rotors & aluminum hats (assembled & safety wired)
• Goodridge S.S. braided high performance brake lines & fittings.
Applications
• Subaru WRX STi 5x100 and 5x114.3 Bolt Pattern
Please Note: While this kit provides great stopping power, the reduced weight of the rotor assembly means there is less thermal mass and thus it is not recommended for sustained high braking applications like track days, time trials, or road racing.
CLICK HERE TO ORDER
Thanks for looking,
Darius
AMS is offline   Reply With Quote
AMS/Wilwood WRX STi Front Lightweight Brake Kit Release! AMS MWSOC Vendor Classifieds 1 04-14-2009 03:07 PM
AMS/Wilwood WRX STi Front Lightweight Brake Kit Release! AMS Suspension/Brakes/Handling 0 02-13-2009 06:58 PM
Wilwood 6 Pot Front Big Brake Kit Lunarx Private 'For Sale' Classifieds 9 12-29-2004 03:07 PM
