Old 02-13-2009, 07:04 PM   #1
bnr34rb26dett
Member#: 188424
2012 640WHP STI
Unhappy CEL P2096 Post catalyst fuel trim system too lean (Bank 1) catless with MIL elim
i went catless, installed MIL eliminator, and did 05 rs engine swap with a motor that has 22k miles on it.
now I got the code pulled and its a P2096.
"Post catalyst fuel trim system too lean (Bank 1)"
apparently
"it looks like its only happening on 05MY models... as i read somewhere the rear o2 sensor actually has pulsating ohm resistance, and not a stedy one.."
i dont know if this is true or not, can i get a confirmation?
and is anyone else getting this code?
im lost as to fix this problem. any comments/ suggestions would be great!
bnr34rb26dett is offline   Reply With Quote
Old 02-21-2009, 09:47 AM   #2
bnr34rb26dett
Member#: 188424
2012 640WHP STI
any solutions?
Old 02-21-2009, 02:15 PM   #3
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
This code is usually caused by a faulty front air fuel ratio sensor. But i suspect your Mill eliminator is causing the issue. If the ECM sees a steady 0 volt reading from the rear oxygen sensor it will cause this code.
Old 02-23-2009, 09:23 AM   #4
ndmx52
Member#: 200802
2006 LGT - sTg 1
BSM
I don't know if this is going to help but here goes...
I've been suffering from this code on my LGT for about 4 months. My car is completely stock so that may not help you narrow it down. I have had my exhaust inspected for leaks multiple times, replaced my rear O2 sensor, had my front Air Fuel Sensor replaced. My Subaru dealership was lost for solutions.
But what I believe caused the problem was a cracked hose going too my boost gauge that was causing a vacuum leak. More air being drawn into the engine than the MAF sensor was calculating = lean condition.
Hope that helps.
ndmx52 is offline   Reply With Quote
Old 02-23-2009, 10:05 AM   #5
bnr34rb26dett
Member#: 188424
2012 640WHP STI
hmmm, thats interesteing. i was thinking its caused by the MIL eliminator but i do have a hybrid intake system installed.
this might have affected CEL but i doubt it. but my car is MAF. maybe i wil ltake that out and see what happens.
my car is NA by the way.
no boost ftl
Old 02-24-2009, 08:38 AM   #6
ndmx52
Member#: 200802
2006 LGT - sTg 1
BSM
Well, it looks like my vacuum leak wasn't the main problem for me. My CEL came back on last night. So I'm back to being clueless myself.
How to fix: p2096 Post Catalyst Fuel Trim System Too Lean Bank 1 Honkey3k Normally Aspirated Powertrain 3 02-11-2016 10:44 PM
cgeck engine p1071 system too lean bank 1 brianmurder13 General Community 7 04-05-2009 04:19 AM
CEL P0171 trouble shooting. Too Lean, Bank 1. theDaishi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 09-15-2008 10:49 PM
it safe to drive the car with this code P2096 Post Catalyst Fuel Trim System Too L TampaSTI Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 07-21-2005 11:54 PM
P2096 Post Catalyst Fuel Trim System Too Lean Bank ? TampaSTI Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 07-18-2005 05:46 AM
