Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Services
Old 02-14-2009, 12:44 PM   #1
IAG Performance
Vendor Sales Rating: (66)
Member#: 158123
Default The IAG Performance Service Special Thread!
About Us:
IAG Performance is a complete performance & service center, able to take on the smallest or largest projects. So whether you need a sway bar end link installed or forged pistons added along with a rotated turbo system, we are happy to help you. At IAG, we are very familiar with the entire Subaru line of vehicles and you can feel comfortable knowing your STI, WRX, Forester XT or Legacy GT is in good hands while work is performed. Our customers' satisfaction and comfort during service is our number one priority! We are not about inflated service tickets or one time visits... At IAG, we hope to build long-term relationships that last a lifetime!
A quick shot of our showroom:
IAG Performance Subaru Scheduled Maintenance Services
30,000 & 90,000 Mile Service - $399
-Oil change using your choice of Motul, Eneos or Valvoline Synthetics
-K&N or Purolator Pure One Oil Filter & new drain plug washer
-Replace Transmission Fluid w/ Motul 75w90 (other fluids available upon request)
-Replace Differential Fluid w/ Motul 75w90 (WRX) or Motul PA 90 (STi)
-Coolant flush and inspect cooling system, hoses and connections. Global coolant w/ 1 bottle of Motul MoCool
-Air Filter Service (replace factory filter w/ K&N Drop-In, or clean & lubricate existing filter)
-Flush & replace brake fluid w/ your choice of Ate SuperBlue or Motul DOT 5.1
-Inspect brake pads and rotors
-Inspect brake lines and check operation of parking brake
-Inspect Front & Rear axle boots and axle shaft joint portions
-Inspect clutch operation
-Inspect Steering & Suspension
-Inspect tires & rotate
-PCV Valve
-Top-off all fluids
-Replace fuel filter and inspect fuel system
60,000 Mile Service - $499
-All services performed in 30K Service
-Change spark plugs
105,000 Mile Service - $899
-Replace Timing belt
-Replace water pump & water pump gasket
-Replace thermostat & thermostat gasket
-Flush coolant & inspect cooling system. Global coolant w/ 1 bottle of Red Line Water Wetter or Motul MoCool
-Crank Seal
-A/C & P/S Belts
-Cam Seals
-Timing belt tensioner
Timing Belt/Water Pump Service Only - $499
Brake Packages
Stage 1
Hawk HPS Front/Rear Pads
Techna-Fit SS brake lines
Motul DOT 5.1 or Ate SuperBlue
WRX - $449 Installed
STi - $499 Installed
Stage 2
RacingBrake SS brake lines
RacingBrake Slotted or Cross-Drilled & Slotted Rotors
WRX - $949 Installed
STi - $1099 Installed
Suspension Services
Alignment/Corner Balancing
Performance Alignment - $99
Performance Alignment & Corner Balancing - $199
Install Springs/Coilovers (purchased @ IAG) w/ Performance Alignment - $250
Install Customer supplied springs & alignment - $349
Install Customer supplied coilovers & alignment - $399
Fender Rolling Services
$75
Roll rear fenders
$99 - Roll & pull rear fenders
$125 - Roll all 4 corners
$149 - Roll & pull all 4 corners
Transmission Services
Exedy Stage 1 clutch package w/ resurfaced flywheel & Motul or Eneos 75w90 fluid
WRX - $899 Installed
STi - $999 Installed
Exedy Twin-Plate clutch package w/ performance flywheel & Motul or Eneos 75w90 fluid
WRX - $1899 Installed
STi - $1899 Installed
Other clutch purchased @ IAG installation prices (includes resurfacing flywheel and new fluids)
WRX & STi - $400
Install customer supplied clutch (includes resurfacing flywheel and new fluids)
WRX & STi - $450
Performance Part Installs
Downpipe/Turboback (purchased @ IAG) - $75
Downpipe/Turboback (customer supplied) - $99
Uppipe Install (purchased @ IAG) - $225
Uppipe Install (customer supplied) - $300
Appearance Services & Window Tint
Window Tinting @ IAG Performance
Our window tinter has been in the business for over 15 years, and does an absolutely incredible job. We offer Johnson high quality window films, available in shades from MD legal all the way to limo dark.
Our tinting services come with a lifetime warranty against bubbling, peeling, fading, purpling, hazing, & more.
If you're looking for high-quality tint for your Subaru, shoot us a PM or call at the shop any time!
Other Appearance Services
Recondition headlights - $75
Koji-Mod & Paint headlights (your choice of color, typically black)
WRX - $199
STi - $225
Headlight and Taillight Protection Films - Price varies - PM for details!
A shot of our shop:
__________________
See our 100% positive vendor review thread
/ 410-840-3555 /
IAG Performance is offline   Reply With Quote
Old 02-18-2009, 10:52 PM   #2
4G63 T
Member#: 185708
04 330i
I might in need perfor. alignment.
4G63 T is offline   Reply With Quote
Old 02-20-2009, 04:42 PM   #3
IAG Performance
Member#: 158123
We can definitely help out with that! Shoot us a PM and let us know when you'd like to come in!
Rick
__________________
/ 410-840-3555 /
Old 06-11-2009, 04:17 PM   #4
IAG Performance
Member#: 158123
All Service Specials are still going on!
__________________
/ 410-840-3555 /
Old 06-27-2009, 02:20 PM   #5
xxelxx
Member Sales Rating: (13)
Member#: 202109
Hi Rick,
What's the widest wheels you guys fit for a 04 Sti? I have Rota SVN's 18x10 30 offset. I'm currently running -2.7 in the rear and -1.6 in the fronts and still rubs on dips. My rear fenders are rolled but not the fronts. I was wondering if you guys will be able to clear this for me without anymore rubbing issues. I live in Nj and would Luke to know if it'll be worth it to drive down there.
Thanks
xxelxx is offline   Reply With Quote
Old 06-30-2009, 03:28 PM   #6
IAG Performance
Member#: 158123
Originally Posted by xxelxx View Post
Hi Rick,
Thanks
It was nice talking with you yesterday! We'll look forward to hearing from you again soon!
Regards,
Rick
__________________
/ 410-840-3555 /
Old 07-05-2009, 08:25 AM   #7
GundamFan
Member Sales Rating: (1)
Member#: 212204
What is the koji mod? Please don't link me to his crazy long thread, i have slow internet and it wont load
GundamFan is offline   Reply With Quote
Old 07-14-2009, 05:24 PM   #8
IAG Performance
Member#: 158123
We have been receiving a lot of questions regarding "Koji Modding" (painting) headlights. Here are a few pics to demonstrate the difference between stock lights and painted. We will add pics once they are back on the car!
Enjoy!
Rick
IAG Performance
Stock:
In Black with or without chrome ring.
With Red Ring! (the guys in the shop are somewhat split on this look, but I think its HOT!!!)
Call today to get your lights painted! A variety of colors are available!
IAG Performance
1203 Baltimore Blvd.
Westminster, MD 21158
410-840-3555
www.iagperformance.com
__________________
/ 410-840-3555 /
Old 08-05-2009, 03:52 PM   #9
IAG Performance
Member#: 158123
Bump!
__________________
/ 410-840-3555 /
Old 08-12-2009, 05:36 PM   #10
IAG Performance
Member#: 158123
To the top!
__________________
/ 410-840-3555 /
Old 08-12-2009, 08:57 PM   #11
kidofdoomz
Member Sales Rating: (3)
Member#: 163848
2007 WRX STi
Obsidian Black Pearl
have you gotten those headlights back on a car yet? I'd love to see what it looks like mounted.
kidofdoomz is offline   Reply With Quote
Old 08-18-2009, 02:58 PM   #12
IAG Performance
Member#: 158123
Sorry, are you referring to the headlights pictured above? We have some pics of the koji-modded lights, not sure about the red rings... I'll check and see if I can come up with anything...
Rick
__________________
/ 410-840-3555 /
Old 08-27-2009, 07:17 PM   #13
IAG Performance
Member#: 158123
Almost Friday Bump!
__________________
/ 410-840-3555 /
Old 08-31-2009, 07:07 PM   #14
IAG Performance
Member#: 158123
Get your free alignment check at IAG Performance Today!!!! Call for details!!
Rick
__________________
/ 410-840-3555 /
Old 09-03-2009, 01:25 PM   #15
IAG Performance
Member#: 158123
Thursday Bump!
__________________
/ 410-840-3555 /
Old 09-08-2009, 03:15 PM   #16
IAG Performance
Member#: 158123
Post-holiday bump! Hope everyone had a great weekend!
Rick
__________________
/ 410-840-3555 /
Old 09-11-2009, 01:27 PM   #17
IAG Performance
Member#: 158123
Hope everyone has a great weekend! We are here until 7pm this evening and 10AM-5PM tomorrow! Call or PM for questions/orders!
Rick
__________________
/ 410-840-3555 /
Old 09-16-2009, 05:56 PM   #18
IAG Performance
Member#: 158123
Hump day bump!
__________________
/ 410-840-3555 /
Old 10-26-2009, 01:49 PM   #19
IAG Performance
Member#: 158123
Happy Monday!
__________________
/ 410-840-3555 /
Old 10-27-2009, 04:04 PM   #20
IAG Performance
Member#: 158123
ACT Clutch Deals!!!!
__________________
/ 410-840-3555 /
Old 10-27-2009, 04:10 PM   #21
vinnyd
Member Sales Rating: (22)
Member#: 148219
2013 Mazdaspeed 3
Liquid Silver
just got my 60k done. thanks for the great service guys
vinnyd is offline   Reply With Quote
Old 10-28-2009, 03:13 PM   #22
IAG Performance
Member#: 158123
Thanks, Vince! Always a pleasure! Thanks for the ride
Rick
__________________
/ 410-840-3555 /
Old 10-29-2009, 06:34 PM   #23
IAG Performance
Member#: 158123
Bumpers!
__________________
/ 410-840-3555 /
Old 10-31-2009, 06:07 PM   #24
clkoontziii
Member#: 128389
2006 impreza wrx
steel gray
i want the old logo back
clkoontziii is offline   Reply With Quote
Old 10-31-2009, 06:07 PM   #25
clkoontziii
Member#: 128389
2006 impreza wrx
steel gray
p.s BUMP
IAG Performance Service Special Thread - Now Including Mobile Electronics Specials!!! IAG Performance MAIC Vendor Classifieds 450 01-06-2012 01:18 PM
IAG Performance Holiday Special Service Thread: Free Services & Discounts? Mmmhmmm! IAG Performance MAIC Vendor Classifieds 27 01-02-2010 06:16 PM
The Japtrix Performance Service & Parts Special Thread! Japtrix Services 3 03-24-2009 01:20 PM
The Official IAG Service Special Thread IAG Performance MAIC Vendor Classifieds 165 02-02-2009 03:06 PM
