Old 02-14-2009, 03:49 PM   #1
2.5rsDOHC
Member#: 54820
1998 2.4 RS-T
hybrid\stroker
Impreza GC8 desperate for help
ok so awhile back my car got to where it was running pretty rough and started to stall out for no apparent reason so after a lil bit of down time and after I installed an ewg I start it up and I notice its running extremely rich (even for my car) and I try to rev it up a bit but it wont rev over 3k and once it gets to 3k it all irratic like its about to stall and it deffinitly isnt drivable so I take it to a shop they run a compression check & leak down test both of which are negative, so they tell me the only thing left for them to do is pull the motor check the internals and sort through all the wiring, all of which is at an $80 per hour rate an I dont have that kind of $ to spend right now
so I asked them in your perfesional opinion what do you believe it to be and they said that its prob out of time due to a jumped timing belt if not they said it has to be in the wiring, so a $120 gates timing belt and a $160 tensioner later it runs exactly as it did before...
any sugestions as to what could be causing this?
2.5rsDOHC is offline   Reply With Quote
Old 02-16-2009, 01:21 AM   #2
master c
Member#: 168226
what is your base fuel pressure? do you have a wideband 02 so you can see the afr's
master c is offline   Reply With Quote
Old 02-16-2009, 02:45 PM   #3
#522
Member#: 2185
01 RS
swirly blue
What engine management are you running?
#522 is offline   Reply With Quote
Old 02-16-2009, 03:20 PM   #4
2.5rsDOHC
Member#: 54820
1998 2.4 RS-T
hybrid\stroker
I dont know what my base fuel pressure is right now my battery is dead so I'll let you know as soon as I get it charged and yes I have a wideband
Im using the e-manage ultimate
Old 02-16-2009, 03:42 PM   #5
#522
Member#: 2185
01 RS
swirly blue
Is your laptop connected when this is happening? Whenever my laptop is connected and the EMU software is running and I try to start the car, it asks if I want to connect then goes super rich and dies. If I start the car with my laptop connected and ON, then rev the car to 2k, then launch and sync the emu software, it's fine.
have you tried to re send your current maps/setup to the EMU? Because of the above issue, I recommend turning the car to ON, but not started, launching the software, then after it syncs, open your latest map/setup from the laptop, send file to emu, then quit, shut the car off. Wait 5-10 secs, then try to start.
Old 02-16-2009, 04:26 PM   #6
2.5rsDOHC
Member#: 54820
1998 2.4 RS-T
hybrid\stroker
ok I went out to try that but my plugs are fouled so I'll have to wait till I get plugs tomarrow
Old 02-17-2009, 01:08 PM   #7
2.5rsDOHC
Member#: 54820
1998 2.4 RS-T
hybrid\stroker
ok I tried what you said #522 and let me clairify when you say resend you mean the "export to main unit" option correct?
if so this didnt change anything exect I threw 2 new codes Im currently throwing a p117(engine coolant temp circuit low imput), p122(TPS/pedal position sensor A circuit low imput) & p403(EGR flow circuit malfunction)
the car wont even rev to 3k now it goes to about 2k then either stalls or almost does but oddly enough it idles quite smooth even though its super rich
Old 02-17-2009, 05:47 PM   #8
#522
Member#: 2185
01 RS
swirly blue
Yeah, that's what I meant. Sorry that didn't help.
It sounds like an electrical issue to me at this point, especially with circuit low error codes. Something is sapping current away from your sensors. Not sure if it your EMU unit itself or wiring for it, like a bad ground. When your car is on or idling, does the emu warning light flash red at any point? It should pulse that orange color or green if communicating with a laptop.
Can you check fuel trims? With tunes that are too rich, the ECU maxes out it's ability to pull fuel and the car will die. When I had the issue with my laptop I described above, I would watch the short term trims go all the way to -29 while idling and then the car would shut off.
This stuff is always tricky for me to figure out, especially not being able to see the car directly, so hopefully some others will chime in too.
Old 02-18-2009, 03:43 AM   #9
IllNastyImpreza
Member#: 36333
98 2.5RS
Need EM solution...
I think a little more detail with your setup would help
IllNastyImpreza is offline   Reply With Quote
Old 02-18-2009, 11:05 AM   #10
2.5rsDOHC
Member#: 54820
1998 2.4 RS-T
hybrid\stroker
98rs with stock ecu
e-manage ult, tuning with greddy map sensor
98 dohc heads
EJ22t shorty wiseco 2.4l stroker setup
8.5:1 c/r
720cc inj
big 16g @ 14.5lbs
large fmic
I just recently started to dabble with my emanage and Im not sure how to view/move a saved data logged file so I could post it for you to see?
Old 02-18-2009, 10:33 PM   #11
PhilSine
Member#: 130489
02 WRX Wagon (WRB)
98 OBS-T, 91 Legacy SS
It's not internal that I am somewhat sure of.
Think about it...
If it jumped timing; the leakdown test would have revealed that as one valve or another would likely be open at the wrong time.
View your logs and make sure that there is not too much fuel being dumped in at the wrong time. Also, make sure your turbo is actually spinning. I had an exhaust gasket fall apart and shoot up to my turbo and jam up the hot side wheel at one time. An easy test would be to load in a neutral map (where no fuel is added anywhere) and remove the c-clip from the wastegate actuator and then wire the wastegate open with some bailing wire or a zip tie. Doing that will eliminate the possibility that its turbo related. Also, check the plugs. Are they black because of too much fuel or white due to too little fuel?
Also, go into your programming and double check that you have the correct before and after values entered in for your injector sizes.
Report back.
PhilSine is offline   Reply With Quote
Old 02-19-2009, 02:55 PM   #12
2.5rsDOHC
Member#: 54820
1998 2.4 RS-T
hybrid\stroker
ok so I just went out and fired it up turbo was spining freely but I dont have a neutral map to load up but it seemed fine, oh btw I have a ewg so no need to wire the actuator
and the plugs were just replaced 2 days ago from where they had fouled out
injector values checked and set at 280cc and 720cc
but about viewing the logs what areas do I need to load on to the logger to read while I log the info, and how can I acess the saved datalog files so i could post them for you to see and tell me what you think?
Old 02-19-2009, 04:21 PM   #13
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
12 Legacy GT 13 Armada
Curious, did you hard wire your EMU in or use Philsine's DB25 connector method?
MY99 2.5GT is offline   Reply With Quote
Old 02-19-2009, 05:35 PM   #14
2.5rsDOHC
Member#: 54820
1998 2.4 RS-T
hybrid\stroker
I started to use the DB25 connecter idea but backed out and its just hard wired in now but it is using PhilSine's diagram
Old 02-20-2009, 05:22 PM   #15
#522
Member#: 2185
01 RS
swirly blue
I would log:
Airflow IN OUT
INJ IN OUT
IGN IN OUT
RPM
VEH SPEED (had another car once that thought it was going 100mph all the time)
PSI
AFR (if connected)
Throttle.
That should do it, so just about everything. If you click start, log the data for a bit maybe rev it up some etc, then click stop. You can then click the little save icon in the logger window and save it where ever you want. Then, post it someplace on the net, and one of us can download, load into our logger and play it back. If you don't want to post, email it to one of us. You can pm me if you like for my email, not sure I will be able to look at it this weekend though.
Old 02-20-2009, 06:17 PM   #16
freeride
Member#: 49783
2000 2.5rsti&98wagon
SRP/white
Seems if you have the water temp and tps tapped then that might explain the low input. EGR i'm not sure about.
freeride is offline   Reply With Quote
Old 02-20-2009, 07:31 PM   #17
2.5rsDOHC
Member#: 54820
1998 2.4 RS-T
hybrid\stroker
Originally Posted by #522 View Post
I would log:
Airflow IN OUT
INJ IN OUT
IGN IN OUT
RPM
PSI
AFR (if connected)
Throttle.
whats your e-mail adress?
Old 02-20-2009, 11:38 PM   #18
PhilSine
Member#: 130489
02 WRX Wagon (WRB)
A bit of advice when saving data logs...
For the file name, save it by the date and time you made the log. this will make it easier for you to remember which was your latest.
example...
A log made on Feb 20th at 5:12 PM would be 02202009_1712
Use the underscore instead of a space when separating the time since some uploaders won't recognize a space and may kick back teh file or say invalid name.
Old 02-21-2009, 12:20 PM   #19
2.5rsDOHC
Member#: 54820
1998 2.4 RS-T
hybrid\stroker
ok so I cant figure out how to attach the files on here now lol
Inspection fail, desperate for help or ideas... jeepwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 25 10-22-2009 10:15 PM
Desperate for help smileyou Southern California Impreza Club Forum -- SCIC 15 08-09-2007 11:38 AM
Desperate for Help with Cobb AP.. Please help Flyguy3663 Engine Management & Tuning 5 10-08-2005 05:14 PM
Houston: Desperate for springs help. NeoteriX Texas Impreza Club Forum -- TXIC 32 06-03-2004 01:30 PM
PNWSEC MEET TSHIRTS - desperate plea for help! Subie Gal North West Impreza Club Forum -- NWIC 13 05-11-2002 01:17 AM
