Old 02-14-2009, 05:58 PM   #1
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Default STi Brembo on rear of WRX..where to get bracket and parking brake shoes?
Im looking for the Dogbone adapter to mount the STi Brembos on the rear of a 02 WRX. Ive heard the Kartboy IHI 2-pot bracket works, but then Ive heard it dosent.
Im also looking for the thicker parking brake shoes for the rear so I can use a 04 STi rotor. I dont want to have to run a special rotor.
Old 02-14-2009, 06:12 PM   #2
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
brake supersticky -> STi brembo FAQ?
Old 02-14-2009, 06:27 PM   #3
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Answers neither question. Unless Im retarded, Ive read and reread that.
Old 02-14-2009, 06:42 PM   #4
Butt Dyno
Member#: 17301
is the "dark side"
OK, just checkin'. If it misses stuff we can add it.
Old 02-14-2009, 07:18 PM   #5
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
After further research, it looks like this is what Im going to buy.
DBA 4000 Rear brembo Adapter Kit from MachV (fastwrx)
http://www.fastwrx.com/rebradkit.html
Will be going with DBA 4000 04 STi front rotors.
Old 02-14-2009, 07:23 PM   #6
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Also, MachV sells the rotor or brackets seperately.
Old 02-14-2009, 07:39 PM   #7
Rexwagon03
Member#: 127429
2006 Legacy GT Limit
thats spendy
Rexwagon03 is offline   Reply With Quote
Old 02-14-2009, 07:41 PM   #8
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
yup that's how I'd do it
although for future reference I *think* the 'special' brake shoes are only available from Godspeed in the UK
UkNuck is offline   Reply With Quote
Old 02-14-2009, 07:44 PM   #9
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Yeah I found the adapter shoes from Godspeed.
http://www.godspeedbrakes.co.uk/Suba...ar_classic.htm
Old 02-14-2009, 07:48 PM   #10
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Originally Posted by Rexwagon03 View Post
thats spendy
Retail for kit: $569
DBA 4000 STi Rear (for comparo) $283
Kartboy Dogbone Bracket for FHI 2-pots: $225
Total: $508. $61 less than the MachV kit. Thats not outrageous.
Old 02-14-2009, 07:57 PM   #11
Butt Dyno
Member#: 17301
is the "dark side"
The sticky did mention the MachV stuff FWIW. But I added this thread just to be complete. I am not sure we had a link that covered the godspeed stuff.
Old 02-14-2009, 08:57 PM   #12
tom@kartboy
Member#: 67
1999 Outlasting
the competition.
i cannot say for a fact if our adapters work with the brembos. We only make them to fit the Red FHI 2 pots. if you modify the adapters to fit all the better for you.
Tom
Old 02-14-2009, 10:46 PM   #13
JO'S TR
Member#: 127012
2006 WRX 18g+Meth
6spd WRB
Im putting brembo's on my 06 wrx, and from what I have seen the rear 2 pots caliper on the "brembo" and the FHI are the same. the rebuild kit are the same factory part #. the only differance is the "dogbone" bracket the brembo bracket is a little taller to compensate for the bigger rotors.
sorry for the rambling just passing it on.
JO'S TR is offline   Reply With Quote
Old 02-15-2009, 04:29 AM   #14
jamal
Member#: 71875
98 2.5GT
my wheels fit
The mounting holes on the sti and the 06-07 wrx are in the same place. The brembo caliper itself is taller to account for the different rotors. I'd expect it's possible to make a bracket that will work for either.
jamal is offline   Reply With Quote
Old 02-15-2009, 09:20 AM   #15
Ian Godney
Member#: 41573
1999 Subaru RB5
Grey
This kit works out at about 360 dollars including shipping to the US
Ian Godney is offline   Reply With Quote
Old 02-15-2009, 09:24 AM   #16
ray101381
Member#: 131327
2013 2014 BMW M5 CP
BMW Individual LSB
i have brembos on my 07 wrx, all you need to do to get them to work properly is either get the shims for the ebrake and use 04 sti rotors or just get the dba adapter rotors, the other thing is to drill the spot welds out of the dust shield and that's it, and they'll bolt right up
ray101381 is offline   Reply With Quote
Old 02-15-2009, 09:38 AM   #17
axelthrasher
Member#: 144779
200X ZOMG a car 100%
crabon fibre girlfrendorz
What are the differences from the Brembos to the IHI 2-pot kit?
I have been looking into this for a while and I am thinking that I will just end up going with the IHI kit because it can be had for cheaper. Does anyone know the weight of both kits or the size of the discs?
axelthrasher is offline   Reply With Quote
Old 02-15-2009, 10:01 AM   #18
Daishi00
Member#: 78952
2005 WRX
CGM
Larger rotor on the Brembo's and that coupled with different piston sizes equates to a different rear brake bias over the FHI units.
Daishi00 is offline   Reply With Quote
Old 04-27-2009, 10:17 PM   #19
bfontana@india.com
Member#: 182785
2008 Subaru
hey anybody know what the story if for 08+ cars wanting to use rear brembos?
bfontana@india.com is offline   Reply With Quote
Old 06-23-2009, 02:46 PM   #20
turbochico
Member#: 212067
2003 WRX
ok I've mounted brembo rear calipers from an 04 STI on my 03 wrx with the godspeed brackets and installed the godspeed fat shoes. I will install the fronts once I get the bolts for the brembo calipers. The adapter brackets are easy to install, and they seem stout. (only time and a lot of hard braking will tell) I did notice that the caliper was not completely centered on the rotor forcing one piston (inner) to be a bit more out than the other. A pro told there should be no problem.
Installing the fat shoes was a bit more of a chore than I thought it would be. My ebrake handle feels softer and goes all the way up and a bit of power on the engine will overpower them. don't know if this is due to the godspeed pads or me not adjusting the brakes enough. will let you know next week.
I also have the biggest air bubble in my brake lines (I popped a front caliper cylinder by being a total noob) so I can't tell you if the brembo brakes are better or not. again, I will tell you next week once I get this air chamber out of my brake lines.
Note: you will need to cut or preferably mallet out the rear rotor shield out of the way for the bigger rotor.
turbochico is offline   Reply With Quote
Old 07-05-2009, 01:01 AM   #21
modliving
Member#: 161273
2008 forester xt
where do you get these shims?
modliving is offline   Reply With Quote
Old 07-05-2009, 01:34 PM   #22
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
these brackets seem very weak to me. are they alu or steel? they apear to be very thin. on my old 06 i ran the adapter rotors from dan and they worked great.
PARANOID56 is offline   Reply With Quote
Old 10-23-2009, 04:13 PM   #23
outlwstr
Member#: 102201
Tom
woudnt it be of interest of your company to start producing adaptors for brembos. This is a commen swap but not many choices available for brackets or adaptors not to mention the price.
-Kyle
outlwstr is offline   Reply With Quote
Old 10-23-2009, 05:24 PM   #24
tom@kartboy
Member#: 67
1999 Outlasting
the competition.
-Kyle
I believe machv.com and wrxbrakes.com sell the adapters and rear rotors to make them work.
might try them first
Old 10-23-2009, 10:39 PM   #25
charlesdixon
Member#: 161345
2005 AW STi
Stage Poo
Can someone school me? I've searched I promise.
06 WRX going to swap in 04 STi brembo front and rear calipers and 04 STi rotors, also front and rear.
I know I need the DBA STi adapter rotors to retain usage of the hand brake but, can i use the 04 STi rear rotors on my 06 WRX on a temp basis until i can get the adapter rotors ordered? I know i will lose usage of my hand brake, but i honest hardly ever use it.
And before i get yelled at, my car is an automatic not manual, so again, i almost never use the hand brake.
Cliff note: will 04 STi rear rotors work on 06 WRX with 04 STi rear brembos.
charlesdixon is offline   Reply With Quote
how to remove rotor when parking brake shoes seized to the inside of top hat? glepko Brakes, Steering & Suspension 3 05-24-2010 11:59 PM
anybody know where to get a pass.front. brake caliper bolt? ultraspdWRX Brakes, Steering & Suspension 18 06-25-2006 08:26 PM
anyone know where to get brackets for 02-03 foglight covers? djcttb Interior & Exterior Modification 9 07-18-2005 10:45 PM
where to get front and rear rotors? 99SubRs Brakes, Steering & Suspension 4 06-30-2002 12:52 AM
Where to get bushings and strut top mounts for new WRX? jmott Brakes, Steering & Suspension 1 06-13-2001 08:30 PM
