Go Back   NASIOC > NASIOC General > Motorsports > Autocross
Old 02-14-2009, 05:52 PM   #1
S1MPSONS
Member#: 90357
2006 Corey's EVO
& 1993 Mazda RX7
Default Quick Q: SCCA Solo *SP Legal?
Is a Greddy Pressure Relief Valve *SP Legal?
http://4autoshop.com/Greddy-Pressure...source=froogle
S1MPSONS is offline   Reply With Quote
Old 02-14-2009, 07:20 PM   #2
van_dutch
Member#: 198633
2004 WRX
In the 2009 SCCA Solo rules I found the following: 15.10C4d states "No changes are permitted to blow-off/pop-off valves." That would be a no.
van_dutch is offline   Reply With Quote
Old 02-14-2009, 08:55 PM   #3
KC
Member#: 442
16 SS
00 S2000
e) Compressor bypass valves (CBVs) are considered part of the air intake system, and may be added, replaced or updated/backdated independently of the other components of a forced induction system.
The Subaru uses a CBV, not a blowoff valve. Since it also attaches directly to the I/C, which is also changeable, I believe it is also legal.
However, if it's not a Subaru, it depends on what the FSM calls it. The Nissan product you linked to wouldn't be legal if the Nissan FSM calls it a Blowoff/Pop-off valve.
--kC
KC is offline   Reply With Quote
Old 02-14-2009, 09:05 PM   #4
S1MPSONS
Member#: 90357
2006 Corey's EVO
& 1993 Mazda RX7
ask for my 93 Rx7
Old 02-14-2009, 09:11 PM   #5
KC
Member#: 442
16 SS
00 S2000
Originally Posted by S1MPSONS View Post
ask for my 93 Rx7
Depends on what the factory service manual calls it.
--kC
Old 02-14-2009, 09:15 PM   #6
Mechie3
Member#: 120152
From the SCCA's standpoint, why the different ruling on BPV/CBV versus a car that comes stock with BOV?
Mechie3 is offline   Reply With Quote
Old 02-14-2009, 09:30 PM   #7
van_dutch
Member#: 198633
2004 WRX
If this is for an FD, did you swap the radiator? That is one of the first things done to an FD for reliability reasons as the stock radiator is terrible. That automatically puts you in SM2 and this is no longer an issue. I would recommend posting on the Solo forum for a better answer. I read the rules as a different recirc valve would be acceptable in ASP but switching to a BOV/POV is not legal. That, however is just my reading. I don't think you would run up against huge protest if you did run in ASP and it was not legal, however.
Old 02-14-2009, 09:47 PM   #8
Mechie3
Member#: 120152
^^ New rules for 2009 allow changes to the stock radiator as long as weight/dimensions are >= stock for SP classes.
Edit: 15.10.L
Old 02-14-2009, 10:01 PM   #9
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
JDM Speedwagon 3 LSDs..:)
Not true....Brakes and Radiators are free to switch now...as long as the radiator is the same size or bigger than stock...
Brakes are pretty much WIDE open now..including Aluminum 2 pc rotor and multipiston Calipers...
Just received my 2009 Rule book...
most of this has been covered in last yrs fasttracks...
Bill
Old 02-14-2009, 10:29 PM   #10
S1MPSONS
Member#: 90357
2006 Corey's EVO
& 1993 Mazda RX7
if I'm not mistaken, this part works independant of the BPV and throttle position.
Old 02-14-2009, 10:32 PM   #11
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
For Subaru's....Aftermarket BPV are Legal...for your app....not sure..:/
Old 02-14-2009, 10:51 PM   #12
espEVO
Member#: 97610
Is this thing a "safety" type valve? Like you set it so that it relieves pressure slightly about your target boost pressure so as not to esplode your motor.
If it's in addition to your CBV I would says it's not legal. Not sure if it would be allowed based on intake & intake mani being free to mod. If it's not performance enhancing (and it doesn't appear to be) then I don't see much issue with it. Might run into issues at an NT or Pro.
espEVO is offline   Reply With Quote
Old 02-15-2009, 07:40 AM   #13
KC
Member#: 442
16 SS
00 S2000
So this is in addition to the existing BPV on the car? No legal. It's not a compressor bypass valve (only thing allowed by the rules) that's being "added".
How it's vented? Where it vents to? Where in the process it vents, what pressure is it venting or prevented from being vented?
--kC
Old 02-15-2009, 08:11 AM   #14
Mechie3
Member#: 120152
--kC
Should have specified, from a performancing enhancing standpoint, why would the SCCA allow CBV's to be added/removed/etc but not BPV?
Old 02-15-2009, 10:24 AM   #15
S1MPSONS
Member#: 90357
2006 Corey's EVO
& 1993 Mazda RX7
Yes, it is a safety type valve exactly as you described. This would be in place in addition to the factory BPV.
SCCA Solo Weekend XIX - School and Solo missiceblast Alaskan Impreza Club Forum -- AKIC 21 06-04-2009 06:15 PM
Howard Duncan on legality of WRX options - SCCA Solo kelley nelson Motorsports 9 05-03-2001 11:50 AM
INR-SCCA Solo II - Sunday April 8 Karly Mid West Subaru Owners Club Forum -- MWSOC 0 04-03-2001 05:22 PM
Someone asked for the SCCA Solo I/II Schedule Luftyone Bay Area Impreza Club Forum -- BAIC 2 03-27-2001 01:42 PM
Portland SCCA Solo 2... Draken North West Impreza Club Forum -- NWIC 5 08-18-2000 01:58 PM
