Old 02-15-2009, 01:20 AM   #1
jeremywrx15554
Member#: 168567
2003 big 16g coming
fixing my 03 wrx
Talking 03 wrx 18g+meth tuned by AWDTUNING.COM
i went down to little elm and got my tune i will have to say i am very happy.thanks to keith he did a real good job.well i put down
340awhp,300awtq @ 25psi
just to let you know this is a 4 eat not a 5 speed!!!!!
my set-up is
my setup is
mhi 18g with a 14.7psi actuator
aps tmic
aps 65mm cai
aps tgv's deletes
aps turbo inlet
aps 50\50 bov
gt-spec headers wrapped
gt-spec up-pipe[no cat] wrapped
xs-power tbe down pipe wrapped[no cats]
gm bcs
modded wrx injectors flow tested 876cc
255lph walbro
vision fpr
nrg grounding kit
phenolic spacers grimmspeed 8mm
pully crank & alt.
turbo blanket
and all the heat sheilds.
smc methanol kit doing a 50\50 mix
ngk one step colder
suspension
perrin front end links
perrin 25 mm front sway bar
perrin rear end links
perrin 25 mm rear sway bar
whiteline sturt tower bar
axxiss f\r brake pads
215\55r16 tires
jeremywrx15554 is offline   Reply With Quote
Old 02-15-2009, 01:27 AM   #2
Iflysti06
Member#: 156955
2006 STI
UR GT35R w/ mad bolt ons
Nice numbers! Gotta a dyno graph by any chance?
Iflysti06 is offline   Reply With Quote
Old 02-15-2009, 01:30 AM   #3
jeremywrx15554
Member#: 168567
2003 big 16g coming
fixing my 03 wrx
nope i did'nt get one
Old 02-15-2009, 01:52 AM   #4
k04sti
Member#: 171773
04 wrx sti
jbp dom 3 xtr w meth!
Nice, do you know if you are maxing out your maf?
k04sti is offline   Reply With Quote
Old 02-15-2009, 02:15 AM   #5
focusfuri75
Member#: 142011
nice numbers!!!
focusfuri75 is offline   Reply With Quote
Old 02-15-2009, 07:02 AM   #6
testes1010
Member#: 47145
2012 Gas Saver
a 18G does not flow enough to max out the MAF(ie, 5volts). My TD05H-20G @24psi to redline pushed 4.90v on a stock sized inlet with MAF @ 370whp/355wtq.
really nice numbers for a 4eat.
testes1010 is offline   Reply With Quote
Old 02-15-2009, 08:51 AM   #7
c'dalerider
Member#: 92388
04 WRX, 06 STI
wrb x 2,900awhp combo
x1000.
I did not see any trany mods in the OP. Get some trany work done like hstc and vb.
fwiw....my AT '04 tuned to 300/260 (18g, smc 50/50...almost exact setup as OP) got an easy 1.53 60', 12.3sec @ 112mph 1/4mile pass. Your car could get into the very low 12s and Id say into 11's with a good launch...IF she pulls on the road like the dyno numbers show!
c'dalerider is offline   Reply With Quote
Old 02-15-2009, 09:05 AM   #8
big16gwrx
Member#: 129459
yeah... i beg to differ... mine is maxed out on an 18g also.... but i do not have a stock turbo inlet...
big16gwrx is offline   Reply With Quote
Old 02-15-2009, 09:17 AM   #9
WagonGGA
Member#: 134481
08/4 Subaru
Legacy Spec B/Forester XT
I maxxed out my MAF on a VF22 running c16. Had to get a Big Maf for my 18g Setup on C16 too.
WagonGGA is offline   Reply With Quote
Old 02-15-2009, 12:32 PM   #10
k04sti
Member#: 171773
04 wrx sti
Lol....
Old 02-15-2009, 04:19 PM   #11
testes1010
Member#: 47145
2012 Gas Saver
Differ all you want. If your MAF was not hitting 5.0v it was not maxed. MANY tuners will tell you its maxed(IMHO a sales ploy) when it hit the 'factory' 4.7v CEL, however the MAF is NOT maxed. You simply raise the CEL limit to 5.0v & rescale the MAF scalar and you just gave yourself another 100crank hp of headroom. The 5.0v equates to +350g/sec(and roughly 475chp) of air flow thru the MAF.
Please show me some logs of your VF22(or 18G for that matter) on any fuel flowing rates even close to 5.0v & I'll retract my BS flag. 4.7v is roughly 325-330whp on a dynojet dyno.
Code:
mafv g/s lb/min hp
2.00 16.81 2.22 22
2.05 18.33 2.42 24
2.10 19.93 2.64 26
2.15 21.62 2.86 29
2.20 23.41 3.10 31
2.25 25.30 3.35 33
2.30 27.29 3.61 36
2.35 29.38 3.89 39
2.40 31.58 4.18 42
2.45 33.89 4.48 45
2.50 36.31 4.80 48
2.55 38.85 5.14 51
2.60 41.50 5.49 55
2.65 44.28 5.86 59
2.70 47.17 6.24 62
2.75 50.19 6.64 66
2.80 53.34 7.06 71
2.85 56.62 7.49 75
2.90 60.04 7.94 79
2.95 63.59 8.41 84
3.00 67.27 8.90 89
3.05 71.10 9.41 94
3.10 75.08 9.93 99
3.15 79.20 10.48 105
3.20 83.47 11.04 110
3.25 87.90 11.63 116
3.30 92.47 12.23 122
3.35 97.21 12.86 129
3.40 102.11 13.51 135
3.45 107.17 14.18 142
3.50 112.39 14.87 149
3.55 117.79 15.58 156
3.60 123.35 16.32 163
3.65 129.09 17.08 171
3.70 135.01 17.86 179
3.75 141.10 18.67 187
3.80 147.38 19.50 195
3.85 153.84 20.35 204
3.90 160.49 21.23 212
3.95 167.33 22.14 221
4.00 174.36 23.07 231
4.05 181.58 24.02 240
4.10 189.01 25.01 250
4.15 196.63 26.01 260
4.20 204.46 27.05 271
4.25 212.50 28.11 281
4.30 220.74 29.20 292
4.35 229.20 30.32 303
4.40 237.87 31.47 315
4.45 246.76 32.65 326
4.50 255.86 33.85 339
4.55 265.19 35.09 351
4.60 274.75 36.35 363
4.65 284.53 37.64 376
4.70 294.54 38.97 390
4.75 304.79 40.32 403
4.80 315.27 41.71 417
4.85 325.99 43.13 431
4.90 336.95 44.58 446
4.95 348.16 46.06 461
5.00 359.61 47.58 476
5.05 371.31 49.12 491
Perfect example of a the 'sales ploy' I mentioned. Nothing at all against P&L, I think they make great products but this is the same misinformation at its finest:
http://www.pandlmotorsports.com/osCo...a04fcda415899f
Utilizing a full 3" cross section, the intake is designed to offer MAF resolution up to 450HP on a Subaru non drive-by wire ECU (limited to 4.74 MAF volts), and up to 500HP on a Subaru drive-by wire ECU which goes up to a full 5 MAF volts.
Old 02-15-2009, 06:13 PM   #12
autowagon
Member#: 42933
03 WRX (ej257 swap
black
what are these numbers from? They are very high. I've had a super16g (close to 18g flow) maxed (for pump gas) which hit 270 on a mustang dyno at sea lvl. Then i switched to a td06 20g and got my 4eat fully built. my tuner threw me a curveball and said he recalibrated the dyno after he changed the name of the shop which netted me a whopping 270whp on the same dyno with the bigger turbo. So bassically i've found over the years that 300 on a 4eat is damn hard to get.
autowagon is offline   Reply With Quote
Old 02-16-2009, 10:02 AM   #13
ownnij
Member#: 70459
2002 AW Bugeye ej257
6spd, GT3076R, Alky & EWG
hmmm i want to drive a automatic wrx with 350whp. how do you launch in those things?
ownnij is offline   Reply With Quote
Old 02-16-2009, 11:11 AM   #14
jeremywrx15554
Member#: 168567
2003 big 16g coming
fixing my 03 wrx
i can launch it at about 3700 rpm's but i have not done it because i do not want to tear up my tranny
Old 02-16-2009, 11:57 AM   #15
BlueRallyWrx
Member#: 104876
2003 WRX, HEMI Jeep,
DD Honda Accord
Nice numbers!
BlueRallyWrx is offline   Reply With Quote
Old 02-16-2009, 12:31 PM   #16
20wrx05
Member#: 177861
1999 Built! RSTI
FP Red, E85, IM FAST!
lets see the car !!
20wrx05 is offline   Reply With Quote
Old 02-16-2009, 12:42 PM   #17
The Beej
Member#: 99677
2004 wrx
aspen white
got any pics of that smc meth kit? i really want to get one.
The Beej is offline   Reply With Quote
Old 02-16-2009, 12:54 PM   #18
jeremywrx15554
Member#: 168567
2003 big 16g coming
fixing my 03 wrx
here you go it is nothing special
Old 02-16-2009, 01:29 PM   #19
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
18G with 25psi and every bolt on attatched to the motor? Why is this hard to understand?
Steve.804 is offline   Reply With Quote
Old 02-16-2009, 01:39 PM   #20
jeremywrx15554
Member#: 168567
2003 big 16g coming
fixing my 03 wrx
here is another 4 eat with a evoIII no meth that broke 300awhp
http://forums.nasioc.com/forums/show...9#post25163699
Old 02-21-2009, 02:07 PM   #21
autowagon
Member#: 42933
03 WRX (ej257 swap
black
Yes, i see you can read too. What dyno?
Old 02-21-2009, 02:46 PM   #22
jeremywrx15554
Member#: 168567
2003 big 16g coming
fixing my 03 wrx
this was on keith's software but this software is very accurate and has been compared with actual dynos, such as the dyno at Engline Logics (Houston).
Keith tuned a car and got the numbers from his program, the very next day it was put on the dyno because some people believed the numbers were inflated. Needless to say, the numbers were pretty much identical to the dyno, which was a mustang dyno if I remember correctly.
Old 02-21-2009, 04:45 PM   #23
GDB FAN
Member#: 105814
Wow, really nice numbers for a 4eat!!
As said above, you dont have any trans mods correct?
GDB FAN is offline   Reply With Quote
Old 02-21-2009, 05:14 PM   #24
k04sti
Member#: 171773
04 wrx sti
So, basically who cares. It's just numbers.
Old 02-21-2009, 06:00 PM   #25
jeremywrx15554
Member#: 168567
2003 big 16g coming
fixing my 03 wrx
Subaru Banner
nope not yet....
we will see how it holds up
Just tuned by AWDTuning.com drsnobiz Engine Management & Tuning 0 04-27-2009 02:33 PM
03 wrx 18g+meth @ 26psi on feb.14 jeremywrx15554 Proven Power Bragging 13 02-24-2009 08:22 PM
03 wrx 18g+meth tuned by AWDTUNING.COM jeremywrx15554 Texas Impreza Club Forum -- TXIC 4 02-15-2009 03:28 PM
