Old 02-15-2009, 09:13 AM   #1
Trevor723
Member#: 57989
2013 Golf TDI
united gray
Default Reputable source for jdm transmission? Swapping into 07 wrx q's..
After a few weeks now of studying up on transmission options and hours spent on gear/speed calculators for my 07 wrx I've come to the conclusion that I want to run what I've come to call the "legacy GT" gears with a 4.44 final drive.
1st: 3.166 2nd: 1.882 3rd: 1.296 4th: .972 5th: .780
Going off the transmission chart there are a number of differenent transmissions with this configuration. Is there a reliable source to get a good condition box? Is there a particular transmission code that is better than others? Rear diff sources as well? So far I have come up with FXT at/mt, 00-01 auto RS, 05+ outback xt mt.
Secondary questions: I am changing to a pull style clutch with this, obviously. Anyone have a part number for the correct slave cylinder? Also is the bracketing the same for the push/pull slave cylinders?
Do the speedo sensor plugs match up? It's my understanding that the speedo gears are different for each fd so as long as the plugs match up my speedometer will remain accurate?
Thanks!
Trevor723 is offline   Reply With Quote
What Transmissions Swap into a 2002 WRX? TRD11 Transmission (AT/MT) & Driveline 15 09-18-2011 09:35 AM
Driveshaft for Six Speed Swap into 02 WRX VipersEatLotus Transmission (AT/MT) & Driveline 4 03-19-2010 08:55 PM
vf48 swap into 07 wrx WR-eX (Honda) Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 18 12-16-2008 10:59 PM
Good source for JDM transmissions codemunky Southern California Impreza Club Forum -- SCIC 4 06-06-2008 03:28 AM
JDM V7 swap into 2002 WRX, Will it pass NYS inspection?? jonepachek Subaru Conversions 1 08-20-2005 01:25 PM
