Old 02-15-2009, 03:37 PM   #1
leftho0k
Member#: 177589
Default EJ22-T SWAP -93 ss
Does anyone know for shure if a 1991 legacy turbo long block will be a "bolt in" swap for my 93 ss turbo long block?
leftho0k is offline   Reply With Quote
Old 02-15-2009, 03:44 PM   #2
leftho0k
Member#: 177589
I see a few reasonably priced 22-t's on "car-part.com" but they are from 91 ss's can I swap them right in no prob.? what will bolt in in place least ammount of bulls#itting. I am a full time Toyota student @ co-greene in hudson, it is a 45min. drive and I need my car back on the road asap. this is my last semister, i am broke as hell and cant afford to miss any days.
I am looking to buy a good ej22t long block near 12477.
Old 02-15-2009, 04:25 PM   #3
leftho0k
Member#: 177589
I met a guy who had ECS put a jdm ej 2o in his ss. I have a 96 ej22 but it has the siamease port exhaust so i dont see swapping that in as an option. i used to have a 1.8 and it was dual port. should i, or could i stop by the pick n' pull and see if they will give me an old leaky 1.8 and i then use the factory ss ecu to run say 7lbs boost on the 1.8? hehe?? is that a possibility? or am i dreaming and really i will have to part with a kidney to get my ss back on the road?
Old 02-15-2009, 05:25 PM   #4
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
All years of Ej22T are interchangeable. There's no difference between a '91 and a '93.
You can also fairly easily install an EJ20G inro your car. I've got a thread here in this forum about doing it. I did it on my '91.
Old 02-15-2009, 08:54 PM   #5
leftho0k
Member#: 177589
thanks alot, I see a 91 22t long block for 350$ in mass. any one know a better deal quick or would this be the best thing nearest to me?
Old 02-15-2009, 09:01 PM   #6
Matt Monson
Member#: 832
99 2.5RS, '85 911
That's a screaming deal on that. The Ej22T blocks have become rare and desireable. I've sold a few of them, block only, in the $500-800 range. You can easily sell your core for $350 once you get it out of the car. Just put it in your regional forum here or on Ebay and it will go away quickly.
Old 02-15-2009, 09:17 PM   #7
RallyColtTurbo
Member#: 16819
Originally Posted by Matt Monson View Post
........You can easily sell your core for $350 once you get it out of the car...........
Originally Posted by leftho0k View Post
...... I have a hole in the cank case. ....
Matts always keeping us on our toes, somebody has to return the favor.
Either way, I agree with Matt, that's a good deal.
Another option for stock or close to stock power levels, is to replace the shortblock with a N/A one (keep the turbo heads). Compression will go up, but at stock boost levels it will be fine. There are a few Lc members that have bought cars and driven then for a (long) while only to discover upon the eventual teardown that someone in the past has installed a N/A shortblock. Some believe that dealers may have even installed a few when actual EJ22T shortblocks were 'sold out'.
RallyColtTurbo is offline   Reply With Quote
Old 02-16-2009, 10:23 AM   #8
Matt Monson
Member#: 832
99 2.5RS, '85 911
Busted. I didn't read the story, just the opening question.
Old 02-16-2009, 02:00 PM   #9
leftho0k
Member#: 177589
MILLIS AUTO in MILLIS, MA is a scam opperation, they clearly tried to "bait and switch" on me. when i got there they were insisting that a na labled with a turbo tag was a turbo and they wanted me to take to na 22 as a turbo.... only thing is im not that gulible and can clearly see the difference. watch out for millis auto!
Last edited by leftho0k; 03-16-2009 at 11:48 AM. Reason: millis tried to scam a brother
Old 03-16-2009, 11:37 AM   #10
leftho0k
Member#: 177589
thanks agian, I have been driving around on the 91 longblock for 2 weeks now. only thing to mention is that at the last min. of the swap when i was putting all the hoses back on and connecting the wiring, I had to keep my 93 engine wiring harness because the 91's was different.
Old 03-16-2009, 11:43 AM   #11
leftho0k
Member#: 177589
also what was retarted was that the throwout bearing wouldnt let go of the press. plate so i had to do it "torque converter style" and take all the bolts out that hold the press. plate to the flywheel to get it done without worry of braking something.
Has anyone else had that happen to them? Is the problem i had just it being bound up or is there some thing i was doing wrong, like a clip holding the throwout to the diaphram spring ??? ... runs great now though like i said just was a pia and i was in a hurry.
Old 03-16-2009, 02:27 PM   #12
RallyColtTurbo
Member#: 16819
It's designed that way. The bearing stays with the pressure plate.
You need to pull the pivot shaft that holds the release fork. Then the fork will drop out of the release bearing and you can pull the trans.
Old 03-16-2009, 02:52 PM   #13
Matt Monson
Member#: 832
99 2.5RS, '85 911
Doing such things without a proper manual tends to make it take longer. I am just saying...
Old 03-16-2009, 07:16 PM   #14
leftho0k
Member#: 177589
Is the pivot shaft behind the hex cap screw to the far left in that picture? I have access to strap on's shop-key and was referencing it at the time and here I will quote there procedure that left me ignorant. somebody should tell snap-on they are so general with there procedures it makes them look bad when you have to pay for that kind of MISINFORMATION."
http://img15.imageshack.us/gal.php?g=straponsux.jpg "
yeah thanks Matt,at the time my ex-boss was around and i asked him wtf was going on, he had said to remove the pivot shaft, i took out that hex cap thing (size of a quarter) and saw like a stud behind it. i was un shure about trying to drive it out or something so i just went with the shure thing, the p.i.a. press.plate bolts. well next time... it will be easier. thank you agian for your insight.
EJ22T into 93 L Wagon 5spd/EJ22 into 93 SS auto swap. WagonMafia01 Subaru Conversions 13 06-01-2009 03:51 PM
Cruise control from 93 SS into 95L vica153 Electrical & Lighting 9 09-07-2006 12:50 PM
Swap help? 93 SS --->>> 95 L vica153 Mid West Subaru Owners Club Forum -- MWSOC 18 08-10-2006 10:49 PM
89 ej22 conversion to 93 ej20t rs wiring problems askep18 Newbies & FAQs 1 06-03-2005 05:55 PM
Has anyone done a 98 N/A EJ22 into a 93-95 EJ18 swap? Kostamojen Subaru Conversions 3 06-05-2004 12:40 AM
