Old 02-16-2009, 01:24 AM   #1
Mikeyb133
Member#: 160435
2000 GF 2.2
Default 00 OBS suspension
i was wondering if anyone had any information on a performance lateral link set up and trailing arms. i dont think pinks would would work but if someones done it let me know
Mikeyb133 is offline   Reply With Quote
Old 02-16-2009, 02:02 AM   #2
Seraphinwolf
Member#: 150922
97 OBS EZ30R
94SVX LSi Bourduex Pearl
You can use just about anything that will fit 93-07 Imprezas. Easiest to just look for RS stuff. Shoot over to RS25.com and you'll find more information on your aplication than here on NASIOC.
-Gaddis
Seraphinwolf is offline   Reply With Quote
Old 02-24-2009, 11:18 PM   #3
Mikeyb133
Member#: 160435
2000 GF 2.2
then if those fit, will the sti coilovers(pinks) work as well?
Old 02-25-2009, 12:30 PM   #4
linsavy
Member#: 11620
1997 GF4-STiV3 clone
Stuff after 01, won't fit for the most part. You want to stick with GC and GF chassis parts. There are both STi and aftermarket lateral links and trailing arm set ups. About $800 on ebay for the aftermarket stuff.
Some later model stuff fits/some doesn't, sometimes it fits but won't give you the preformance you are looking for.
linsavy is offline   Reply With Quote
Old 02-25-2009, 09:28 PM   #5
MeadowsMan
Member#: 169342
1998 Sleeper
Black n Tan
are you asking about coilovers or linkage?
i have wrx lat links on my obs and stance makes coilovers for the gf chasis
MeadowsMan is offline   Reply With Quote
Old 02-26-2009, 02:14 AM   #6
Mikeyb133
Member#: 160435
2000 GF 2.2
i know the lat links will work, now i was just wondering about coilovers. lke people have stated and i've also heard GC works on GF
Old 02-26-2009, 12:00 PM   #7
linsavy
Member#: 11620
GC = GF, the differences are body panels and few minor things. (spring rates, ride height, strut rates, axel thickness, gear ratios, fender struts) WRX lat links fit, but they are longer so the track changes and you have to fix the geometry and roll the fenders for decent sized tires. They offer no benefit over stock GC/GF lat links. If you want to spherical joints and stronger links then get the GC aftermarket stuff that fits properly.
I recommend coilovers and top mounts specific to the GC/GF check out Hotbits.
Old 02-27-2009, 06:39 AM   #8
Mikeyb133
Member#: 160435
2000 GF 2.2
thanks for the insight, i think im guna go cusco all around
Old 03-06-2009, 12:18 PM   #9
Ninja007
Member#: 150637
02 WRX Wagon
96 Impreza, 06 STI
Cusco is a good idea - I just installed GC specific Cusco coilovers on my brighton and they went in without a hitch and are nicely adjustable.
Coilovers made for WRX's will bolt up, but have different tabs for the brake lines and will probably have a different ride height on your GC.
As for lateral links, I am running Beatrush adjustable WRX links. At their shortest adjustment they are the exact same length as the stock GC links.
Keep in mind that whenever you adjust the lateral links your RSB mounting location will move as well..... I ran into this issue when I tried to bolt up my Perrin WRX bar. I ended up having to mount the sway bar/endlink to outside of one lateral link and the inside of another one to get it to fit correctly.
GL
Ninja007 is offline   Reply With Quote
Old 03-06-2009, 01:04 PM   #10
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
I was looking at a few setups, I will be going with the STi pillowball units. Less adjustible parts means less likely for parts to move over time, but that's just me.
FuJi K is offline   Reply With Quote
Old 03-10-2009, 11:09 AM   #11
kirkdunkan
Member#: 205260
800$ is very high cost.
kirkdunkan is offline   Reply With Quote
NY: Parting out 00 OBS Impreza rayc Complete Car Part-Out 98 04-23-2007 11:22 AM
exhaust setup for my 00 OBS staticchmbr Normally Aspirated Powertrain 1 02-09-2007 02:32 PM
01-02 WRX wagon rear strut bar on 00 OBS? wfofromthegetgo Brakes, Steering & Suspension 3 02-14-2006 06:43 PM
wanted. 98-00 OBS hood parts mengy2 Private 'Wanted' Classifieds 1 01-28-2004 12:56 AM
00 obs body kits? SilencedImpreza Outback Forum 3 07-30-2003 10:06 AM
