Old 02-16-2009, 01:02 AM   #1
SubarusRmyThing
Member#: 203031
2005 Baja Turbo
White/Silver
Default Cruise control switchs and steering wheel swaps... Help please.
So heres the dilema. Ill post pictures to make this tangled web easier to follow. FYI, these are not our cars actual pictures. just ones i found on google.
Buddy #1, John, Has a 2005 2.5RSTi with the standard Impreza steering wheel.
Buddy #2, Vince, Has a 2004 Subaru WRX with the Momo Steering Wheel.
Then there is Me. i have a 2005 baja turbo with the standard Subaru Wheel.
And then the Steering Wheel thats causing all this drama, and the reason for this thread... The 2005+ STi Steering wheel.
Now heres whats going on.
Buddy 1, (john) wants The Momo Steering Wheel from Buddy 2 (vince) in his 2.5RS.
Me wants Buddy 1's, (john) 2.5RS steering Wheel in my Baja.
Buddy 2 (vince) wants the STi steering wheel in his WRX.
the 2.5RS Steering wheel cruise control lever is different than the wrx.
The RS the cruise control is turned on by a button on the lever. The wrx the cruise is turned on by a button on the dash.
The STi is turned on the same way as the RS.
and the Baja is turned on the same way as the wrx.
So this means all the levers are different. and are the wrong set up for each car.
So my question is..
Can we use the stock cars lever, with the new steering wheel? are they an easy swap? or how can we solve this issue thats stoping us from all gettin the steering wheel we want for dirt cheap.
need to figure this out asap. THank you!!
SubarusRmyThing is offline   Reply With Quote
Old 02-16-2009, 08:18 PM   #2
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
01 Legacy 95 Impreza L
I can tell you that I decided not to pursue installing the bigger stalk with the on/off switch into my 02 wrx wheel (which is just like the 04 pictured) The stalk is much bigger and does not mount the same way. I chose to reroute the on/off wiring as that seemed the easy of the two if that tells you anything.
You will also run into issues with the steering columns having different clock springs that are not interchangeable from one column to another.
If the stalks are the same, yes. If the stalks are different, not so easily.
my .02
mccanixx is offline   Reply With Quote
Old 02-17-2009, 12:50 AM   #3
SubarusRmyThing
Member#: 203031
2005 Baja Turbo
White/Silver
figures it would be a bitch. maybe ill say **** it and just snag me a momo and tell my other buddys tuff **** lol.
Old 12-31-2010, 10:13 PM   #4
Ryan321
Member#: 225014
2005 Impreza WRX STI
Sorry for the hijack, figured I would bring a old thread to life and try to help others in a similar predicament as us. Do you have the pin out for the cruise switch from the 2005 wheel? I have the stock 05 wheel in my 01 RS and I’m trying to set it up cruise control and need the pin outs in order to hook it up to the clock spring, if it’s even possible...
Ryan321 is offline   Reply With Quote
Old 01-01-2011, 04:49 PM   #5
TheLordChesterfield
Member#: 234539
Clock spring?
I merged an '04 STI ECU into an '04 forester harness that required rewiring the cruise switches. Which pinout's do you need?
In my case, the wires were all the same colors. Let me know if I can help.
TheLordChesterfield is offline   Reply With Quote
cruise control switch and Fog light switch illumination Bulb part # AFBeefcake Electrical & Lighting 3 03-13-2009 08:42 PM
UTEC and cruise control switching ataac_flat04 Engine Management & Tuning 11 03-17-2005 09:10 PM
WTB: Cruise control lever on steering wheel natmat Private 'Wanted' Classifieds 0 05-04-2004 05:23 AM
STi steering wheel swap successful; cruise control intact! Paulie Interior & Exterior Modification 19 04-09-2004 10:41 AM
Cruise Control and Steering Wheel Adapter slvrwrx02 Interior & Exterior Modification 9 10-10-2002 07:11 PM
