Welcome to the North American Subaru Impreza Owners Club Thursday September 1, 2016
Mid West Subaru Owners Club
Go Back   NASIOC > NASIOC Chapters > Mid West Subaru Owners Club Forum -- MWSOC > MWSOC Vendor Classifieds
Closed Thread
Old 02-16-2009, 02:50 AM   #1
GrimmSpeed
Vendor Sales Rating: (212)
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
Default 3-Port Boost Solenoid - GrimmSpeed Product Release
http://www.grimmspeed.com/catalog/pr...roducts_id=145
Price: 109.99
GrimmSpeed introduces the most complete and easy to use 3-Port Electronic Boost Solenoid available on the market. Our aftermarket boost controller allows you to raise the OEM boost levels in a quick and efficient manner. If you try to raise the boost on the weak OEM boost solenoid it will start to become unpredictable and unable to maintain proper and safe boost levels. Using our solenoid you are able to spool your turbo quicker and maintain a rock solid boost level. We have made our solenoid to withstand 120psi, way more than any Subaru will see.
Revolutionizing the Subaru boost solenoid market, we have created model specific install brackets that allow you to directly fit our Boost Solenoid into your Subaru for a factory fit. No more Zip-typing! We give you the factory fitment you have been waiting for.
Staying with the OEM fitment theme, our Boost Solenoid uses a Subaru style wiring harness so you can simply unplug your OEM solenoid andplug ours in. No more cutting the oem wiring and cripping wires together!
Also new to the Subaru boost solenoid market, we have used ultra low-profile hose fittings to keep the unit as small and clean as possible. The hose fittings are nickel plated brass so you don't have to worry about them snapping off like the plastic hose fittings!
Features:
  • Direct plug and play into oem wiring.
    MAC Valve has completely custom made the valve for us(only MAC valve on the market to be custom made for automotive tuning use).
  • Users can use AN fittings with the solenoid.
  • Mounting bracket so its a direct bolt on into factory location.
  • Low-profile brass hose fittings(small in size so its compact, no chance of breaking fittings like the plastic ones our competitors use).
  • Specifically designed by GrimmSpeed to work safely with the factory Subaru ECU (requires tuning) and to reliably handle the vibrations and temperatures of your engine bay!
  • The only direct “bolt in” design for all Subaru models. Direct bolt in mounting bracket and hardware included! (specify which model before ordering)
  • Includes plug and play harness, no wire splicing required and easy to return to stock.
  • Allows you to raise the factory boost levels with adding more response and more control.
  • Allows you to get full boost sooner.
  • Faster response and greater flow than any other valve out there. (by more than 10%!)
  • Nickel plated brass fittings. (unlike the competitors failure prone plastic fittings)
This BCS will handle all your boost control needs no matter what your power goals are.
Easy for your shop or tuner to tune!
3 bracket variations fit all Turbo Subaru models!
Solenoid and Bracket attached to 05+ LGT and 08+ WRX OEM bracket
Solenoid and Bracket attached to 08+ STi OEM Bracket
Tuner's comments
AWD Tuning:
"The GS 3 port boost control solenoid provides rapid boost response while maintaining the ability to make acute adjustments via turbo dynamics. While many other boost control solenoids react to adjustments too fast which can make them difficult to control with as much finesse as the stock bleed system. This solenoid can make micro-adjustments at the edge of target boost not only providing better spool, but overall more control. Additionally, the solenoid is plug n' play so you do not have to splice into the wiring harness for it's installation. "
Bullwinkle Tuning:
"The GrimmSpeed BCS is a compact, well designed unit. It's design as a 3-port solenoid provides better boost control then the stock bleed-type style. The unit is easy to tune for, as it behaves like many of the other 3-port solenoids already on the market.
Often, this enables a tuner to cut mapped wastegate duty cycles in half. This change in WGDC gives a tuner more granularity when tuning, and can yield much improved boost curves. In addition, the 3-port design often significantly improves spool.
Lastly, the GrimmSpeed BCS is almost silent when acting in the engine bay, unlike some of it's competitors. A great product, one I would recommend."
PRICE: 109.99
__________________
| AIM: GrimmSpd | Phone: 612-379-0000
Email:
GrimmSpeed is offline
Old 02-16-2009, 08:44 AM   #2
mccanixx
Member Sales Rating: (26)
Member#: 60566
2005 XT 5sp, 02 WRX
01 Legacy 95 Impreza L
Nicely done. You guys rock.
You'll be hearing from me soon.
Greg
mccanixx is offline
Old 02-16-2009, 09:11 AM   #3
Mechie3
Member Sales Rating: (51)
Member#: 120152
That's hot!
Mechie3 is offline
Old 02-16-2009, 09:01 PM   #4
coolblue05
Member Sales Rating: (436)
Member#: 39169
2008 Cayman S, C63
Tuned Perfection
Great guys, great looking product!
coolblue05 is offline
Old 05-10-2009, 08:19 PM   #5
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
just an FYI to the MWSOC guys, Matt over at 555 Motorsports will usually have these on his hands when he is tuning so you can get them from him.
Justin
__________________
Email:
Old 05-10-2009, 10:49 PM   #6
mpsti05
Member Sales Rating: (14)
Member#: 86741
05 STi.. Built
twinscroll35r Love/Hate
^Sweet, infact my brother is waiting for one so matt can finish the tune on his car!
mpsti05 is offline
Old 05-11-2009, 05:57 PM   #7
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
Yeah we've had to overnight a few of these to him recently so maybe thats one of them
Mike
__________________
Email:
Old 05-11-2009, 06:17 PM   #8
qc punk
Member Sales Rating: (3)
Member#: 83514
2006 tr
blue
I just bought one, should be at my door step tomorrow. And then a 555 tune.
qc punk is offline
Old 05-12-2009, 02:06 PM   #9
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
You should be one happy camper!
Mike
__________________
Email:
Old 05-12-2009, 08:34 PM   #10
gogetr
Member Sales Rating: (1)
Member#: 178631
02 shatdan
Mike
i hope i will be too! matts bringing me one down when he comes to tune.
i could check else where for this or send a pm but im lazy.
you guys have the high flow cross pipes and up pipes in stock??
gogetr is offline
Old 05-13-2009, 01:39 AM   #11
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
batch finish date on the xpipes and up pipes is early next week.
__________________
Email:
Old 08-10-2009, 07:35 PM   #12
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
All of the boost solenoids are in stock and ready to ship!!!
Mike
__________________
Email:
Old 08-14-2009, 06:39 PM   #13
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
Every tune can benefit from one of these! Way better boost response and cleaner delivery throughout the powerband!
Mike
__________________
Email:
Old 05-05-2010, 05:46 PM   #14
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
__________________
Email:
Old 06-04-2010, 11:12 PM   #15
BUBSKI
Member#: 245425
2007 impreza wrx sti
simple enough
BUBSKI is offline
Old 06-09-2010, 06:03 PM   #16
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
Yeah its really not too bad at all
Will
__________________
Email:
Old 06-10-2010, 04:00 PM   #17
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
__________________
Email:
Old 06-10-2010, 09:27 PM   #18
STi Hockey Guy
Member Sales Rating: (13)
Member#: 212589
12 135i
alpine white
got mine today... cant wait to get it on next week
STi Hockey Guy is offline
Old 06-11-2010, 10:41 AM   #19
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
Awesome! Let us know how it goes!
Will
__________________
Email:
Old 06-11-2010, 06:55 PM   #20
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
These are back in stock so place your orders soon before they are all taken up!
Will
__________________
Email:
Closed Thread
FS: NIB GrimmSpeed 3 Port Boost Solenoid Tussen Engine/Power/Exhaust 0 10-21-2009 03:36 PM
FS: Norcal Grimmspeed 3 Port Boost Solenoid New! Strider327 Engine/Power/Exhaust 7 04-16-2009 11:42 AM
fs: prodrive 3 port boost solenoid, oem solenoid, A/C se0ul Engine/Power/Exhaust 4 12-09-2008 06:00 PM
Prodrive 3-port boost solenoid, $75 shipped silverwrxmike Engine/Power/Exhaust 5 08-09-2006 01:19 PM
