Old 04-08-2002, 10:13 AM   #1
Darby
Member#: 17175
2002 Outback Beaner
2 counts, right?
Default turbo advice please
anyone know if a turbo can safely be put on a 1996 2.2l L Coupe Impreza? If so, any suggestions? Thanks!
Darby is offline   Reply With Quote
Old 05-04-2002, 08:43 PM   #2
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
Yeah I would like to know as well..
SubaruImpreza_power is offline   Reply With Quote
Old 05-04-2002, 08:57 PM   #3
STiTuner
Member#: 5778
09 135i
Jet Black
yes if you have money...
its pretyt much the same as all the other subarus.
Brad
STiTuner is offline   Reply With Quote
Old 05-04-2002, 09:02 PM   #4
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
so run it around 4lbs of boost? thats safe right?
Old 05-04-2002, 09:29 PM   #5
STiTuner
Member#: 5778
09 135i
Jet Black
4 pounds is safe if you do it right.. then again 9 pounds should be safe if you do it right too..
Brad
Old 05-04-2002, 09:30 PM   #6
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
ok thanks!
Old 05-04-2002, 09:42 PM   #7
hayscoob
Member#: 4544
2004 STi Aspen White
Bone Stock for now
I was running just 4.4 lbs of boost and POOF! So, 4 lbs can smoke your motor as fast as 9lbs. You MUST use some sort of timing control to avoid a massive internal failure. Trust me when I tell ya, do it right the first time or it's really gonna cost ya. I am at 3k so far for a rebuild. I havn't even purchase the PEMS yet. Ouch! Do it right or else...
Paul...
hayscoob is offline   Reply With Quote
Old 05-04-2002, 09:45 PM   #8
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
Timeing control? you mean like a boost controler?
Old 05-04-2002, 11:09 PM   #9
RS2000
Member#: 2138
2000 2.5 RS-T
BRP
Even if you take all the precautions you can, things can still happen. I went the extra step to be on the safe side and got a tec II and redid the fuel system and my engine still gave way at just 7 psi. Its not totally blown yet but it might as well be, I've been babying it to try to make it last as long as I can while I have an engine built but its getting worse and its just a matter of time before it completely lets go. Good luck to you.
RS2000 is offline   Reply With Quote
Old 05-04-2002, 11:43 PM   #10
STiTuner
Member#: 5778
09 135i
Jet Black
no he means ignition timing controller. the Apexi ITC is one example I believe that Split second makes a similar product.
Brad
Old 05-05-2002, 06:44 AM   #11
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
lol if I ran it at 2psi I very well better off without the turbo....
Old 05-05-2002, 06:46 AM   #12
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
This is the Apex ITC you mean
You your saying if i still use this product my engine can still blow?
Old 05-05-2002, 09:00 AM   #13
STiTuner
Member#: 5778
09 135i
Jet Black
you can blow your engine even with a PEMS.. but the more protective gismos that you have tuned the RIGHT way the less chance you have of doing so
Brad
likes to install ITC's
Old 05-05-2002, 04:40 PM   #14
hayscoob
Member#: 4544
Bone Stock for now
Build up the bottom end and put a PEMS unit in and go for conservative boost/hp levels and you will have a much more reliable car on you hands. Do it wrong, like I did, and you will have a money pit on your hands.
Paul...
Old 05-05-2002, 08:30 PM   #15
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
So your saying.. rebuilt the bottem end of the engine?
Old 05-05-2002, 09:58 PM   #16
hayscoob
Member#: 4544
Bone Stock for now
You don't have to, but I would recommend it. After blowing up my motor and seeing what it costs to rebuild it; I would never want to see someone else go through it. If you can afford to take the proper precautions ahead of time, the better off you will be later on. Wouldn't it be nice to stomp on the accelerator and not worry about the motor flying into pieces...?
Old 05-05-2002, 10:03 PM   #17
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
yeah it would be nice to do that and not have to worry about the engine.. But rebuilting the the bottem part of the engine.. What does that require doing?
Old 05-06-2002, 08:12 AM   #18
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
Could I get by just by changeing the pistons? Or I need to change the block?
Old 05-06-2002, 08:16 AM   #19
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
I'am looking at Cobb tuneing now... they have the Short Block & the Cylinder Head for a Impreza 2.5 RS... I can't use that in a 2.2 L can I?
Old 05-06-2002, 09:09 AM   #20
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
Is this True?
"The 4EAT tranny (auto) can handle more boost than the 5-speed manual. The manual can only handle up to 5 psi (5psi then change clutch: 10psi then change tranny/to Larry's Chalek dog gears), but I don't actually know how much more the 4EAT can handle over the manual. I'm just waiting for Templar's supercharger to come through. *fingers crossed*"
seen here
http://pub58.ezboard.com/fimprezarsd...picID=79.topic
Old 05-06-2002, 05:39 PM   #21
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
So how do I go about to add a turbo if the 2.5 RS Short block wont fit on the 2.2L engine? finding another used 2.2 engine is not going to help... just the same thing..
Old 05-06-2002, 06:08 PM   #22
STiTuner
Member#: 5778
09 135i
Jet Black
all of the EJ engines are the same physical size... they just have different bore and stroke but the outter shell of them is the same.
the only thing that is different sometimes is the heads. I do believe that the DOHC heads had a slightly different exhaust port design but eveything should bolt up fine.
Brad
Old 05-06-2002, 06:13 PM   #23
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
So when I'am ready... I just get the stage 3 short block from Cobb tuneing.. and it should bolt up fine.. but the exaust ports might be a little differnt so just get exaust ports that fit the 2.5 RS motor then right? If the person said.. If you want to add a turbo.. Make sure it's done right first.
Old 05-06-2002, 06:23 PM   #24
STiTuner
Member#: 5778
09 135i
Jet Black
you're heads will be fine on that car after reading it more.... not sure which head gasket you're going to be using though.
Brad
Old 05-06-2002, 06:28 PM   #25
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
The Cobb Stage 3 does not come with the head gaskets? I'am sure thats not going to be that hard to their...
Turbo advice please fastlanerex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 36 04-21-2007 07:57 PM
going for my turbo upgrade need some advice please Berts_Wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 06-04-2006 12:10 PM
Advice on my new 1985 gl turbo wagon please??? Sun Valley Boy Newbies & FAQs 5 10-28-2004 03:11 PM
Advice please....Stock turbo+sti pinks+EM=??? skiblur Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 08-23-2004 08:37 PM
Some Turbo Advice Please SubyDoobyDoo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-19-2002 03:04 PM
