Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 02-16-2009, 10:56 AM   #1
Tuned200
Member#: 127740
2015 WRX-Mine
2007 F-STI-Her's
Default What is the max boost for the VF48?
As it says, looking for solid #'s to figure out if my vf48 is being pushed. Im at 18 psi now and wanting more.
Tuned200 is offline   Reply With Quote
Old 02-16-2009, 12:47 PM   #2
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
What does your tuner say? Please don't say you are controlling it without engine management.
Old 02-16-2009, 04:40 PM   #3
Badler
Member#: 133597
More boost doesn't always = more power FYI.
Badler is offline   Reply With Quote
Old 02-17-2009, 12:17 AM   #4
Tuned200
Member#: 127740
2015 WRX-Mine
2007 F-STI-Her's
I understand this. I am protuned with supporting mods and ap. I was just asking if there is anymore room to add more psi? I was told it was cut off since my 4eat was about at the limit. basically if there is more room i wouldl ike to get a racegas tune.
Old 02-17-2009, 12:25 AM   #5
modaddict
Member#: 95840
sold to a good bud
awaiting next car
I think the vf48 will make hella boost if you weld the wastegate shut or the shaft twists in half.
modaddict is offline   Reply With Quote
Old 02-17-2009, 03:02 AM   #6
Tuned200
Member#: 127740
2015 WRX-Mine
2007 F-STI-Her's
Yeah. Thanks for the words of wisdom.
Old 02-17-2009, 08:49 AM   #7
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
You can't add boost without tuning. Talk to your tuner as our words mean nothing without your tuner's advice.
Old 02-17-2009, 09:44 AM   #8
testes1010
Member#: 47145
2012 Gas Saver
Depends on how the map was originally tuned.
The VF48 on 93 should have another 3-4psi left in it if intercooling & fueling capacity are adequate.
testes1010 is offline   Reply With Quote
Old 02-17-2009, 09:52 AM   #9
Tuned200
Member#: 127740
2015 WRX-Mine
2007 F-STI-Her's
This is the info im looking for. Lets assume I have pleanty of fuel and intercooler forthe job. I am happy with my 18psi tune for street and dd use. I would like a high boost map, as well as a low boost map. I will talk with my Jorge about my options as well. Im just gathering info.
Mr. Testes, you have a pm. I have questions about your set up as im looking to upgrade my lgt too.
Old 02-17-2009, 10:31 AM   #10
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
<<<<< Our turbos are pretty much identical. I have 40k miles on the car and between 4-5k are on the high boost map. 28psi yields only a few more whp than 23 psi, but in the midrange you get a crazy kick. Tuning and boost control is key, this will help determine how agressive you can go with timing.
On the high boost map I run the 28psi with 34-35 degrees of timing up top, and the car is reasonably quick for such a small turbo.
STi Mikey is offline   Reply With Quote
Old 02-17-2009, 11:03 AM   #11
WagonGGA
Member#: 134481
08/4 Subaru
Legacy Spec B/Forester XT
STI Mikey- What engine management do you use?
WagonGGA is offline   Reply With Quote
Old 02-17-2009, 11:13 AM   #12
modaddict
Member#: 95840
sold to a good bud
awaiting next car
Holy crap I run half of that!
Old 02-17-2009, 11:31 AM   #13
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
I use Ecutek w/ easy ecu. When I first purchased the car, I only wanted to spend top dolar on quality EM. My 04 sti was a 23psi pump gas monster and had the ecutek, so i figured I would stay consistant.
If I could go back and do it again, I could make the same power + have more options (ffs & lc) with open ecu. It was 1100 with all of my software and two tunes. It could have been free if I used open
Nonetheless, the car is performing as well as healthy through 40k.
Old 02-17-2009, 05:25 PM   #14
Tuned200
Member#: 127740
2015 WRX-Mine
2007 F-STI-Her's
Mikey, you have a pm. This info is what I was wondering and looking for. the max air a vf48 can push before maxing out.
thanks a lot
B
Old 02-17-2009, 05:59 PM   #15
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
I run my td04 up to 21-22psi in the midrange and it is quite entertaining
What is the max PSI for the 2009 WRX stock turbo? 2407WRX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 06-10-2009 02:28 PM
What is a tax cut for the rich? Corn-Picker Political Playground 43 11-30-2005 01:43 PM
what is the max boost for the sti 4 banger Tri-State Area Forum 1 09-23-2003 08:24 PM
What is the MAX boost for a VF30 fatray Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 07-16-2003 03:21 PM
What is a good price for the 1yellow03 Tire & Wheel 4 06-25-2003 09:43 PM
