Old 02-16-2009, 04:20 PM   #1
stg2wgn
Member#: 182387
2004 Wrx Wagon
WRB - stg. 2
Default stage 2 wagon tune at surgeline! (stats inside)
Well today I had my car tuned my tim bailey at surgeline today. i ended up with 249awhp and 259awtq on his in house mustang dyno. this was on WA 92 pump and the boost peaked at 16.5 on the stock turbo. i will shortly post up some videos, pictures, and the dyno graph. im very happy with my results :] it pulls much stronger and smoother now than it did, and its also safer as it was running too lean for tims preferences on the ots cobb map. i was pleased to hear him say it was the most powerful stage 2 hes seen :]
stg2wgn is offline   Reply With Quote
Old 02-16-2009, 04:30 PM   #2
wrxhard
Member#: 108091
Odd. Cobb maps are usually quite rich. Mod list?
wrxhard is online now   Reply With Quote
Old 02-16-2009, 04:31 PM   #3
Nuke209
Member#: 108089
2003 WRX
NF Performance
hm, lean for cobb ots?
maybe you have a leak!
Nuke209 is offline   Reply With Quote
Old 02-16-2009, 04:34 PM   #4
Praet0rian
Member#: 175172
2006 STI
AW
Please show us your mod list, this will help me decide whether I want to stick with a stage II tune or go with a VF39.
Praet0rian is offline   Reply With Quote
Old 02-16-2009, 04:43 PM   #5
stg2wgn
Member#: 182387
2004 Wrx Wagon
WRB - stg. 2
The new 16.5 psi stage 2+ protune
Heat Wrapped Borla Header
Cobb Down-Pipe
Gutted Up-Pipe
Cobb 3" Exhaust
Cusco Turbo Heat Shield
Samco Intercooler Pipes
K&N Filter
Stock Air Restrictor/Silencer Removed
2004 Sti Top Mount Intercooler
Cobb Radiator Shroud
Zerosports Air Splitter
Kartboy Short-shifter
Gruppe-S Shifter Bushings
Eibach Sport Springs
Cobb Front & Rear Sway-Bars
Cobb Tuning Shift Knob
Rallitek Front Plate Delete
Jdm Sti 02-03 Hood Scoop
Primitive Racing 3/16ths Rally Skidplate
Rally Armor UR Blue Logo
Custom Painted Headlights
Custom Fitted Iridescent Turn Signals
17 x 7.5 Gun Metal Rota Tarmac IIs
235/45/17 Toyo Proxes 4s
(I just decided to post all of them cause i wanted to :P HAHA)
Old 02-16-2009, 07:12 PM   #6
flycaster
Member#: 60142
2011 WRX
Grey
I thought Tim worked on the Cobb maps, or so I was lead to believe. Regardless, they are not a "one size fits all" proposition, and I'd be willing to wager that the Cobb OTS map was far richer than the OEM map.
flycaster is offline   Reply With Quote
Old 02-16-2009, 11:05 PM   #7
jmlaser
Member#: 125529
02 WRX 18G EJ205
1/4 mi stock block record
I dont think Tim wrote the old Cobb OTS maps. I think he was only involved with the ones that were created more recently
Well done,... I remember my stage 2 protune (by Tim). It was ALOT of fun and very smooth
ENJOY
jmlaser is offline   Reply With Quote
Old 02-17-2009, 12:10 AM   #8
stg2wgn
Member#: 182387
2004 Wrx Wagon
WRB - stg. 2
thanks. :] im very happy with my results! i havent seen any stage 2s yet hit close to my numbers on a mustang dyno
Old 02-17-2009, 01:16 AM   #9
Cobb Tuning
Member#: 4803
ENJOY
That is correct. I started creating base maps for Cobb Tuning in early 2008.
Flycaster's comment regarding air fuel ratio's is spot on in regard to 2007+ Cobb Tuning OTS calibrations. Subaru's new (2007+) calibration strategy kept the fuel ratio as lean as possible even while under full boost. The best way to correct this dangerous condition while enhancing torque and improving drive quality is to appropriately richen the Air to fuel ratio when under boost. Take a look at any 08 sti stock dyno plot compared to a stage 2 tune.
Best regards
Tim
Old 02-17-2009, 01:26 AM   #10
stg2wgn
Member#: 182387
2004 Wrx Wagon
WRB - stg. 2
haha thanks tim. here is a video, high res photo, and the dyno sheet. plus i gotta hand it to tim for some great service, expertise, and friendliness. i had a great time this morning at surgeline and would recommend his services for anyone!
Dyno Video
Old 02-17-2009, 02:02 AM   #11
08EJ25
Member#: 174022
2008 WRX
Lightning Red
Nice numbers!
08EJ25 is offline   Reply With Quote
Old 02-17-2009, 12:55 PM   #12
flycaster
Member#: 60142
2011 WRX
Grey
Originally Posted by Surgeline Tuning View Post
That is correct. I started creating base maps for Cobb Tuning in early 2008...
Thanks for the heads-up, Tim. I knew you became involved at some point in time, but I didn't know when, nor did I know how old the map was that the OP was referring to. I'm still planning on heading over the hill for a touch-up tune when I get the DW's swapped in for the old Perrin 816's...just a matter of when the docs clear me to start driving this dang car again.
As for Tim's comment about the OEM AFR's, search P&L's thread in PPB from last year that shows a dyno pull with on a bone stock car, with boost, AFR's, and timing plotted - it is simply unfrigging believable. At 3.2 - 3.5K, the fueling was so lean that the OEM tune backed the timing advance almost down to zero to stop detonation. Frankly, it's amazing that every single one of these cars doesn't break a piston or 2.
Old 02-17-2009, 07:07 PM   #13
jmlaser
Member#: 125529
02 WRX 18G EJ205
My old Master Bailey tune on Buschurs Mustang Dyno was
240whp/270 wtq
on pump and 250/315 on C16 Broke in the 12's too
Old 02-17-2009, 07:49 PM   #14
Cobb Tuning
Member#: 4803
This is the strategy for every new subaru..... lean with full boost until 4K or later. The stock calibration on the 09 forrester xt will hold full boost and leaner than 14:1 until 5k or later.
I agree. Its amazing more newer stock turbo subaru's don't break. This terrible OEM tuning strategy makes my job really easy.
Tim
Old 02-17-2009, 08:19 PM   #15
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
FNF LSX Swap,E85 and more
^ lol
TDagen is offline   Reply With Quote
Old 02-17-2009, 10:02 PM   #16
stg2wgn
Member#: 182387
2004 Wrx Wagon
WRB - stg. 2
240whp/270 wtq
god damnit haha
Old 02-17-2009, 11:03 PM   #17
flycaster
Member#: 60142
2011 WRX
Grey
Don't sweat this - the gas they use in Ohio is unlike what we get out here. I'm not kidding.
Old 02-17-2009, 11:57 PM   #18
stg2wgn
Member#: 182387
2004 Wrx Wagon
WRB - stg. 2
haha good i cant believe how much of a difference the tune made in daily driving tim. its absurd.
Old 02-19-2009, 11:38 PM   #19
slowwrx02
Member#: 117548
02 WRX
nice number man. i just got my tune by tim today and made 248whp and 264 torque. we have similiar setup. except i run 255 pump and intake
slowwrx02 is offline   Reply With Quote
Old 02-20-2009, 02:05 AM   #20
Eric Rule
Member#: 198864
2008 wrx
wrb 375 whp/430ft lbs tq
I had my car tuned at Surgeline by Tim as well. I feel so lucky to live so close to one of the greatest tuners in the industry! 349whp 368ft/lbs torque!
Eric Rule is offline   Reply With Quote
Old 02-20-2009, 02:32 AM   #21
slowwrx02
Member#: 117548
02 WRX
damn man i envy 2.5 nice torque!!!
Old 02-28-2009, 05:42 PM   #22
stg2wgn
Member#: 182387
2004 Wrx Wagon
WRB - stg. 2
haha i still enjoy my 2.0l td04 quick spool torque!
Old 03-01-2009, 03:15 AM   #23
stiffler199
Member#: 177607
2008 GR STI, OBP
Stage 2 , BBS wheels
we all are damn lucky to have the best and easiest shop to deal with right in our backyard. I'd love to put the Metro area's subbies vs. other major cities. Bet we'd have way more and done the RIGHT way. Surgeline FTW!
stiffler199 is offline   Reply With Quote
Old 03-01-2009, 08:40 PM   #24
stg2wgn
Member#: 182387
2004 Wrx Wagon
WRB - stg. 2
absolutely. ^ +2823757652
tim is the man when it comes to doing business in this field. Portland is easily becoming the capitol for cars on the west coast, with all the different shops, scenes, and racetracks available.
08 STi stage 2 dyno tune at The Shop MistirSTI Proven Power Bragging 9 10-16-2009 10:33 PM
Drive to tuner with 650cc's and 18g on my stage 2 Ecutek tune? B16A2NR Commercial ECU Reflashes 6 02-20-2007 11:41 AM
Cobb Stage 2 + Precision Tuning (shop) kevin2.5rs Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 07-01-2005 03:35 PM
COBB stage 2 dyno'd @ Tuning Technologies Drews_WRX Southern California Impreza Club Forum -- SCIC 32 01-29-2005 01:10 PM
Stage 2 CLB Tuning Rich10 Engine Management & Tuning 0 05-30-2003 11:18 PM
