Old 04-08-2002, 11:35 AM   #1
willguidry
Member#: 16388
Default GANZFLOW vs COBB CAI
Ok, just a quick question. I've been through everything here, but would like to buy today. Question is.
Which one?
Both are same price, but which is better?
Please give me your thoughts and knowledge.
Which one do you run? How was it to install? Do you love it? and why?
Putting this into a MY00 RS
Cheers
William
willguidry is offline   Reply With Quote
Old 04-08-2002, 11:47 AM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
first
naughty naughty no caps in the subject lines
2nd
cobb better but more epensive..
tried both
cobb is also noticably louder
Old 04-08-2002, 11:56 AM   #3
willguidry
Member#: 16388
I didn't use ALL caps
I seriously thought that you couldn't put ALL caps in subject line.
SORRY!!!!
Can I change it?
Anyhoo.
Cobb huh. And the cobb is louder?
Annoyingly? or boxer-licious?
Also, for the MY00 do we have to jack the car, and remove the tire to remove the stock air box? Cause it looks as though mine is sitting IN the engine bay on the left fender front.
What kind of HP/torque gains can I expect?
Cheers
William
Old 04-08-2002, 12:05 PM   #4
jhayzhon
Member#: 2933
BOTH of them are the same price now? Did Cobb bring the price down or did Larry up his?
Well the general consensus is that the Cobb intake is the better of the 2(not by much though).
Jason(happy with his ganzflo intake and stock filter )
jhayzhon is offline   Reply With Quote
Old 04-08-2002, 12:09 PM   #5
jhayzhon
Member#: 2933
BTW - the intake install is very simple. All you have to do is unscrew some bolts, remove the snorkus assembly(airbox too if you're doing the cobb), and stick in the intake(I left out some details but you get the idea). I did mine extremely slow cause i'm paranoid like that and it took me like 20 - 30 minutes. Knowing what to do now it would probably take me like 10-15 to put one on.
Old 04-08-2002, 01:14 PM   #6
spiralsmurf
Member#: 16085
2005 STi
i believe the ganzflow will provide more torque gains since it retains the factory airbox which provides for standing air. other than that they should be about the same. i also thought the ganzflow was cheaper. its $109 right now with shipping.
spiralsmurf is offline   Reply With Quote
Old 04-08-2002, 02:09 PM   #7
willguidry
Member#: 16388
So now I'm confused.
Will I loose my low end torque if I get the Cobb?
Please Help!
Cheers
William
Old 04-08-2002, 02:10 PM   #8
DanzBorin
Subaru Bounty Hunter
Member#: 7131
2015 Outback - Croc
Dundee Edition Ice Silver
Depends on what you want...
Cobb is the best, bar none, but more expensive. The sound is great, not too loud, and only when you stomp on it.
Ganzflow is the best for the money, but not as good on the top end, and the sound isn't as ravenous...
It's up to you, but if the $ isn't a huge issue, I recommend Cobb.
Hope this helps
DanzBorin is offline   Reply With Quote
Old 04-08-2002, 02:31 PM   #9
willguidry
Member#: 16388
Money is not the issue.
I just want the best for my money.
Looks like I'll be ordering the Cobb then.
Cheers
William
Old 04-08-2002, 02:34 PM   #10
Dolphin Overton
Member#: 1925
01 A4 89 944s2
13 Speed 3R 99 Sprint
The cobb is better, the stock airbox does pretty much nothing. The only thing the stock box is there for is to provide a large quantity of air immediatly when you step on the gas. So it basically makes up for the poor flow from the stock piping for quick stabs at the gas. Top end is horrible.
The Cobb does not loose any tourque noticeably. High end is better than any intake out. Plus it comes with the best filter you can buy. Go to www.imprezars.com . Even Larry himself says the Cobb is better. Calls it a "Stage 2 Ganzflow" or something like that.
Dolphin Overton is offline   Reply With Quote
Old 04-08-2002, 10:57 PM   #11
edkwon
Member#: 453
2014 Audi S4 B8
2016 Porsche Cayman GTS
Question is, how well does the COBB intake work with the MY99 RS with the MAF sensor? any problems with sensor burnout, will i need to also install a SuperAFC?
Ed
edkwon is offline   Reply With Quote
Old 04-09-2002, 01:22 AM   #12
hacman
Member#: 3603
edkwon - the cobb won't work with the 98/99s in it's native form. I've heard of folks getting them, splicing in the MAF, and using the kartboy MAF adapter.
the only fear I would have would be blowing the MAF due to vibration. but if you can secure the MAF (like Peaty did on his) then you should probably be fine.
Eventually, I'm going to do it. but for now, I just did the cone filter (that's my car on imprezars)
as for the safc, I'm pretty sure it's a must have with the 99s (98 uses a different MAF)
hacman is offline   Reply With Quote
Old 04-09-2002, 07:39 AM   #13
edkwon
Member#: 453
2014 Audi S4 B8
Ahhhh poo, being a MY99 MAF owner really kills me sometimes
Ed
WTT: Cobb CAI for ur Ganzflow CAI ommmjido Bay Area Impreza Club Forum -- BAIC 0 11-05-2004 03:55 AM
Injen Vs Cobb CAI ClimbinNBouldern Normally Aspirated Powertrain 46 03-13-2004 02:28 AM
COBB CAI vs GANZFLOW Yebisu69 Normally Aspirated Powertrain 25 10-23-2003 01:57 PM
Aem Short Ram vs Cobb CAI custus Normally Aspirated Powertrain 12 07-01-2003 07:59 PM
ganzflow vs cobbtuning intake Blindeye_03 Normally Aspirated Powertrain 9 03-10-2001 10:37 AM
