Old 02-16-2009, 09:41 PM   #1
Popwar4207
Member#: 169487
2006 STI
Default When Do I Need A Tune?
As of right now I am stock and untuned. I am getting a cobb intake and an HKS exhaust soon and was wondering do I need/want a tune with just those mods?
Popwar4207 is offline   Reply With Quote
Old 02-16-2009, 10:01 PM   #2
kbcr3
Member#: 44170
2010 Forester XT
05 and 09 honda ruckus
you don't NEED a tune with those mods, but a tune on a stock car makes a performance difference regardless.
kbcr3 is offline   Reply With Quote
Old 02-16-2009, 10:02 PM   #3
2006WRX4ME
Member#: 134286
2006 WRX Limited
I would look into a downpipe of some sort and then thinking about taking advantage of a professional tune. However, as kbcr3 mentioned already, you don't need a tune.
2006WRX4ME is offline   Reply With Quote
Old 02-16-2009, 10:04 PM   #4
PsiAddiction
Member#: 146714
2007 STI
Dark Gray Metallic
i thought if you did a turboback and an intake u deffinitly need cobb stg 2 or a tune?...! because intakes are bad without a tune (lean) i thought..
PsiAddiction is offline   Reply With Quote
Old 02-16-2009, 10:06 PM   #5
Jubert69
Member#: 167739
04 WRX
ej207 spec C 18g
Depends, if you get a Catback exhaust, you don't, if you get a full turboback, you need a tune.
Jubert69 is offline   Reply With Quote
Old 02-16-2009, 10:07 PM   #6
Jubert69
Member#: 167739
04 WRX
ej207 spec C 18g
Cobb, SPT, and K&N do not change air/fuel ratios, so they don't run the car lean. This is because of the piping diameter. There may be other intakes, but I just said popular ones.
Old 02-16-2009, 10:08 PM   #7
T Wrex--OH
Member#: 179478
2000 Impreza 2.5 RS
Sedona Red Pearl
The cobb intake, along with a couple select others, do not alter the tubing diameter, or the amount of air ingested as compared to the stock airbox. They are claimed to not create a lean condition, and therefore do not need a tune.
T Wrex--OH is offline   Reply With Quote
Old 02-16-2009, 10:13 PM   #8
turb04
Member#: 61386
04 PSM WRX R.I.P.
05 Snow White Camry
Hold off on the intake and spend that money on purchasing a downpipe
turb04 is offline   Reply With Quote
Old 02-16-2009, 10:16 PM   #9
F3n1x
Member#: 158728
2000 Forester
This ^, a catless up-pipe (if you don't have one already), and a cross-over. Then find someone local who does opensource tunes and be done with it.
F3n1x is offline   Reply With Quote
When do you have to tune? SilentEdge Newbies & FAQs 26 01-24-2009 10:48 PM
When do I need to replace my water pump? flat4gtguy Service & Maintenance 12 09-24-2002 03:45 AM
When do I NEED engine management? Corn-Picker Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 03-18-2002 09:58 AM
when do I need injectors Hypnotic Perf Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 02-05-2002 01:42 AM
When do you need to align/balance the wheels? e_a_olson Newbies & FAQs 7 07-15-2001 02:16 PM
