Old 02-16-2009, 11:05 PM   #1
Mawheaton
Member#: 192242
Question piston rings...end gap?
I'm about to install a set of OEM standard size rings on a new piston.
The rings are the type that have an overlaping gap. Do I need to be concerned with actually measuring and possibly gapping these?. thanks, MW, Tucson
Mawheaton is offline   Reply With Quote
Old 02-17-2009, 12:43 AM   #2
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Take your finger and dip in oil
Lube up the cylinder.
Take piston ring #2 and insert into cylinder and use piston in opposite direction push in about 1.5"
Use feeler guage to measure gap.
Compare to OEM spec.
Piston ring end gap advice afmardve Built Motor Discussion 22 10-15-2010 09:40 PM
CP Pistons End Gap Question Hayaboosted Built Motor Discussion 39 08-14-2009 12:50 AM
JE 2618 Pistons Ring gap & valve notches... xbcaraudio Built Motor Discussion 4 04-17-2008 10:23 PM
ej20 arias .020 over pistons ring gap Scooby Rex Built Motor Discussion 5 07-30-2006 11:24 PM
ej20 arias .020 over pistons ring gap Scooby Rex Built Motor Discussion 1 07-26-2006 09:33 AM
