Old 04-08-2002, 12:12 PM   #1
willguidry
Member#: 16388
Default can someone explain what grade of gas?
What grade of gas is best for the RS?
I have always believed if you can afford it, put the best in.
Am i wrong in this assumption?
As I have read in here that higher octane lowers your timing etc?
Is that true?
I thought the only difference was that higher octane has a higher temperature burn-off, and thusly left less deposit in the engine.
Am I wrong?
Cheers
William
willguidry is offline   Reply With Quote
Old 04-08-2002, 12:33 PM   #2
tekriter
Member#: 13513
2002 Impreza 2.5 RS
Use regular gas. Do search on this, there is lots of info. Basically, the higher the AKI number the harder the gas is to burn. If you have a high compression engine (you don't) then you need a gas with a higher AKI number.
In very hot operating conditions your engine may knock. the next grade higher will stop it. I have never had this happen with subaru in 160, 000 kms. My Volvo used to knock in the summer.
Anyone that tells you your car runs better on a higher octane gas is a fool.
Different gas grades don't mix well either.
tekriter is offline   Reply With Quote
Old 04-08-2002, 12:54 PM   #3
willguidry
Member#: 16388
So what do I do?
I have been running 93 octane for the last couple weeks.
And have noticed actually it doesn't respond as well when I lay on the gas.
should I be running the lowest?
which is 87.
Or 89?
Will I need to go up in grad when I do mods to my car? IE intake exhaust, that kind of stuff?
Cheers
William
Old 04-08-2002, 01:03 PM   #4
spiralsmurf
Member#: 16085
2005 STi
it has been the general consensus among most people who know about car that unless you have high compression or forced induction you do not need high octane gas, even luxury cars. modern cars are equipped with knock sensors that do a good job of adjusting for different conditions. occasionally you may need it during the summer with a high mileage / higher performance engine as tekriter said. so i say unless you have a wrx go with 87 or 89.
spiralsmurf is offline   Reply With Quote
Old 04-08-2002, 01:15 PM   #5
willguidry
Member#: 16388
Thanks a million Spiralsmurf!
A buddy at work just explained the knock sensor stuff to me, So I guess I'm gonna start saving me alittle cash at the pumps now.
I'll just run 89, stay safely in the middle.
Cheers
William
Old 04-08-2002, 01:58 PM   #6
Jademonkey
Member#: 9213
2000 RS
Red
I was told very strictly I may add, but a tech at Albany Subaru, to ONLY use 87 gas on the RS. Depending on your mods though... I have a borla catback and header with ganzflow, and I get pinging once in a while, so I run 89.
Jademonkey is offline   Reply With Quote
Old 04-08-2002, 02:57 PM   #7
Jack
Add Lightness
Member#: 13699
2004 Outback, 13 XV
(From General)
I use 87 normally and 93 on track days only. Octane rating is a measure of the galoline's resistance to igniting under temp and pressure. Low octane is more like a flash in the cobustion chamber....higher octane burns more slowly. Where lower octane becomes a problem is when your timing is advanced too much...then the gas explosion releases a lot of it's energy before the piston reaches tdc. A higher octane slows the flame front and so the energy release hits the piston as it just brakes over the tdc point.
Old 04-08-2002, 04:41 PM   #8
tekriter
Member#: 13513
2002 Impreza 2.5 RS
well said. the owners manual says 87. It think it takes the ECU a while to adjust ot a new grade as well. I try to get good quality gas from the same place as much as possible.
Old 04-08-2002, 05:20 PM   #9
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
Old 04-08-2002, 05:25 PM   #10
SoCalScooby
Member#: 854
2000 2.5 RS
Blue Ridge Pearl
Talking
I love this board, everyone is so helpful
~Eric
SoCalScooby is offline   Reply With Quote
Old 04-08-2002, 10:10 PM   #11
dsc
Member#: 15559
Now there's a persuasive argument.
dsc is offline   Reply With Quote
Old 04-08-2002, 10:18 PM   #12
Jademonkey
Member#: 9213
2000 RS
Red
Haha...my car definately runs better on 89 than 87. I get slightly more MPG on 89. I ran a tank of each for 2 weeks, after I put on my last mod, taking note of the mpg for the last week for each octane lvl. It's slightly higher...not by much though.
Old 04-09-2002, 12:45 AM   #13
willguidry
Member#: 16388
Yeah, I've been doing 93 Mobil1 gas.
I'm going to switch back down to 89
You guys are awesome, I love learning this stuff from people who know.
Cheers
William
Old 04-09-2002, 06:13 AM   #14
hobun2
Member#: 16831
2000 Legacy L
Dark blue
Question
I've been using 94 octane for the past 6 years on all my cars. Actually, I used 87, then 89, then 91 and then 94 on my second car, 1989 Tracer.
There reason I switched to higher grades was that I was able to gt better gas mileage for a similar price. Also, it seemed that I got better acceleration expecially in low RPM.
I've been using 94 since I bought my MY93 L. Do you guys recommend I switch to a lower grade?
hobun2 is offline   Reply With Quote
Old 04-09-2002, 06:17 AM   #15
hobun2
Member#: 16831
2000 Legacy L
Dark blue
Default Japan
If I remember correctly, they have 98 octane gas in gas stations inthe UK. I think a client of mine told me that a few weeks ago...
Old 04-09-2002, 08:21 AM   #16
tekriter
Member#: 13513
2002 Impreza 2.5 RS
What Grade of Gas? Seahag1978 Baja Forum 14 01-30-2005 07:22 AM
can someone explain what "tarmac" is? Benjamin Tang Vancouver Impreza Club Forum -- VIC 7 10-23-2003 12:54 AM
Can Someone explain what a "clip" does for a turbo? TexRex2002 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 09-01-2003 08:21 PM
What grade of gas does everyone use? madcow Newbies & FAQs 25 05-03-2003 04:33 PM
Can someone explain what ping sounds like? S-WRX Newbies & FAQs 4 09-02-2002 02:02 PM
