Old 02-17-2009, 12:11 AM   #1
apexslider
Member#: 168101
07 STi Limited
COBB Tuned GT35R
Thumbs up New Tune, and loving it!
the bad news is my scanner took a dump, so I cant post my graph...
07 STi
stock motor
stock clutch
GT35R rotated kit (.63 ar)
FMIC
pump gas
Tuned at Surgeline Tuning
I asked Tim to make the tune real conservative, the car's my DD and I dont want to punish the stock internals too much. I asked Tim for 350 at the wheels, and he gave me 354whp and 344wtq at 20.5psi. Peak hp is about 6100rpm and peak tq is about 4360rpm. The afr averaged 11.9
The car drives better then it did stock and pulls all the way to redline. I couldn't be happier. I am going to have Tim raise the boost once a few changes are made to the setup and the speed density software is ready. I think I'll get closer to the 400whp mark at that point....maybe
As for now I'm stoked, the car pulls hard and is a blast to drive, but most important it is very civilized.
HUGE THANKS to Surgeline, they spent lots of time over the past few weeks answering my questions and getting me pointed in the right direction. Also Joey at Double J Motorwerks (non subie shop) for getting the turbo kit to fit...bolt on's never do.
apexslider is offline   Reply With Quote
Old 02-17-2009, 12:15 AM   #2
06-wrx-tr
Member#: 185106
2006 Subaru WRX WRB
Mazda protege'
congrats on the numbers!!! must pull very hard!!!
06-wrx-tr is offline   Reply With Quote
Old 02-17-2009, 02:04 AM   #3
08EJ25
Member#: 174022
2008 WRX
Lightning Red
Nice! Wish we had a good tuner like Tim in AK..
08EJ25 is offline   Reply With Quote
Old 02-17-2009, 02:37 AM   #4
Boost_Creepin
Member#: 202468
06 Scoobie
nice numbers
Boost_Creepin is offline   Reply With Quote
Old 02-17-2009, 02:41 AM   #5
wikedcobra312
Member#: 203207
2004 wrx 2.0/e55amg
nice numbers
wikedcobra312 is offline   Reply With Quote
Old 02-17-2009, 06:25 AM   #6
ScooobaSeth
Member#: 165607
04 Wagon
V-Tuned
average of 11.9? isnt that a little lean only on pump gas?
good numbers!
ScooobaSeth is offline   Reply With Quote
Old 02-17-2009, 07:34 AM   #7
Badazzcr
Member#: 67693
4 Making them
faster then anyone else.
good numbers!
The Mustang Dyno take the avg for the entire run. So that includes when coming into boost and the afr's are mid 13's
Badazzcr is offline   Reply With Quote
Old 02-17-2009, 07:58 AM   #8
STi Mikey
Member#: 114631
2007 11.5 @ 118
Stock Turbo Record Holder
good numbers!
Good numbers with so much more room to expand!!!
I know I do not see this often but on pump gas my AFR's are 12.1 to 1.
I was disturbed when I saw this on the dyno but the car seems to love it after 40k miles with the air/fuels in this state.
OP, is this your original motor and if so whats the milage. Seems you got a strong one!!
Congrats!!
STi Mikey is offline   Reply With Quote
Old 02-17-2009, 09:39 AM   #9
SLOJOE
Member#: 163290
04 STI
PSM DOM 3XT-R
wich 35r kit is this? nice #'s btw
SLOJOE is offline   Reply With Quote
Old 02-17-2009, 10:38 AM   #10
apexslider
Member#: 168101
07 STi Limited
COBB Tuned GT35R
Congrats!!
Yep, original motor. Has just over 18k on the clock.
Its the Perrin kit with a few minor mods done to it, mainly to the intake to support a recirc bpv and a larger MAF housing.
Old 02-17-2009, 12:57 PM   #11
MattPersman
Member#: 139385
awesome results, Tim is so darn good, miss him coming out here
MattPersman is offline   Reply With Quote
Old 02-17-2009, 02:40 PM   #12
cpturbo
Member#: 49175
2004 STI
Well, then. that figure is meaningless. I wouldn't want people to think 11.9 is ok on any pump gas (E85 would be the exception) .
cpturbo is offline   Reply With Quote
Old 02-17-2009, 04:05 PM   #13
n2oiroc
Member#: 141952
03 emo 8/2011 wrx
whats wrong with 11.9? a lot of guys run leaner.
n2oiroc is offline   Reply With Quote
Old 02-17-2009, 04:26 PM   #14
Cobb Tuning
NASIOC Manufacturer
Member#: 4803
Default Dyno Plots
We thought we would post up some plots from last night. The first plot is 15psi tapering up to 18psi and the second is ~20psi. AFR is the value on the right side of the graph.
good numbers!
As you can see in the above plot, AFRs at the tail pipe were 11.7s ramping to 11.5s at redline. Based on our measurements from tail pipe vs down pipe, this would be about 11.5 to 11.2 AFR.
You certainly can run 11.9 AFRs on pump fuel, but that would be on the lean side given the high air volume of the 35R. At high ambient temperatures that might become problematic.
It is equally important to not put too much regard into the exactness of the AFR measurements, especially at the tailpipe. There are some interesting variances I have measured over the years. Discussing .1 AFR differences in a non controlled test environment is fruitless.
Jeff
Old 02-17-2009, 04:28 PM   #15
Iflysti06
Member#: 156955
2006 STI
UR GT35R w/ mad bolt ons
Nice hotside choice, the 3563r spool is soo amazing for a DD car!
Iflysti06 is offline   Reply With Quote
Old 02-17-2009, 04:58 PM   #16
Cobb Tuning
NASIOC Manufacturer
Member#: 4803
Every motor is a bit different. I tend to run motors with higher VE and less back pressure at leaner air to fuel ratio's. As a matter of process i always richen a tune to the point where i can see a power loss. Of course i'm also balancing power output with fuel, boost, ignition timing, and EGT. There is no point to running a leaner mixture or more timing than is needed. Longevity is enhanced when heat is reduced and this is a integration of all major aspects of engine control.
I love subaru's so don't get upset about the following.....
Subaru motors run rich compared to almost anything else out there because they are terribly inefficient. The required rich AF ratios are a function of overall poor VE and heat control. For example, any mitsubishi EVO motor is far far more efficient and that's the reason they run comparatively less ignition advance and much leaner AFs.
Tim
Old 02-17-2009, 05:19 PM   #17
wrblueballs
Member#: 121549
2005 WRX 20G, PPG
nice numbers left with a lot of wiggle room for the future
wrblueballs is offline   Reply With Quote
Old 02-17-2009, 05:38 PM   #18
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
Tim
Calling Phatron..
So Mr.Bailey, is there anything out there yet to combat these issues?
mxpunk is offline   Reply With Quote
Old 02-17-2009, 05:45 PM   #19
Cobb Tuning
NASIOC Manufacturer
Member#: 4803
Originally Posted by mxpunk View Post
Calling Phatron..
What specific issues are you refering to? how do we to make a subaru motor better?
Heads, cams, headers, intake manifold, turbo, etc etc etc.
Its impossible to get around the terribly innefficient design that splits airflow to two separate heads and puts the turbo several feet from the exhaust ports.
Tim -
Old 02-17-2009, 05:49 PM   #20
modaddict
Member#: 95840
sold to a good bud
awaiting next car
Well, I guess my car is not OK.
at 40k, I'm hoping it will blow up soon......
modaddict is offline   Reply With Quote
Old 02-17-2009, 06:31 PM   #21
stg2wgn
Member#: 182387
2004 Wrx Wagon
WRB - stg. 2
nice numbers! tim did my tune for my stage 2+ wrx earlier that morning. combined we did over 600 hp that day. :]
stg2wgn is offline   Reply With Quote
Old 02-17-2009, 06:48 PM   #22
cpturbo
Member#: 49175
2004 STI
You are the guy with the magic Crawford motor. I forgot. Running 11.9 on 91 octane California gas is like living on borrowed time. One bad batch of gas and it could be all over. One track day in hot weather and you will have problems. Really, how many people can honestly say I run at near 12:1 with Cali gas at anything but crossover into positive boost (<8lbs)? The Surgeline guys clarified the AFR discrepancy in an above post. Re-read it. They richen to about 11.2 in this particular case.
Old 02-17-2009, 06:52 PM   #23
n2oiroc
Member#: 141952
03 emo 8/2011 wrx
You are the guy with the magic Crawford motor. I forgot. Running 11.9 on 91 octane California gas is like living on borrowed time. One bad batch of gas and it could be all over. One track day in hot weather and you will have problems. Really, how many people can honestly say I run at near 12:1 with Cali gas?
pump was specified, not 91. some of us are lucky enough to get 93 or better.
Old 02-17-2009, 06:57 PM   #24
cpturbo
Member#: 49175
2004 STI
While I neglected to mention 93, 100 (some do have this at the pump), I did mention E85 which is pump gas AFAIK. I'm not trying to start trouble. I am just pointing out that lean AFR are dangerous on inconsistently blended pump fuel, no matter what the min octane rating is.
Old 02-17-2009, 10:40 PM   #25
modaddict
Member#: 95840
sold to a good bud
awaiting next car
Did you see to the left under my name?
I have a magic subaru OEM motor
amigo, I was on borrowed time 20,000 miles ago.
p.s, I'm still waiting to burn ANY oil at all in 3k miles. You'll be the first I PM when the stock motor lets go cause I ran 11.9:1 AFR on pump. BTW, how would you prove that?
Just bought it and love it...looking for add-ons IndianaJason Newbies & FAQs 2 03-03-2010 05:01 PM
New to Subaru, Loving it so far! dragon_dad Newbies & FAQs 2 03-04-2009 06:51 PM
New '06 owner and love it!!! Balvenie Texas Impreza Club Forum -- TXIC 34 09-04-2007 10:12 PM
Bought a Honda.....and love it check it out, you'll like it JonP North West Impreza Club Forum -- NWIC 12 07-18-2007 12:03 AM
Message Board Statistics All times are GMT -4. The time now is 02:14 AM.
