Old 02-17-2009, 12:55 AM   #1
RllyGC
Member#: 182425
1998 2.5RS Coupe
Default Crossmember fitment
I am currently in the process of converting my 2001 2.5 into a turbo and have a question about a cross member. I have the cross member from a 94 turbo legacy. Will this 1. bolt in 2. require additional modifications? 3. allow me to use wrx headers and up-pipe? I have been in email contact with subachad and he says with a new or notched crossmember I should be able to use a WRX exhaust? Can anyone confirm this?
RllyGC is offline   Reply With Quote
Old 02-17-2009, 10:52 PM   #2
leonwrx13
Member#: 183021
05 STI Parts
i believe it should work fine
leonwrx13 is offline   Reply With Quote
Old 03-02-2009, 12:09 AM   #3
supernick77
Member#: 145122
1999 99 lgt, 86 brat
black, lt blue
good idea. i was gonna get wrx one. but if the old ones work why not.
supernick77 is offline   Reply With Quote
Old 03-02-2009, 08:18 AM   #4
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
the Legacy one works better then the WRX one as you do not have to shim the controll arms.
Zephyr is offline   Reply With Quote
Old 03-03-2009, 11:59 AM   #5
vermonturbo
Member#: 22698
08 Legwrxob
covered w/ snow
Default tleg-crossmember
the exhaust will work fine as they all have the same layout
vermonturbo is offline   Reply With Quote
Old 03-03-2009, 01:46 PM   #6
nick42010
Member#: 114933
alot of
escalades
Your only issue will be your swaybar. A non turbo swaybar will not clear and the WRX one I tried to use was too wide. I believe that A turbo GC8 swaybar will work or a WRX wagon specific swaybar will also.
nick42010 is offline   Reply With Quote
Old 03-03-2009, 08:37 PM   #7
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
just buy a 91-94 legacy turbo front sway bar. I use it on my GF and it works perfectly.
Old 04-10-2009, 04:01 PM   #8
2slofouru
Member#: 90539
95 340whp impreza
05 Raven R6, 07 2.5i
I have the 94 legacy turbo crossmember and can't find the correct swaybar brackets. Anyone know the part number? The dealer ordered some and they were the wrong type, just like the ones on my L. I need the type with two bolts holes instead of one bolt and a lip. Thanks
2slofouru is offline   Reply With Quote
Old 04-12-2009, 06:37 PM   #9
JRach
Member#: 78075
98' SF5 STI
93' GF8 (rally)
+1
unless you plan to run wrx control arms, and then there's other issues
Also, swaybar... if you run the legacy turbo crossmember you need a wrx wagon, or legacy turbo sway bar.
JRach is offline   Reply With Quote
Old 04-16-2009, 09:50 AM   #10
2slofouru
Member#: 90539
95 340whp impreza
Why do you have to shim the control arms? I have the wrx crossmember and the control arms fit pretty snug. I tried installing a 3mm shim but had to hammer it in. Considering I could just tighten the crossmember until it hits the control arm the shim seemed too thick.
FS : Kosei K1 TS STi fitment Arthur Dent Wheels/Tires 4 06-16-2010 12:13 AM
02 Vs 04 Rear suspension crossmember fitment flyinghighlm Newbies & FAQs 0 03-28-2009 05:51 PM
WTB: '02 WRX rear crossmember and front crossmember plate Hank3 Private 'Wanted' Classifieds 2 01-09-2006 08:15 AM
GC8 AWD rear crossmember and T-crossmember moss Private 'For Sale' Classifieds 1 12-25-2005 05:34 PM
wtb: legacy turbo crossmember, or wrx crossmember, new england area hopefully legacy2003 Private 'Wanted' Classifieds 0 06-21-2005 03:35 AM
