Old 02-17-2009, 11:13 PM   #1
Un0RiGiNaL
Member#: 189748
Default I figured out one of the best ways to keep your subs from moving
Well i figured this out a long time ago but never posted it. I have a big enclosure, 2 10" alpine type-r's and i had a problem with them moving around whenever i took turns or etc.
This is alot cheaper than getting a strut bar.
I just cut out some wood for the side of the enclosure and for the front of the enclosure and put it under the carpet. I do donuts and everything and have NO PROBLEM with subs moving around AT ALL. Heres a quick MSPAint of it
And the wood is under the carpet, so its not even noticeable. My amp is mounted on my box so i have that extra space on the right
just make sure the wood is like an 3/4 or 1 inch thick so it can hold the subs.
Un0RiGiNaL is offline   Reply With Quote
Old 02-17-2009, 11:18 PM   #2
alxhastngs
Member#: 152059
2007 WRX Limited
UGM
I guess that works OK until you need to access your spare tire well...
alxhastngs is offline   Reply With Quote
Old 02-18-2009, 12:52 AM   #3
burtont62
Member#: 148211
04 sti
black
L-brackets bolted to the rear deck with wingnuts would save a lot of weight and allow access to the spare.
burtont62 is offline   Reply With Quote
Old 02-18-2009, 02:18 AM   #4
Giganticprune
Member#: 147662
2006 wrx tr stage 2
i just crammed a box from my mtx coaxials inbetween my box and the back of the trunk..
too bad i have a scuff on my surround now..
yeah..building a new box tomorrow-ish..using L-brackets like i should have
Giganticprune is offline   Reply With Quote
Old 02-18-2009, 03:53 AM   #5
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
Your illustration is brilliant. Here's my solution to the same problem
Current setup
Former setup
Audiosavvy is offline   Reply With Quote
Old 02-18-2009, 09:04 AM   #6
Uncanny
Member#: 133012
2015 STi
Lightning Red
I just made a couple of brackets and bolted my box to where the rear wiper motor/assembly would attach on the rear deck...works like a charm.
PS mounting an amp to a box is bad juju... if you ever need to take the box out, you have to then pull the fuse and disconnect all of your power to the amp.
I've also seen plenty of wires get pulled out of an amp from the box moving around the trunk...
Uncanny is offline   Reply With Quote
Old 02-19-2009, 02:17 AM   #7
lowranger
Member#: 124370
03 wrx stg 2.34159
Pro tuned by Cobb Tooning
what about for auto X?
or you could just build another floor, lets say outa 1/4 mdf ow any wood to your liking and build another floor and screw it in like that
lowranger is offline   Reply With Quote
Old 02-19-2009, 02:38 AM   #8
trueno16v
Member#: 175170
2005 WRX Wagon
owl + bungee cord= my a$$
4 small "L" brackets with short wood screws. One bracket on each side + one screw in box + one screw in the floor. Once you unsrew the screws from the floor you can even tell you screwed something in there.
trueno16v is offline   Reply With Quote
Old 02-19-2009, 12:11 PM   #9
Uncanny
Member#: 133012
2015 STi
Lightning Red
What about it? the setup is very similar to Audiosavvys and works extremely well. I have my amp mounted to a custom bracket i made that fits in the drivers rear corner by the jack
Old 02-19-2009, 12:49 PM   #10
Audiosavvy
Member#: 150794
Qcab dakota 4x4
You mean similar to my LAST setup, right? The current setup uses no screws/bolts/brackets, it's built to be about 3mm too tall to fit under the strut brace, so I loosen it up, position the enclosure, and mount it back down. The FEEL of the bass is noticeably better, and there's nothing I can do to even budge the enclosure. I did track it with the last setup, with brackets mounted to the rear deck, and never had a problem, but this setup is better by a bit.
Old 02-19-2009, 12:55 PM   #11
burtont62
Member#: 148211
04 sti
black
Wood screws don't hold well in metal, if your going to screw in to the floor then use a screw with a better thread.
Old 02-19-2009, 01:19 PM   #12
Audiosavvy
Member#: 150794
Qcab dakota 4x4
Good point. The only time they work well in metal is when you're screwing into metal where no hole existed, and so it's distorting and bending the metal out of the way to give the coarse threads something to grab on. Certainly less than ideal
Old 02-20-2009, 12:31 AM   #13
trueno16v
Member#: 175170
2005 WRX Wagon
I'm not talking about screwing into the metal, just the carpeted wood panel that is on the trunk floor.
Old 02-20-2009, 01:09 AM   #14
Scooby-King
Member#: 180499
2007 SRT8-Cherokee
2008 Sierra Denali
Or you could simply not do donuts . . . .
add two L brackets with Wing nuts and be good to go
Scooby-King is offline   Reply With Quote
Old 02-20-2009, 03:46 AM   #15
burtont62
Member#: 148211
04 sti
black
That flimsy fiberboard will slide too if you throw some G's into it.
Old 02-20-2009, 12:33 PM   #16
Djphill_2003
Member#: 178972
2009 STi
Another Cheap and easy solution is to just take strips of the rough side of velcro and stick them to each other (double sided rough velcro). Then lay the strips between the carpet and the bottom of the box. More strips = Less movement.
Djphill_2003 is offline   Reply With Quote
Old 02-21-2009, 04:22 AM   #17
04psmgt35sti
Member#: 203623
2004 STI
464whp
seems fine to me
04psmgt35sti is offline   Reply With Quote
Old 02-21-2009, 10:24 AM   #18
saab-on-the-cobb
Member#: 116330
2005 Saabaru 9-2x
desert sand metallic
Have a Nice Day?
DOn't feel bad.
I get wood from Alpine Bishes, too.
SOTC
saab-on-the-cobb is offline   Reply With Quote
How do you guys keep your subs from moving? Un0RiGiNaL Car Audio, Video & Security 27 12-03-2008 01:09 PM
best way to keep your Ipod safe WrxWonderWagon Off-Topic 5 07-24-2007 02:15 AM
What's the best way to keep coffee fresh? dropmech Off-Topic 21 07-27-2004 03:08 AM
How to keep my sub from moving? wrxtasy555 Car Audio, Video & Security 13 04-21-2002 07:09 PM
